You are here: Home Pro Reviews Speakers Lifestyle, Desktop and Portable Yamaha NX-U10 USB Speaker Video
by Clint DeBoer last modified November 21, 2007
  • Product Name: NX-U10 USB Speaker
  • Manufacturer: Yamaha Electronics
  • Review Date: January 07, 2007 19:00
  • MSRP: $$179.99
Specifications
Amplifier Section
Input Terminal (Digital): USB port
Input Terminal (Analog): Stereo L/R: 3.5mm stereo mini jack
Output Power (Max. Instantaneous): Total 20 W - 10 W x 2 (1 kHz, 10% THD)
Speaker Section
Speaker Type: Yamaha SR-Bass technology, stereo
Frequency Response: 90 Hz - 20 kHz
USB Section
Computer: Computer with USB port
OS: Windows Vista, XP, 2000, ME, 98SE, Mac OS 9.1 or later, OS X 10.0 or later
Dimensions: (W x H x D) 248 x 100 x 33 mm; 9-3/4” x 3-15/16” x 1-5/16”
Weight: 0.5 kg; 1.1 lbs.
Supplied Accessories: USB/AC adapter, USB cable (1m), battery holder, carrying case, 3.5mm stereo mini cable (0.5m) and non-skid pad (x 2pcs)
Executive Overview
The Yamaha NX-U10 USB speaker is a multi-faced speaker that can be powered in almost any way imaginable... except for fuel cell or solar. OK, so it takes USB power, batteries and even AC - but it's still a cool option for getting sound that bests the often underwhelming sound quality of most laptops. With its lightweight styling and surprisingly loud output levels, the NX-U10 will make for a portable speaker solution that won't take up much room and fits nicely into your laptop case.
Tom Andry gets a hands-on look at this new product form Yamaha Electronics.
For more information please visit www.yamaha.com/yec
