You are here: Home Pro Reviews Speakers Floorstanding Paradigm S6 v2 Floorstanding Loudspeaker Review
by Tom Andry last modified January 01, 2008
Paradigm S6 v2
Paradigm S6 v2
  • Product Name: S6 v2
  • Manufacturer: Paradigm
  • Value Rating: StarStarStar
  • Review Date: December 31, 2007 19:10
  • MSRP: $ 4499 (as tested $4999)
Specifications
Design: 4-driver, 3-way floorstanding, MagneShield™
Crossover(s): 3rd-order electro-acoustic at 1.9 kHz, 2nd-order electro-acoustic at 350 Hz (lower bass driver)
High-Frequency Driver(s): 25-mm (1 in) P-Be™ pure-beryllium dome, rear damping chamber with ARB™ aperiodic resonance breakup fins and integrated heatsink, dual super neodymium magnets, die-cast heatsink chassis, ferro-fluid cooled, IMS / SHOCK-MOUNT™
Midrange Driver(s): 178-mm (7 in) Co-PAL™ cobalt-infused pure-aluminum cone, solid aluminum phase plug, dual-layer 25-mm (1 in) rigid, low-mass voice coils, ATC™ asymmetric tapered dual-channel die-cast aluminum chamber, massive ceramic / ferrite magnets, super neodymium magnets, ferro-fluid cooled, AVS™ die-cast heatsink chassis, IMS / SHOCK-MOUNT™
Bass Driver(s): Two 178-mm (7 in) mineral-filled polypropylene cones, dual-layer 38-mm (1-1/2 in) rigid, low-mass voice coils, AVS™ die-cast heatsink chassis, massive ceramic / ferrite magnets, IMS / SHOCK-MOUNT™
Low-Frequency Extension: 28 Hz (DIN)
On-Axis Frequency Response: ±2 dB from 50 Hz - 45 kHz
30° Off-Axis Frequency Response: ±2 dB from 50 Hz - 20 kHz
Sensitivity - Room / Anechoic: 91 dB / 88 dB
Power Range: 15 - 400 watts
Maximum Input Power: 200 watts
Impedance: Compatible with 8 ohms
Internal Volume: 47.1 L / 1.66 cu ft
Height, Width, Depth (Height includes spikes or outrigger feet): 111.0 cm x 21.0 cm x 34.5 cm (43-11/16 in x 8-1/4 in x 13-9/16 in)
Weight: 63.5 kg / 140 lb per pair
Finishes: Cherry, Natural Birdseye Maple, Piano Black
  • Huge soundstage
  • Full midrange
  • Beautiful finish
  • Fantastic imaging
  • Tweeter looses some control at extreme volumes
  • Carpet spikes nearly impossible to adjust
  • Midrange/upper bass became muddled at times
  • Costly
Introduction
Some speaker companies need no introduction. There are few names that are as associated with speakers as Paradigm. One approaches a speaker of this caliber with a sort of reverence. You don't play music through them; you allow them to recreate the music for you. The Signature 6's are an expensive speaker, but for that you get fantastic build quality, great sonics, and aesthetics to die for. The Paradigm S6's present a laid back but full soundstage that is both wide and deep. Bassy, full, with a detailed high end, the S6's aren't the perfect speaker, but they may be right for you.
Recent Forum Posts:
Guangui posts on January 22, 2008 11:14
Sorry Guangui but I am the same guy whom you directed this comment to the other day? Most mfg's list all professional reviews(positive ones anyways ) on their homepage and are easy to find.
Regards, Billy P
http://www.psbspeakers.com/reviews/GS-Review-Alpha-B1 [psbspeakers.com]
Want to thank Billy P for pointing me in the right direction.
No problem, no harm done, maybe egos bruised...
billy p posts on January 22, 2008 10:29
Guangui;362106
Patrick, thanks, it is good to know that you can take some "fire", and still keep a cool head.
Billy, you are right, I didn't read complete, was waiting to do that when I had more time. Those things happen, what I cannot understand is that "I'm bigger that everyone else" attitude..." I ceratinly wasn't going to link it for him." You showed your true colors with that comment.
Regards, Billy P
Guangui posts on January 22, 2008 08:44
PatrickBateman;362080
I think I worded my thoughts incorrectly, at least my head knew what I was trying to say.
Anyway Guangui I believe this may be the review you were referring too.
http://www.soundstage.com/revequip/psb_alpha_b1.htm [soundstage.com]
billy p posts on January 22, 2008 08:28
That would be the review. I bet I took you all but 5 minutes if you go to the PSB homepage and look under reviews. I ceratinly wasn't going to link it for him.
PatrickBateman posts on January 22, 2008 07:30
