You are here: Home Pro Reviews Speakers Floorstanding THIEL Audio MCS1, SCS3 and SS2 Loudspeaker System Review MCS1, SCS3 and SS2 Speaker Design
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Ken Stein last modified January 14, 2007
The stands for the SCS3 surround speakers happened to be placed at ear level for the lower front seats. I set them up near the corners at the back of the room and towed them slightly inwards. clip_image002_021.jpg
Another commendable design concept from THIEL Audio was the implementation of large radius curves located on the front baffels of the MCS1s and the SCS3s. I once read in one of my speaker design books that small radius curves on a front baffle has insignificant impact to the tonal quality of the speaker however a large radius of about 4 inches can actually help reduce the diffraction from the edge of the cabinets for mid and high frequencies. THIEL Audio has been applying this design concept to their designs at least as long as I have known about the company. Since the MCS1 is a MTM (midrange-tweeter-midrange) design it is quite difficult to keep a large radius curve on the front. To solve this physical limitation, THIEL created moon shaped sides resulting in a larger radius near the drivers along with a 3-inch thick front baffle.
The thick front baffle combined with 1 inch thick side and back panels and excellent shelf-type bracing all made from MDF (medium density fiberboard) make this cabinet solid and formidable.
Giving the speaker a simple but revealing knuckle revealed that none of the panels showed signs of drumming or vibration. Having no cabinet vibration is crucial as to not color the sound during playback and THIEL seems to have taken care of this problem quite well.clip_image004_025.jpg
The mid/tweeter chamber was completely sealed although I could not see what material was used for this sub-enclosure. We had several technical questions which we posed to Jim Thiel including this about the sub-enclosure:
"The walls of the mid/tweeter's sub-enclosure are made of a round tube of compressed paper that is a little more than a quarter inch thick. The round cross sectional shape gives this enclosure very high strength and non-resonant behavior."
One setup tip we learned was that THIEL recommends leaving the large allen head mounting screws installed if the MCS1s are not mounted to their stands since the threaded holes go all the way through the cabinet. If the four holes are left open then, the back pressure from the woofers will travel through these holes which may result in whistling noises.
There are only a few companies that I'm aware of that go the extra mile when it comes to mounting the drivers, and THIEL has been inaugurated as one of them. Unlike the mainstream wood screws in MDF, all of THIEL's drivers were mounted with machine threaded screws into metal threaded inserts. Most folks who do not review or dissect speakers will likely not notice this feature. My opinion is that the benefits of using threaded inserts exceed the extra manufacturing costs as it ensures the best possible rigid mounting of the driver to the cabinet. Plus, as someone who loves to dissect speakers, I found that the allen head screws helped reduce slippage when tightening or loosening them. I tend to be very cautious when using a phillips head since I always feel that I'm going to slip and go right through the cone. Thus we don't recommend doing this at home. As an added bonus, the screws were all gold plated. But when removing the grills, I thought the gold screws created too many different colors on the baffle. However, the gold screws do reveal a behind the scenes peak at how THIEL Audio paid attention to every detail.
One surprise we noticed during our investigation was that there was no damping material on the side walls of the cabinet and no gasket was used under the drivers to seal them. The only other cabinet we've seen that didn't have these features included the Canton Karat Reference 2 DC speakers which we reviewed several months earlier.
I found it peculiar how THIEL Audio recessed the drivers. The mid/tweeter driver had a conical shape to the frame as opposed to a more common flat shape. It was recessed about 3/4 of an inch with the cabinet continuing the same slope as the driver. I thought that the purpose of this was to line up the voice coil to the woofers so that the time coherence was maintained. I quickly noticed that the woofer was also recessed about 3/4 of an inch which seemed to misalign the voice coil thereby seemingly negating the time coherence. We asked Jim Thiel the reasoning behind such a design and he responded with the following memo.
“You are perfectly correct that "the recessing of the tweeter is to line up the voice coils for the purpose of time alignment". You are also correct that if we did not recess the tweeter there would be a little bit of diffraction eliminated. And, further, you are also correct in noting that if we did not recess the woofers we would not need to recess the tweeter to achieve alignment. With most drivers this would not be true. It would usually be that if none of the drivers were recessed they would be far from time-aligned because the woofer's coil would normally be much farther behind the baffle than the tweeter's. Why it is true with the MCS1 is because both the woofer and tweeter are unusual in their geometry. The tweeter has a built-in recess from the geometry of its chassis that places the midrange cone rim behind the baffle surface and the woofer has an extremely shallow diaphragm geometry that is made possible by the use of a thick, cast polystyrene foam layer laminated behind the aluminum layer of the diaphragm to obtain the required strength and stiffness. So, why did we not utilize these features as sufficient to achieve correct time-alignment and mount the drivers without any recess? Good question! The answer is that the woofer would actually not have its minimum diffraction mounted flush with the baffle.
