Z-Base 550 Build Quality, Remote and Setup
In this digital age we live in, sometimes we get locked into the "more-is-better" mode. How many formats can it decode, how many different inputs/outputs does it have, exactly how big is the birds nest of cables coming out of the back of the unit? Actually - that mode works most of the time, but thing is, sometimes you just need to shut up and listen before you pass judgment on it. If you are an old school guy (read - your VCR was always blinking 12:00) the Z-Base 550 does a decent job of creating surround effects by ignoring all the digital data available on a disk and manipulating the analog signal to reproduce what the digital signal contains. There is no doubt that the sound stage produced by the Z-Base 550 is far better than any speaker system included on a display; however during our review we found it to be a little quirky and never really producing convincing surround sound. What it does have is good build quality (with the exception of its dual analog inputs, but more on that later), solid construction materials, and sound quality that is way beyond what anyone would guess based on its rather simple look. So if you've got a room (bedroom, small family room, or apartment) that you'd like to have a high quality surround sound system in, but speaker placement just will not work for a traditional 5.1 system, I'd recommend you give this system an in-home audition and just shut up and listen!
ZVOX is a relative newcomer to the AV marketplace. However, the company is led by industry veterans and has a stout product line of innovative surround sound systems that might just be the perfect solution to those tough rooms we all struggle with from time to time. You know a company has an outside-the-box approach when they shrug off the digital world we are consumed with and tries to convince you that their analog surround system is the ticket for your bedroom or small theater. While it will never compete with a true 5.1/7.1 digital surround system (nor was it really designed to), after spending some quality time with the Z-base 550, we agree this is a great solution for situations where a larger system just will not work, but you still want a high quality product with a great sound.
Build Quality and Features
It is apparent as soon as you remove this system from the box that it is well put together. Although not heavy (it weighs in at about 20 pounds), it is a very solid piece of gear. The cabinet itself is constructed of MDF on top and bottom and the MDF panels with a painted high-gloss finish on both ends give it a pretty slick look. The system is magnetically shielded so it's a great fit for anyone using a flat screen display sitting on top of an AV rack. While the 550 is attractive, one of my favorite things about it was that it virtually disappeared in my room with my display sitting on top of it. According to the website, the base can hold most displays with a base less than 27" wide and 13" deep, and a weight of less than 90 pounds.
Reviewer's Note: I couldn't help but laugh when I got my box, unloaded this exciting new product designed to work as a base to sit your display on and found a sheet full of warnings that included: "Placing objects on top of this device can result in tippiness." and "Do not place anything on top of this device that might topple over." Gotta love those attorneys!
The 550 is bi-amplified (60-watt amplifier), and includes
five 2" main drivers, and a 5.25" subwoofer (bottom mounted) in a
ported enclosure. No skimping on speaker
components in this product. It uses
specially treated long-excursion main drivers with Neodymium magnets. The back panel includes 2 "mixing"
analog inputs, a subwoofer output, and a power switch. As an example of the great design of this
unit, it includes a subwoofer output on the far right side (if you are looking
at the back of the unit) of the panel.
One note on the mixing inputs, if you have two sources connected to the
Z-base and both are on, you'll hear both devices. This is a HUGE no-no and
we're at a loss to understand why ZVOX would do this, except to save money on
a true switching feature. While the system sounds great as is, if you're a true
home theater enthusiast or an audiophile, you're going to want to add a
subwoofer to this system. On the other
hand, if placement is intended for a bedroom system, you could easily get away
without a subwoofer - it's going to be better than most TV speakers.
While the system is completely analog, it is not without innovation. ZVOX's PhaseCue system is the technology that produces the virtual surround sound. The short version of this technology is that it manipulates analog audio signals by mixing various levels of "in phase" and "out of phase" signals into its 5 drivers. The result is an impressive sound field that is truly bigger than would seem possible. While it cannot compete with a full blown (and full price) 5.1 or 7.1 surround system, it did generate very impressive surround effects during our review of several movies. Equally impressive was the wide sound field it generated with some of my favorite music discs as well. I spent quite a bit of time tweaking the PhaseCue setting during this review, with one end of the spectrum seeming to push the sound farther apart (although the extreme end seemed to cause some loss of mid-range and ended up sounding too tinny to tolerate) and the other end of the spectrum drawing them closer together. With no presets, you are free to find the setting that works best with the set-up in your room. I found that my favorite setting for music was definitely different than my favorite setting for movies. I suppose having the ability to set those levels once I dialed them in might be a convenience, but it was actually kind of fun picking the setting that worked best for the specific disc I selected. Perhaps that fun would diminish over time, but for the course of this review, it remained simply an exercise in dialing in each disc I picked out. The 550 system also takes advantage of ZVOX's Infinite Compliance system to generate bigger-than-expected volume using acoustic tubes within its MDF body. While it could not rock the house, it produced acceptable audio levels for watching movies and music in small rooms. The auto on/off circuit will also turn the power on and off when you turn your source on (or off) eliminating one step in the button pushing process.
Remote & Setup
It also comes with a small (possibly too small if you lose remotes as frequently as I do!) remote that
operates volume, the PhaseCue effect, subwoofer levels, and treble levels. The remote also has a power button and mute
button. There is no display on the
remote or the Z-base 550 system to tell you where you are within each option's
range; nor are there any presets (say for a movie setting vs. music setting) to
help "memorize" your favorite settings. Everything about this system
is done by ear, by design, and with very few visual cues.
Manufacturer's Note: The blue LED beneath the grille flashes once for every "level change" for any setting - volume, PhaseCue, subwoofer or treble. Volume has 22 steps. The other settings have 9. If the user goes all the way up to max on any setting, the LED stops flashing and stays continuously on, informing the user he is "at max." From max, he can then back down two flashes/pushes and know that he is at 7. [This] lets us have the super-clean front panel we were striving for.
Setup is about as easy as you can possibly imagine. I can't remember the last time I bought anything that came with only 2 pages worth of instructions. No long list of acronyms on the box announcing the vast number of formats it can decode. No figuring which type of cable you need to carry signals amongst all your gear. Just 2 analog (yep that's old school, red and white) inputs on the back of the unit and one analog subwoofer output, oh yeah, and a power switch. That is it. No figuring ways to hide speaker wire either. No question this was the easiest set up of any review EVER! I can even add that it was so easy, even my technically-challenged spouse was able to figure it out without having to call me for help.
See also:
