You are here: Home Pro Reviews Speakers Headphones Ultrasone PROline 750 Headphones Review PROline 750 Overview and Build Quality
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Clint DeBoer last modified July 30, 2009
It was high time Audioholics picked up the ball and did some headphone reviews, so we contacted a few manufacturers and selected some products based on price and specifications that we thought would represent a more mainstream target for price-to-performance. Ultrasone's $399 PROline 750 headphones seemed to fit the bill and we quickly arranged for a pair to be sent to us.
Headphone Design & Build Quality
PROline-750-headphones.jpgThe Ultrasone PROline 750 headphones are a closed-back design. Closed headphones are modeled so that the music doesn't escape the headphone as with an open design, and is instead pumped directly into your ears. One advantage is that they also provide a level of noise attenuation from the outside ambience. In the case of the PROline 750's they reduce ambient noise enough to help isolate sound in loud environments (around 10dB or so). This is accomplished through having a tight seal around the entire ear with each headphone pad. The caliper pressure used was not uncomfortable, but I have to say, the experience of using closed headphones in general isn't for everyone and can be a bit disconcerting for the first few times. The velvet ear pads were easily removed with a simply twist and the inclusion of an extra set was a nice touch.
PROline-750_driver.jpgTaking a close look at the headphones with the ear pads removed reveals an off-center placement of the driver. This positioning is what, in part, makes up the S-Logic Natural Surround Sound system. The idea is that the sound will arrive at your ears in a method more consistent with external sound which interacts more with your ear's natural makeup. This is not a surround sound DSP system, mind you, but a method by which Ultrasone attempts to eliminate the "in your head" sound so often reproduced by headphones. The PROline 750s also have something called ULE technology which is comprised of MU Metal shielding in order to reduce magnetic field radiation caused when electrical signals are converted into acoustical energy. ULE is supposed to reduce 98% of that radiation compared to other headphones - something that professionals who are concerned with that sort of thing may wish to factor into their purchase.
The comfortable headband pad protects your head, while the nice velvet ear pads do well to make listening feel comfortable - even for extended listening sessions (though I never went over 2 hours at a time). The majority of the unit was made out of plastic, but it appeared durable and was nicely molded, so I really didn't see this as an issue. I would also not like to carry more metal on my head than necessary as weight lowers the comfort factor considerably - especially over time. The inclusion of a straight headphone cable as well as a coiled one (not to mention making them removable) was a nice touch and should be appreciated by those with special distance needs. Also, I suppose, those audiophiles who substitute the standard cables with cryogenically treated products coated with kosher chicken fat would be equally appreciative.
Packaging
The Ultrasone PROline 750 headphones arrived in a box which opened up in three directions from the center and contained the headphones, extra ear pads, the two headphone cables, a 1/4" TRS to 1/8" stereo mini adapter, bag, demo CD, and instruction manual. The packaging was nice (like something Apple Computer would come up with) and lent a feeling that they took great care in making sure that the ownership experience would be a pleasant one.
