Paradigm S6 - Listening Evaluation and Conclusion
After setting up the speakers and getting them calibrated, it was time for some serious listening tests. I would love to say that I had some reference speaker on par with the Paradigm S6's to use as a comparison but I don't. The RBH TK-5CT's are a great floorstanding speaker for the price ($850/pair) that seriously put to shame anything even near its price category in my opinion but no one could expect them to hold up to the Paradigm's at over 5x's the price. Of course I did do a quick comparison. While listening to the RBH's I was thoroughly enjoying the listening experience. It was lively and detailed. Fun and engaging. When I switched to the Signature 6's, it was like sensory overload. There was so much more information there, the sound was so much bigger, I seemed almost taken aback. At first I thought I didn't like the S6's as much until I let my ears get used to hearing them. When I switched back to the TK-5CT's it was like going from a full orchestra to a quartet - sure the music was still there, it just wasn't as much, as full, or as impressive. After a few minutes with the TK's, I started liking them again but it was obvious that they were outclassed by the exponentially more expensive S6's. And that's the last I'll say about that comparison.
One problem I did have was the height of the speaker. The tweeter was so high that I would literally have to sit on something (I felt like a kid sitting on a phone book at the dinner table) to get my ears to tweeter height. At 42 inches, the tweeter is 2 1/2 inches than the RBH's which I think are a bit too high. While they could have compensated for the tweeter height by making it a bit hotter, the recommendations in the manual were to place your ears at tweeter height so it seems unlikely. This is something that you'll need to think about before you purchase. All listening tests were done with the grill on (as per Paradigm's recommendation) and the speakers run range.
CD: Yello
– the eye
I start nearly every
speaker review with this CD. There is just so much information there that I can
quickly get a handle on how a speaker performs on a number of different metrics
all at the same time. Bass, imaging, female vocals, response time… it's all at
my fingertips. No matter what position I had the speakers in imaging was quite
tight and controlled. Instruments were well placed in the soundstage and I had
little problems locating each of the sound effects as they moved around. There
are a few tracks that play with phase and can, with the right speaker, give the
illusion that there is sound coming from behind you. The Signature 6's did an
admirable job of this though they weren't up to the level of the $20k
Innersound Kaya Reference electrostats I've heard with the same album. Then
again, you could move your head and still have the same effect which the
electrostats couldn't provide. Compared to other non-electrostatic speakers,
imaging was some of the best I've heard and beyond a doubt the best I've heard
in my room. I can't imagine that someone wouldn't be impressed by the imaging
of these speakers. Phenomenal.
CD: Morcheeba
- Charango
Morcheeba's smooth
vocals and driving beats makes this an easy target for review material. The
fact that I can listen to it with a house full of people and have everyone
enjoy it as well is a huge plus. I put in this CD thinking that I would be
listening for bass especially the kick drum and bass guitar. While these were
particularly well represented, I found myself more caught up in the vocals and
some of the background effects. The softness of Morcheeba's voice was
excellently contrasted with the cymbals and background effects which were often
in the upper register. Again imaging was rock solid and even though I knew I
was listening to a two channel setup, I couldn't help but think that the center
channel was somehow engaged. That's how solid the image was.
But let's not forget the bass. Kicking is a word. Clear, articulate, and punchy are a few others. The S6's had no problem filling my room, the room next to it, the kitchen… ok you get the idea. I could pump a lot of power into these speakers without feeling like I was reaching the limits. Let's put it this way, the S6's could easily turn my couch into a shiatsu massage chair with the right amp. And believe me, the RPA-1 is the right amp! I was constantly amazed at the amount of bass I was hearing even at low volumes. It seemed to fill the room and surround me even at low listening levels. The only problem was that the tweeters did start to get a bit fatiguing at higher volumes (we're talking 100dB+ high) not that I would ever recommend people listening at that high volume for any length of time.
CD: Bang &
Olufsen Vol. XIII – The Sound of Perfection
I love to use this
album for reviews because it has a variety of material (like Yello) and it is
easy to listen to (unlike Yello) for the most part. There is way too much
classical on it for me but overall it makes for a good time. If there was a
chink in the armor of the S6's, it was the decision to mount the drivers on the
front baffle. This can lead to diffraction issues. For the most part I didn't
notice any problems but occasionally (and mostly during my time with this album
and at higher volumes) I could. With a lot of midrange and upper bass
information playing at the same time, the distinction between instruments
became muddied and unfocused. It wasn't a completely unpleasant experience but
compared to the performance of the speakers on other metrics it was a bit
jarring. It's like being totally engrossed in a movie and having someone from
the row behind you tap you on the shoulder to ask you the time.