This is because the surround itself is usually a source of significant diffraction because it protrudes in front of both the diaphragm rim and the baffle. What we have done instead is to design the two-layer diaphragm with enough thickness at its rim so that, by mounting the surround from behind the diaphragm, the surround's roll creates a (relatively) smooth continuation of the diaphragm's shape, rather than an abrupt protrusion.
To complete the desirable situation of a smooth shape from diaphragm to surround roll and on to the baffle, we have recessed the driver chassis enough so that, with the use of the ring, there is no significant, abrupt change from the surround roll to the baffle. So all this was done to reduce diffraction from the woofers' surrounds, with considerable measured success. Now, it is true, as you say, that this woofer diaphragm / surround design and driver mounting requires that we recess the tweeter. But the extra recess is only about 1/4 inch and by being very careful with the shape of the recess there is very little added diffraction from the tweeter. You notice that the recess does not continue from the tweeter chassis's edge but rather has a different size and shape that was found to produce less diffraction.”
In summary, it seemed that Jim Thiel indicated that the woofer was first recessed and then a ring was mounted to the top of the driver's frame so that any diffraction from the driver piston to the surround material can be properly eliminated. In other words the ring keeps a smooth transition from the cone to the extent of the front baffle. The woofers has a shallow cone which allows for a low mass piston but materials are added to stiffen the cone to make it more rigid. The shallow cone allows its voice coil to be more forward than most woofers. Now, the conical shape of the mid/tweeter frame itself causes the voice coil to be farther back than a tweeter with a flat frame which allows alignment of the mid/tweeter and woofer voice coils. This shape is merged with the front baffle so that there are no abrupt changes in the surface from the actual moving piston to the extent of the baffle, just like the woofers.
So the recessing is to eliminate diffraction and the shapes of the drivers allow time alignment. Mr. Thiel pointed me to their that one of their technical white papers explains this concept in more detail.
One of the most unique things I've seen with their speakers is Jim Thiel's design of the coaxial driver. As shown below there is a dome tweeter and a cone midrange that share one voice coil with some material used to couple the two together. The purpose is to have time coherence between the mid and high frequencies by eliminating the phase problems exhibited by an electronic crossover circuit. It seems that there would be some lag caused by the coupling suspension.
Pictorial representation of the THIEL Coaxial Driver
Think of holding a spring with a weight on the other end. As you move your hand up and down slowly the weight moves along with your hand at the same speed but as you increase the speed of your hand motion the motion of the weight can't keep up with the motion of your hand because of its mass; the weight lags the motion of your hand. The same theory seems to apply here, the dome should have less mass than the cone portion and the so called spring is the coupling suspension; therefore the midrange cone would seem to lag the movement of the tweeter dome. According to Thiel, there isn't any lag, and here is his commentary on this topic:
“There is no time lag between the mid and tweeter since they are driven by the same voice coil.
There is phase shift but this is opposite for the two diaphragms and cancel out in the speaker's total output. This is also how a first order crossover works; there is phase shift but it is equal and opposite and less than 180 degrees and so can be made to perfectly cancel in the acoustic output.”
We also asked how the crossover occurs between the dome and the cone of this driver and this is what Thiel had to say:
“How the mechanical crossover works is that the coupling suspension's stiffness is high enough so that at low frequencies the two diaphragms move together as one unit. So the tweeter diaphragm is contributing to the low frequency output but at a much reduced level. At high frequencies the coupling's compliance allows the midrange diaphragm to "decouple" from the voice coil because high frequency force cannot be conducted through this compliance to the relatively heavier midrange moving system. So at these high frequencies the tweeter diaphragm is the only one driven by the voice coil, since it is directly connected.”
This explanation is a much better answer for both the time lag and crossover questions. It seems Mr. Thiel is saying that at the lower frequencies (slower speeds) the dome has such a low output you can't hear it but at the higher frequencies (faster speeds) the coupling suspension (spring) does not allow these frequencies through so the cone would not lag nor play the higher frequencies hence there is a mechanical crossover.
The SS2 subwoofer didn't raise nearly as many questions since it had a more traditional truncated cast frame and an aluminum cone with rubber surround. I also found the crossover quite interesting since all of the components were wired by their leads. In other words there was no printed circuit board and no wires connecting component to component thereby minimizing connection paths. All internal wiring used 18 AWG solid twisted pair. THIEL's logic behind the Speaker Wire can be found in our FAQ with Jim Thiel which is included at on Page 8 of this article.
Notice the cast baskets and large motor structures of the drivers.
Notice the quality air core inductors, polypropylene capacitors and ceramic resistors.
