You are here: Home Pro Reviews Speakers Lifestyle, Desktop and Portable Eos Wireless Multi-Room Speakers Review
by Aaron Howard last modified September 02, 2008
EOS Wireless Speakers
  • Product Name: Eos Wireless Multi-room Speakers
  • Manufacturer: IntelliTouch
  • Review Date: August 28, 2008 07:55
  • MSRP: $ 249.95
Specifications
Type: 2.1 X 4 speaker system
Colors: White, Black
Inputs: iPod Dock and (1) auxiliary input
Power:  15 VDC 1.3A (via included AC wall transformer)
Dimensions (Base): 9.75"w 8.25"h 6.75"d
Dimensions (Satellite): 5.75"w 9"h 5"d
Sound: 48 KHz
Broadcast Frequency: frequency hopping spread spectrum technology @ 2.4 GHz
Warranty: One (1) year
Weight (Base): 5 lbs
Weight (Satellite): 3 lbs
Included cables: three ft. 3.5mm, six ft. power cord (base), 2'10" power cord (satellite)
  • Rich, full sound
  • Ease of use
  • Nice design
  • iPod and Auxiliary input
  • No main volume or on/off control
  • Weak Bass
  • No EQ control
  • Finicky remote control
Introduction
The Eos Digital Wireless Multi-Room Audio System stands for simplicity and reliability at a cheaper cost. IntelliTouch wants to offer consumers a product that is easy on the wallet and easy to set up. The Eos Wireless System is the product they believe will fulfill all of those goals. Of course you can find a bigger, better, more expensive hamburger and of course there may be bigger, fancier sound systems out there, but for the cost and consistency, IntelliTouch does not want to be beat.
Recent Forum Posts:
Clint DeBoer posts on August 28, 2008 14:48
Sonos has a lot more flexibility and options, but for $249 it's hard to beat a two speaker wireless system.
