You are here: Home Pro Reviews Speakers Lifestyle, Desktop and Portable McIntosh MXA60 Integrated Audio System First Look
by Tom Andry last modified December 23, 2009
  • Product Name: McIntosh MXA60 Integrated Audio System
  • Manufacturer: McIntosh
  • Review Date: December 23, 2009 19:10
  • MSRP: $7500
Specifications
  • 75 Watts/Channel Output
  • Two-way Loudspeaker System
  • Cast Aluminum Loudspeaker Construction
  • Loudspeaker Tilt
  • CD/SACD Player
  • 24-bit, 192kHz Sampling Burr Brown DAC
  • AM/FM Tuner with RBDS Display
  • Custom IR Remote Control
  • Balanced and Unbalanced Audio Input
  • Line Level Output
  • Vacuum Tube Preamplifier
  • ThermalTrakā„¢ Output Transistors
  • Power Guard
  • Two line Vacuum Fluorescent Display
  • Illuminated Output Watt Meters
  • R-Core Power Transformer
  • Headphone Jack
Executive Overview
mxa60_angleWhat do you get for the audiophile with everything this Christmas? They already have amps galore, cutting edge processors (meaning it actually has HDMI), power cables as thick as a baby's arm, and a record cleaning machine to keep their vinyl in all of it's pristine, scratchy, glory. They've got racks, stacks, and isolation. They have speakers that cost more than most cars, amps that require forklifts to power them, and a closet full of discarded gear that would make any self respecting Audioholic weak in the knees. They don't have any room treatments but they're sure they do need them. So what to do?
McIntosh has the answer. The MXA60 Integrated Audio System is a standalone tabletop system complete with a CD/SACD/MP3 player, 75-watts per channel amplifier, and speakers. This system is for the true connoisseur of high end audio. The preamplifier is tube powered (yeah!) and the speakers are two-way bass reflex.
What has always distinguished McIntosh, of course, is their look. The MXA60 doesn't disappoint. The case is all metal with anadized aluminum accents. The front analogue gauges (a virtual requisite for any piece of McIntosh gear - someday they'll release a speaker with these) are present with that trademark (and quite comforting) blue backlit glow. You rarely need to see a logo to know that a piece of gear is constructed by McIntosh and the MXA60 is no different.
The 75 watt per channel sports a number of McIntosh features including:
  • 75 watt per channel, complementary-balanced amplifier
  • ThermalTrakā„¢ Output Transistors - for improved bias stability and enhanced low level linearity
  • Sentry Monitor fuse-less short circuit protection
  • Power Guard anti-clipping circuit
mxa60-backThe hybrid preamplifer sports tubes, input switching (both balanced and unbalanced inputs are accepted), tone controls, 24-bit, 192kHz sampling Burr Brown DACs, and more. The solid state input circuitry is designed to eliminate noise with the vacuum tubeassisted line stage provides that classic sound that McIntosh (and tube) lovers crave.
While the inclusion of MP3 support is probably more a nod to the times and the quickly diminishing ability of the public to recognize good sound, the real audiophiles are interested in both the redbook CD and SACD support. There is a tuner on board as well for terrestrial radio enjoyment.
When you flip the MXA60 around, you'll find two inputs (one balanced, one unbalanced), speaker terminals, remote power outputs (for turning on/off gear with the MXA60), and analogue RCA outputs. You can use only one of these outputs if you want to add a subwoofer to the included speakers. The speakers are rear ported with a bottom that is actually cut on an angle so that they speaker naturally points slightly up. McIntosh included a integrated stand so that the speaker could be leveled for a more standard orientation. The speakers have a 3/4" titamium dome driver and 4" woofers and boasts response down to 45hz (which would be very impressive indeed).
The strange thing about the MXA60 is that it includes the analogue RCA outs for use with an external amp. It seems to us that if you paid $7500 for an integrated McIntosh system that you'd want to use the fabled McIntosh amps. Plus, it would be sad if those little needles just sat there. We're pretty sure most McIntosh owners would consider that a mortal sin.
Recent Forum Posts:
Shock posts on January 07, 2010 18:23
Just got some nice red rep from someone who said, and I quote.
"not for us with money and smaller brains than U"
Well he was right about the smaller brain thing.
haraldo posts on January 07, 2010 03:17
Shock;670839
You guys are forgetting, it also comes with a free rectal exam, since you're going to need it after that price tag is done with you.
If I bought something like this my girlfriend would send me to a hospital where I would be treatet by doctors wearing white jackets.
Buying a system that's so absolutely not future proof would be quite crazy
Shock posts on January 06, 2010 14:07
WmAx posts on January 06, 2010 05:25
Hahaha. For this many $$, you can buy a great condition used pair of B&W 802N, or even 802D for not much more used, if you look around for a while.
-Chris
haraldo posts on January 06, 2010 04:11
So these are probably something like $1500... plus $6000 for the design... That I think is horrible anyways
I don't know why there's a CD player, have they not heard about music servers?
Where is the digital input for those with modern equipment?
I never used a CD player after I switched to the Squeezebox and I would never go back, cannot imagine in my wildest fantasies why anyone would buy sth like this with a CD player
And wow.... FM and AM radio, geeeeeeez
