You are here: Home Pro Reviews Speakers Floorstanding PSB Alpha Loudspeaker System Review PSB Alpha System Conclusion
by ken last modified December 07, 2006
It may be hard to tell from some of my comments whether I think that the PSB Alpha's are good or not, so let me clear the air and say that they are great speakers for a system price of $2205. I will say that I don't believe that these speakers are suited for a room such as mine. I have a good sized room (22.5' x 17' x 10' ) and the Alpha's just do not have the dynamics to fill the space. I found some physical shortcomings but I don't think that they really have an impact on the overall sound and performance. While the subs do not have a great low-end extension I think they would have plenty of impact in a smaller room than mine and they would perform without distortion. After quite a few hours of listening I never found the system to be fatiguing. There are a lot of pluses and this was a great performance for an entry level speaker system which would provide years of service. I suggest that if this is the budget that you are looking for that you definitely consider the PSB Alphas.
  • StarStarStar — Good
  • StarStar — Fair
  • Star — Poor
MetricRating
Build QualityStarStarStar
AppearanceStarStarStar
Treble ExtensionStarStarStar
Treble SmoothnessStarStarStar
Midrange AccuracyStarStarStarStar
Bass ExtensionStarStarStar
Bass AccuracyStarStarStar
ImagingStarStarStarStar
SoundstageStarStarStarStar
Dynamic RangeStarStarStar
PerformanceStarStarStarhalf-star
ValueStarStarStarStar
