You are here: Home Pro Reviews Speakers Satellite and Sound Bars Aperion Audio Intimus 4B Harmony SD
by Clint DeBoer last modified October 08, 2008
  • Product Name: Intimus 4B Harmony SD Speaker System
  • Manufacturer: Aperion Audio
  • Review Date: October 08, 2008 05:09
  • MSRP: $ 1179
Specifications
Intimus 4B satellite
  • Frequency Response(+/- 3dB): 120Hz - 20kHz
    Impedance: 8 Ohms
  • Sensitivity: 84 dB
  • Recommended Power: 50-150 watts
    Tweeter: 1" Audiophile-grade Silk-Dome
  • Midrange: 4" Woven-Fiberglass Composite Woofer
  • Driver Configuration: 2-Way
  • Enclosure Type: 3/4" HDF, sealed
  • Dimensions: 8.75" H x 5.33" W x 5.5" D
  • Weight: 6.5 lbs ea.
Intimus 4C center channel
  • Frequency Response(+/- 3dB): 80Hz - 20kHz
    Impedance: 8 Ohms
  • Recommended Power: 25-150 watts
  • Midrange: 2 x 4" Woven-Fiberglass Composite Woofer
  • Dimensions: 5.33" H x 12.8" W x 5.5" D
  • Weight: 8 lbs
Bravus 8D subwoofer
  • Frequency Response (- 3dB): 35Hz - 180Hz (30Hz @ -6dB)
  • Power: 150 watts (BASH)
  • Woofer: Dual 8-inch aluminum cone drivers
  • Driver Configuration: Dual drivers (1 out of phase)
  • Enclosure Type: Sealed and internally braced 3/4" HDF
  • Dimensions: 13.5" H x 12" W x 12" D
  • Weight: 33 lbs
  • Best satellite speaker build quality we've ever seen
  • Solid, powerful bass
  • Beautiful finishes in either High Gloss Black or Medium Cherry
  • Sub includes single band parametric EQ
  • Midrange detail a bit lacking
  • Subwoofer has limited placement options
  • Subwoofer controls a bit tedious
  • Satellites can consume lots of amp power
Introduction
Aperion Audio's Intimus 4B Harmony SD Speaker System may be a lot to pronounce all in one breath - but it may be worth it, if that means you'll get to put them into your listening room. These speakers are incredibly well-built, and do very well in a near-field environment. They are beautiful to look at and the new Bravus dual 8-inch subwoofer leaves a good impression. For those with larger rooms, look to one of Aperion's bigger systems to give you more dynamics and a better fit.
Recent Forum Posts:
armaraas posts on October 08, 2008 21:52
For quick reference, thought I'd throw other current reviews in here for anyone doing research. Of course, I just noticed 3 of them are by the same person...but I'm not going to think about what could indicate...
5T DB System
http://www.ultimateavmag.com/speakersystems/1008int/ [ultimateavmag.com]
6T Tower Speakers only
http://www.enjoythemusic.com/magazine/equipment/1008/aperion_audio_6t.htm [enjoythemusic.com]
http://magazine.playbackmag.net/playback/200806web/?folio=214 [magazine.playbackmag.net]
5B SD System
http://reviews.cnet.com/separate-speakers/aperion-intimus-5b-harmony/4505-7869_7-32981518.html?tag=prod.txt.7 [reviews.cnet.com]
4T SD System
http://reviews.cnet.com/surround-speaker-systems/aperion-intimus-4t-hybrid/4505-7868_7-33192423.html?tag=mncol;also [reviews.cnet.com]
MinusTheBear posts on October 08, 2008 14:22
With Aperion's no risk policy (paid shipping both ways if returned within 30 days) and a ten year warranty on their products is very impressive as well.
rnatalli posts on October 08, 2008 14:04
A nice alternative for those who feel Orbs and Nanosats are too small and full bookshelves too large.
