You are here: Home Pro Reviews Speakers Floorstanding RBH Sound T-2 Signature Series System Review
by Gene DellaSala last modified February 17, 2007
  • Product Name: RBH Sound T-2 Signature Series
  • Manufacturer: RBH Sound
  • Performance Rating: StarStarStarStarStar
  • Review Date: January 31, 2004 19:00
  • MSRP: $ 7499 (black) $9499 (veneer)
Specifications
Technical specs (T-2 N&P)
System Type: Modular Tower
Frequency Response: 20Hz - 20kHz±3dB
Sensitivity: 90dB (2.83V @ 1 Meter)
Power Handling: 500 Watts
Drive Units: (2) 10" Aluminum Woofer
                    (4) 6 1/2" Aluminum Woofer
                    (3) 1" Silk Dome Tweeter
Tweeter Protection: No
Crossover Frequency: 2500Hz
Crossover: 24dB/Octave
Impedance: 4 Ohms
Cabinet Material: Medium Density
Fiberboard (MDF)
Cabinet Finish: Black Oak Woodgrain
with NevamarT tops and bases,
or  30 different real hardwood finishes
Dimensions: 61 1/4""H x 13 1/4"W x 18"D
Weight: 190 lbs.
(2) SA-400 400wpc Subwoofer Amplifiers
MSRP: $7499pr (black) / $9299pr (veneer)
http://www.rbhsound.com
  • Unsurpassed Dynamic Range
  • Gigantic Soundstage
  • Excellent Imaging Over a Large
  • Listening
  • Window
  • Unbelievable Sound and Value
  • Gargantuan Size and Weight
  • Difficult to Set-Up Properly
  • No Sub EQ or Variable Phase
  • Control
  • Low WAF
Introduction
RBH Sound has been manufacturing high performance loudspeakers for over 25 years catering to the high performance (mind you not necessarily high priced) and custom install marketplaces. Yet their name isn't as widely recognized by consumers like some of the big guys out there. Fortunately name recognition is not always a reflection of product quality or performance. I can't think of a better example than this particular loudspeaker manufacturer.
