Aperion Audio SLIMstage30 Soundbar Review
- Product Name: SLIMstage30 Soundbar
- Manufacturer: Aperion Audio
- Performance Rating:
- Value Rating:
- Review Date: July 12, 2010 03:45
- MSRP: $ 799
- Specifications
Surround Algorithms: Euphony HD decodes PCM, Dolby Digital 2.0/5.1, DTS Digital Surround
Decoding 5.1 channel: Dolby Digital, DTS Digital Surround, PCM
Decoding 2.0 channel: Dolby Digital
2-channel to 5-channel conversion: Euphony HD
Power: Class-D Amplifiers (RMS at < 0.8%THD) Satellites 80W, Woofers 60W
Maximum SPL@1m:103dB
Main Speakers: 4 each 50x50mm with patented LMD Neo-sandwich magnets
Woofer Arrays: 2 - Each array includes one Active High-Energy 3 ̋ patented LMD Neo-sandwich magnet woofer plus two 3” bass radiators
Power Supply: Digital, 95–265Vac, 36V, 50/60HzInputs (6)
Analog 1 –stereo 1/8” (3.5mm)
Analog 2 – stereo 1/8” (3.5mm) Available 20dB attenuation for speaker level in
Analog 3 – stereo 1/8” (3.5mm) Front Panel, with priority selection
Digital 1 – SP/DIF coax
Digital 2 – Optical / TosLink
Digital 3 – Optical / TosLinkOutputs (2)
Analog: Subwoofer out – stereo 1/8” (3.5mm)
Analog: Headphone (Euphony Virtual Surround) –stereo 1/8” (3.5mm)
Rear Channel Outputs (normal/default off )Accessories
IR remote control
Power supply with cables and mounting strap
EZ-tilt leveling feet with height insert
Wall-Mount Bracket with mounting hardware
3m optical cable
3m 1/8 ̋ mini phone jack cable
3m 1/8 ̋ mini phone jack to male stereo RCA cable
3m digital coax RCA cableControls
Master, Headphone Volume (IR and front panel) Subwoofer level (IR only) Source select, mute (IR and front panel) Surround/stereo (IR only)
Modes: On, Mute, Off/Standby
Off/Standby Power: 2W or less
Weight (approx): 16.5 lbs (7.5 kg)
Dimensions: (WxHxD)–31.1”x 3.5”x3.7”(790x88x93mm)
Height with EZ-tilt leveling feet – 4.4” (112mm)
Height with feet+height insert – 5.2” (132mm)
Depth with wall-mount bracket, any model – 5” (127mm)
Bravus 8A Subwoofer
Frequency Response: 36Hz - 160Hz
Amplifier Power: 100 Watt
Woofer: Single 8" Aluminum Cone Driver
Driver Configuration: Single
Enclosure Type: Ported and Internally Braced 3/4" HDF
Dimensions: 15"H x 13.5" W x 13.5" D (with feet attached)
Weight: 33lbs
- Convincing surround experience
- Nice bass response even without a sub
- Lots of mounting options
- Compatible with many different surround modes
- Wide front soundstage, convincing experience
- Shares codes with other gear
- No auto/integral calibration options
- Extremely small setup menu display
- 3.5mm connector means extra cable purchases
- Not so hot on stereo or musical content
- Surround rarely reaches all the way behind
Introduction
