You are here: Home Pro Reviews Speakers Floorstanding Westlake Audio BBSM-10VNF
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Tom Andry last modified January 07, 2009
  • Product Name: BBSM-10VNF
  • Manufacturer: Westlake Audio
  • Review Date: January 06, 2009 22:00
  • MSRP: $16,990/pair
Specifications
MODEL NUMBER: BBSM-10VNF WITH ADJUSTABLE ISOLATION BASE
TYPE: 3 WAY FLOOR STANDING SYSTEM
ENCLOSURE TYPE: BASS-REFLEX
DRIVERS: DUAL 10* WOOFERS & 6 1/2* MIDRANGE & 1 1/4* DOME TWEETER
TECHNICAL FEATURES: EXTENSIVE DYNAMIC ELECTRO-MECHANICAL-ACOUSTICAL DAMPENING, INTEGRATED ULTRA LOW DISTORTION, 109 PART PRECISION HIGH LEVEL PASSIVE CROSSOVER FOR SINGLE OR BI AMP OPERATION, HI & LOW FREQUENCY *P.E.* BUS
INPUTS: HEAVY DUTY TERMINAL STRIP
USER FEATURES: BI-WIRE OR PASSIVE BI-AMP CAPABILITY
ACCESSORIES SUPPLIED: INTEGRAL *MID & WOOFER MUFFS*
ACCESSORIES AVAILABLE AT ADDITIONAL COST: SPEAKER MUFFS, SUPERFLEX LOW *P.E. DISTORTION** SPEAKER CABLES
SPECIFICATIONS:
  • POWER HANDLING: 120W
  • FREQUENCY RESPONSE: 40-18K
  • IMPEDANCE: 4 OHMS NOMINAL 2 OHMS MINIMUM
  • SENSITIVITY: 95 DB @ 1M FOR 2.83V INPUT
  • COSMETIC FINISH: SATIN WALNUT VENEER
  • WARRANTY: 5 YEAR
  • DIMENSIONS: 46 X 14 1/2 X 19 1/2
  • WEIGHT: 198 LBS.
Executive Overview
foamlessThe Westlake Audio BBSM-10VNF is a floor standing version of the classic BBSM-10 monitor. The 3-way system uses dual 10" woofers, a 6 1/2" cone midrange and 1 1/4" soft dome tweeter in a ported enclosure. The frequency response is spec'ed at 40-18K which is surprisingly honest for a speaker at this price point. For that alone Westlake Audio has piqued our interest. Of course, all the foam stuff turned us off. Fortunately, it is optional. The North American Walnut cabinet features extensive internal bracing with proprietary sound dampening materials that virtually eliminate any cabinet distortions. All crossover components including hand wound coils; capacitors and resistors are matched within a 1% tolerance to ensure balanced response.
BBSM-10VNF Specs
  • 3-WAY Floor Standing System
  • Dual 10* Woofers, 6.5* Midrange, 1.25* Tweeter
  • Isolation Base with Integral Top Adjust Isolation (Preferred) or Spike Feet
  • Integral Woofer and Mid Muffs
  • Compact Speaker Muff
  • ISO Crossover Assembly with Integral Isolated L.F. & H.F. *P.E.* Buses
  • New Tweeter Mounting with Low *P.E.* Wiring
  • Low *P.E.* Distortion Driver Units
For more information, please visit www.westlakeaudio.com.
Recent Forum Posts:
irishtom posts on January 07, 2009 11:12
We talked about the foam over at the Lansing Heritage forum and some of us thought it was for dispersion control, some foams can act as a lens.
Back in the 70s and 80s EV used a foam lens that covered a large dome tweeter (Superdome) leaving a small hole in the center, it looked like a foam bagel. The lower frequencies from the dome passed through the foam but they higher frequencies came only through the small hole thus making for wider dispersion than a dome that size would normally have. This device allowed EV to use a larger than normal dome (and thus get higher output and a lower crossover than most domes) and still have wide dispersion.
The working of the lens is explained in this sheet from the EV archives.
http://archives.telex.com/archives/EV/Speakers/EDS/Interface%20C%20EDS.pdf [archives.telex.com]