This isn't to say that it was all (or even partially) bad. The midrange and upper bass were so much fuller and richer than anything I've ever heard in my room that it took me a long while just to get used to it. The Signature 6's are in a class above most everything else in my experience that I felt like a noob for about an hour. They seem to be more forgiving of bad material while still presenting you with the full musical experience. I've heard more detailed speakers in the past (remember, I'm sitting below the tweeter level so this may play a part) but usually at the expense of sounding antiseptic. The Paradigm S6's are anything but antiseptic especially at normal listening volumes. They struck me as warm and laid back. Once I started pushing them they got more forward but that is to be expected. The bass has great extension and sounded much more even in my room than I've heard before especially considering that I wasn't using a subwoofer or any sort of active EQ.
There is also a section on a track that uses a lot of notes from the very top end of a piano. I've used this section before to test not only extension but also how lifelike those notes sound. If you've ever tapped out chopsticks on the high end of a piano you know the sound. It is airy and tense. You can almost hear the felt mute the string as it strikes it. The S6's presented these notes in the most lifelike way I've ever heard - bar none. It was as if I were playing the piano. And all the while they still managed to shake my couch with bass. It was an amazing experience.
CD: Various - Jazz
at the Pawnshop
This album isn't for
everyone and honestly I have to be in the right mood for it. Coming from a jazz
background, I find it has a certain kind of nostalgia for me. Pawnshop is a great CD for checking out
how well a speaker presents a really well defined rendition of particular
instruments and how dynamic it is. The music can quickly travel from near dead
silent to a screeching sax in a millisecond. All the while there is a bunch of
background noise (cups rattling, people talking, that sort of thing), a slow
standup bass guitar, and a xylophone. Talk about difficult material! The
Paradigm S6's had absolutely no problem responding to the dynamic range
material and never so much as stumbled during my listening sessions. The only
problem that I noted was that occasionally an upper note of a clarinet or sax
would get away from tweeter and seem to take on a life of its own becoming a
bit more harsh than it should be. Otherwise, I perfect rendition of this well
recorded and excellently performed album.
One approaches a speaker of this
caliber with a sort of reverence. You don't play music through them; you allow them to recreate
the music for you. The Signature 6's are an expensive speaker, but for that
you get fantastic build quality, great sonics, and aesthetics to die for. The
Paradigm S6's present a laid back but full soundstage that is both wide and
deep. Bassy, full, with a detailed high end, the S6's aren't the perfect
speaker, but they may be right for you. Take a listen and find out.
Paradigm S6
$4599-$4999
Paradigm Electronics Inc.
11 - 919 Fraser Dr.
Burlington, ON L7L 4X8
Canada
www.paradigm.com
About Paradigm Electronics Inc.
Innovative design, advanced materials, in-house manufacturing, and
state-of-the-art engineering have made Paradigm an international leader in
speaker design. With more than 250 industry awards for audio excellence and
numerous rave reviews from around the world, Paradigm is committed to being at
the leading edge of speaker technology and consistently achieving the ultimate
in sound for music and home theater.
— Excellent
— Very Good
— Good
— Fair
— Poor
| Metric | Rating |
| Build Quality | ![]() ![]() ![]() ![]() ![]() |
| Appearance | ![]() ![]() ![]() ![]() ![]() |
| Treble Extension | ![]() ![]() ![]() ![]() |
| Treble Smoothness | ![]() ![]() ![]() ![]() |
| Midrange Accuracy | ![]() ![]() ![]() ![]() |
| Bass Extension | ![]() ![]() ![]() ![]() ![]() |
| Bass Accuracy | ![]() ![]() ![]() ![]() |
| Imaging | ![]() ![]() ![]() ![]() ![]() |
| Soundstage | ![]() ![]() ![]() ![]() ![]() |
| Dynamic Range | ![]() ![]() ![]() ![]() |
| Fit and Finish | ![]() ![]() ![]() ![]() ![]() |
| Performance | ![]() ![]() ![]() ![]() ![]() |
| Value | ![]() ![]() ![]() |
Recent Forum Posts:
Regards, Billy P
http://www.psbspeakers.com/reviews/GS-Review-Alpha-B1 [psbspeakers.com]
Want to thank Billy P for pointing me in the right direction.
No problem, no harm done, maybe egos bruised...
Guangui;362106
Patrick, thanks, it is good to know that you can take some "fire", and still keep a cool head.
Billy, you are right, I didn't read complete, was waiting to do that when I had more time. Those things happen, what I cannot understand is that "I'm bigger that everyone else" attitude..." I ceratinly wasn't going to link it for him." You showed your true colors with that comment.
Sorry Guangui but I am the same guy whom you directed this comment to the other day? Most mfg's list all professional reviews(positive ones anyways ) on their homepage and are easy to find.
Regards, Billy P
PatrickBateman;362080
I think I worded my thoughts incorrectly, at least my head knew what I was trying to say.
Anyway Guangui I believe this may be the review you were referring too.
http://www.soundstage.com/revequip/psb_alpha_b1.htm [soundstage.com]
That would be the review. I bet I took you all but 5 minutes if you go to the PSB homepage and look under reviews. I ceratinly wasn't going to link it for him.
