Mondo Mint Music System Review
- Product Name: Mint Music System
- Manufacturer: Mondo USA
- Performance Rating:
- Value Rating:
- Review Date: August 10, 2007 08:45
- MSRP: $ 349
- Specifications
Amplifier
Type: Class-D with T.I. PurePath DigitalColor: Silver/white 2-tone
Inputs: iPod dock (5 size adapters included), 1/8-inch line-in, USB 1.1
Connections: Binding posts, wireless dipole antenna
Power: 70W rms 4-ohms per channel (compatible with 4-, 6-, or 8-ohm speakers) 90-265VAC, 50-60Hz, 0.6/1.0A switching mode power supply
THD+N @ 1W: <0.1% @ 8-ohms, 1kHz
Channel Separation: >65dB
SNR: >100dB
Damping Factor: >20Dimensions: 6.5” W x 3.8” H x 0.95” D (165 x 97 x 24.5 mm)
Weight: 2 lbs (920g)
Loudspeakers
Type: Two-way ported system
Enclosure: Wood enclosure with glossy piano white coating and removable cloth grills
Color: Piano gloss white with gray grills
Drivers: 1-inch Peerless neodymium textile tweeter; 4-inch AuraSound aluminum cone with patented NRT magnetic structure
Frequency Response: 60Hz ~ 25kHzSpeaker Connections: Binding posts
Nominal Impedance: 4-ohms
Dimensions: 5.6” W x 7” H x 8.9” D (260 x 113 x 209.5 mm)
Weight: 5.5 lbs (2.5 kg) each
Included Cables: 4.9 ft Canare speaker cables with banana connectors; USB audio cable; 2-prong power cable
- Small form factor
- Elegant looking
- Dual iPod docking configurations (including wireless)
- Mint Audio Control application for fine-tuning
- Woofers won't bottom out
- No digital inputs
- Weak website support (un-manned message boards)
- No subwoofer support
- Sizzly highs
Introduction
Recent Forum Posts:
admin;294479
The Mondo Mint system is both a lifestyle music product, USB audio device AND a wireless iPod system. Now, it's not every system that allows you to drop your iPod into a local OR remote charging station and have either location play it through the same set of speakers. And just TRY to find something that can play audio via USB from your PC as well... The Mondo closely resembles a double-wide Apple Mini, with the same color motif and rounded corners. It's a nice look and the machine will fit in well with an AppleTV should you decide to go that route.
Discuss "Mondo Mint Music System Review" here. Read the article [audioholics.com].
Double-wide? Does it come with a little Astro-turf mat and tiny white picket fence?
Critofur;689740
I can't seem to find the frequency response measurements? You wouldn't do a speaker review without measurements, would you?
Why not? Bose does.
