Mirage Omnisat v2 FS Loudspeaker Review
by mark last modified October 29, 2005
  • Product Name: Mirage Omnisat v2 FS Loudspeaker
  • Manufacturer: Mirage
  • Review Date: October 29, 2005 20:00
  • MSRP: $ 1000/pair
Specifications
Sensitivity (2.83 V/1 m):
Recommended Amp. Power:
Power Handling:
Impedance, Nominal:
Frequency Response (+/- 3 dB):
Resonance Frequency:
Internal Cabinet Volume:
Bass Principle:
Weight:
Dimensions (W x H x L, cm):
Crossover:
Crossover Frequencies:
Crossover Slope:
Connection:
Recommended Placing:
85.5dB (averaged 300Hz-3kHz)
10 to 175 Watts
175 watts
4 ohms
55 Hz - 20 kHz
47 Hz
10 litres (.39 ft^3)
Passive radiator
9.9 kg (21.8 lbs)
14.05 x 114.3 x 14.9 (5.5” x 45” x 5.9”)
2 1/2 way
900 Hz, 2.5 kHz
Tower Woofers: 12 dB/oct LP; Top Woofer: 6 dB/oct LP; Tweeter 12 dB/oct HP
5-way, gold plated binding posts
Floorstanding
  • Exceptional soundstage capabilities
  • Tonally neutral sounding
  • Very attractive product
  • Small footprint
  • Lightweight bass response; all but requires a subwoofer.
  • High center of gravity; may lean slightly if placed on carpet too thick for the supplied spikes.
Introduction
Even before you get them out of their shipping carton it’s obvious these are definitely not your average box loudspeaker. Clearly Mirage have done their homework and obviously appreciate the importance of integrating performance with appearance.
