RBH TK-5CT Set-up and Listening Tests
Attaching the bases took little time and a small
wrench made short work of the carpet spikes. With my carpet, I decided to just
set the speakers up on their bases without attaching the spikes while
determining the proper placement. Even though we here at Audioholics don’t
recognize speaker “break-in” as a real physical phenomenon, we understand that
many people do. More to the point, “ear” break in is a very real phenomenon and
“encouraging” people listen to their speakers for a number of hours isn’t such
a bad plan. Most companies like to quote 40-60 hours while RBH suggests only
10-15. I interpret this in one of two ways: 1) RBH doesn’t really buy into the
whole “break-in” but has to put it in there because many of their customers expect
it or 2) they DO believe in break-in but they believe that their speakers are
of such high quality that they don’t need that much. Either way, RBH is at
least getting closer to the Audioholics recommended break-in time of 2 minutes than
any other manufacturer I’ve come across – and that should be commended.
The side
firing woofer really needs a little room to breath so I suggest you point it
out rather than in. If you’ve got furniture that the speakers are flanking then
this is imperative but even for your dedicated home theaters with projection
screens and no furniture up front, then having the woofers pointed at each
other can cause some cancellation effects (two drivers firing in phase can do
that). You’d risk negating some of that bass that you paid good money for.
Also, the speakers are rear ported so you’ll want to give a little room behind
the speaker to let it breathe. Even at high volumes I never had any problems
with port noise.
I experimented a lot with toe in and was amazed at
the results. In no position did the TK-5CT’s sound bad. Imaging was good
whether the speakers were pointed straight forward or directly at me. But, of
course, that isn’t all that amazing; lots of speakers can claim that. What WAS
amazing however was the difference I experienced when the speakers were pointed
directly at me versus any other position. In this configuration I experienced a
significant increase in the clarity and presence of the music WITHOUT any
deleterious effects that normally come with on axis listening. So many times in
the past I’ve reviewed speakers that sound great off axis (pointed away from
me) but when I point them directly at me they become bright and fatiguing. Not
so with the TK-5CT’s. Much like an electrostat, I
found that having the speakers pointed directly at me gave me a very small but
very clear sweet spot. However, unlike electrostats, having them toed out a bit
didn’t destroy the soundstage as much as it just widened and diffused it. In my
opinion, for critical listening by yourself, pointing the speakers directly at
you will increase your enjoyment but in a group (or for non-critical listening)
you’ll find that the TK-5CT’s perform far above average if you point them
straight out or with a slight toe in. This makes for a very versatile speaker.
Listening Tests
Floorstanding
speakers have gotten, to a certain extent, a bad rap. So many times you come
across people that have “towers” that won’t go low enough to really be
considered “full range.” For the uninitiated, this means that they’ve set their
receiver for “large” or just forgone the purchase of the subwoofer thinking
that they don’t need it. More often than not, this is a grave mistake. It is
always with a bit a trepidation that I throw in a test disc and examine the
“useable” bass of a tower as I’m often forced to report that they should be set
to “small” and that you’ll still need to fork over cash for a sub. For the
first time, I don’t have to say that. At $800 a pair, I can’t believe I’m about
to say that I heard real useable bass as low as 25Hz and strong output from
31.5Hz and up! Now that all of you are back from checking the specs on the
introductory page, yes, RBH rates them down to 45Hz. The speakers were placed
at least 2 ½ feet from the side walls and 2 feet from the back so NO I didn’t
corner load them to get this result. Obviously the room is playing a factor
here and I can’t guarantee that you’ll have the same results but in my room, I
can EASILY go without a sub for 99% of the music out there. Of course, I still
want a sub for movies but if you have the option of sending just the LFE of the
mains to the sub (essentially running them as “large”) then you can safely do
that. It may even help smooth out the bass response in your room.
CD: Yello – the eye
While I usually just pop in this album for a few
seconds to check out the imaging of the speakers in question, I ended up
spending a lot more time than I normally would. My reference speakers, not so
long ago, were right in the price range (without the upgraded finish) of the
TK-5CT’s and have long been considered a performance leader in this price
bracket. This seemed to be a very good comparison set and I wanted to do it
justice. Imaging by both speakers was very good with a slight edge given to the
TK-5CT’s. And by slight I mean ever so
slight. It was a close match. The separation seemed a little clearer, the
soundstage a little larger, and overall the imaging was more 3-D than my
reference speakers. I spent a lot of time switching back and forth in order to
come to this conclusion so you know it was a close race. With the TK’s pointed
directly at me, the imaging tightened up even more and became more present
handedly beating my reference set which became fatiguing in the same
configuration.
CD: Bang & Olufsen Vol. XIII – The Sound of Perfection
Listening to Track 1 and Track 4, the most noticeable difference between the TKs and my reference speakers was the bass. Out of all the comparisons I did, the difference in the bass was the most noticeable. Tighter, cleaner, deeper and more lifelike all describes the TK-5CTs. The clarity in the lows and lower midrange was significantly better than what I was used too. I was quickly convinced that not only was I standing in the presence of full range speakers, but I was standing in the presence of full range speakers for $800! I still think that price is somehow wrong and that when the accounting department over at RBH gets wind of it, there’s going to be hell to pay. For someone that is used to working with a sub (even one as capable as the Axiom EP500), running full range speakers takes a little getting used to. You don’t have to worry about crossovers, placement, or any of that. You just plug in the speakers and walk away. There is something about that lack of action that I find strangely comfortable. I also think that running the speakers full range added a dimension to the music that a sub just doesn’t seem to provide. Not that a sub can’t provide it but it takes a lot of sub (or perhaps lots of subs) to provide the deep impact for movies while remaining clean and tight up near the crossover point. The TK-5CT’s won’t give you that gut shaking bass during explosions but it will give you bass deep enough for most music at insane listening levels.
Using the
Emotiva Reference Audio Series RSP-1 and RPA-1 along with the Denon 3910, I
pushed the TK-5CT’s as hard as I dared. I was amazed
to find that the top end of the speakers seemed to have no limit (yes, I know
they have a limit but this is a subjective listening test). When the tweeter on
my reference speakers began to break up and distort, the RBH tweeter held firm
and kept its composure. The highs of cymbals, strings, and snare drums stayed
crisp, clean and lifelike at volumes I thought impossible. Overall, I found
there to be a very airy and lifelike quality to the highs. Sounds seemed to
float and hover all around me. Just when I thought one more decibel or one more
hertz would push the TK’s past their limits, they would take all that and more.
For $800, these are some pretty amazing speakers.
Recent Forum Posts:
I found a pair of the RBH-TK-5CTs on eBay. I am familiar with the RBH speakers, but not the TK line. After reading the review and posts I went ahead and bought the TK-5CTs. Yes, the finish is cheesy up close; however the speakers look nice unless you are examining them closely, and they have a good WF.
For the first time I am getting a great sound stake, imaging, and harmonious bass out of this corner. If you have a corner entertainment center that is a real challenge for music, look at the RGH tower speakers.
As for what's going to replace it in the RBH line????
WHAAT?! Say it ain't so!
What are they planning to bring to the market that will be SUPERIOR to the TK series as well as cheaper?
Also is there any wall mounts that work with the TK‑5Cs?
So far I have been impressed with the sound on this $900 package !
