You are here: Home Pro Reviews Speakers Lifestyle, Desktop and Portable EGO Waterproof Sound Case for iPods
by Tony Leotta last modified March 20, 2007
  • Product Name: EGO Waterproof Sound Case
  • Manufacturer: Atlantic Inc.
  • Value Rating: StarStarStarhalf-star
  • Review Date: March 12, 2007 23:15
  • MSRP: $ 149.99
Specifications
Amplifier output: 3W x 2 (RMS)
Frequency range: 50- 20,000Hz
Power supply: 4 x AA (LR6) Blue LED power indicator, auto shut-down after 2.5 minutes without audio signal
Speaker unit: Custom designed waterproof speakers with 45mm neodymium drivers
Dimensions: 9.8”(24.9 cm) L x 1.8”(4.6 cm)W x 6.5”(16.5 cm) H
Weight: 2.05lb / 0.93kg
Playtime: Over 30 hours at medium to high volume (Alkaline & most rechargeable batteries)
  • Waterproof
  • Rugged Design
  • Sealed waterproof clickwheel membrane allows operation of iPod when unit is closed
  • Sound quality
  • Price
  • Will not work with 1st, 2nd, or 3rd generation iPods
  • Only comes in clear
Introduction
I first encountered the EGO Waterproof Sound Case at CES in Las Vegas. I was actually trying to figure out where I was in the massive convention center when Ron Lien, the marketing manager of Atlantic asked if I would like to see their new products. The display that really caught my eye was an iPod speaker soundcase in a sealed bowl with water spraying over it.
Recent Forum Posts:
