Klipsch Icon V Speaker System Review
- Product Name: Icon V Speaker System
- Manufacturer: Klipsch
- Performance Rating:
- Value Rating:
- Review Date: December 15, 2008 12:22
- MSRP: $ 2059.97 - 5.1 system
- Specifications
VF-36 Floorstanding Speakers ($949.99 pair)
Frequency response: 36Hz - 23kHz +/- 3dB
Low frequency extension: 33Hz
Power handling: 150 W continuous, 600 W peak
Sensitivity: 97.5dB
Nominal impedance: 8 ohms compatible
Crossover frequency: 1780 Hz
Drive components: Shielded two-way system utilizing three 6.5" fiber-composite lightweight cone woofers and one 1" aluminum dome tweeter mounted in a 6" square 90º X 90º XT Tractrix® Horn
Enclosure material: MDF (medium density fiberboard)
Enclosure type: Bass reflex via front flared port
Dimensions : 45" (114.3 cm) x 8.5" (21.6 cm) x 15.75" (40 cm)
Weight: 55 lbs (24.9 kg)
Finishes: Black vinyl with furniture-grade black wood veneer top capVC-25 Center Channel ($279.99)
Frequency response: 77Hz - 23kHz +/- 3dB
Low frequency extension: 70Hz
Power handling: 75 W continuous, 300 W peak
Sensitivity: 93.5dB
Crossover frequency: 1900Hz
Drive components: Shielded two way system utilizing 2 - 5.25" fiber-composite lightweight cone woofer and 1 - 1" Aluminum dome tweeter mounted in a 4.5" Square 90° X 90° XT Tractrix horn.
Enclosure type: Sealed enclosure
Dimensions: 7" (17.8 cm) x 21.5" (54.6 cm) x 8.75" (22.2 cm)
Weight: 16 lbs (7.3 kg)
Finishes: Black vinyl with furniture-grade black wood veneer side capsVS-14 Specifications ($329.99 pair)
Frequency response: 99Hz - 23kHz +/- 3dB
Low frequency extension: 92Hz
Power handling: 50 W continuous, 200 W peak
Sensitivity: 89dB
Crossover frequency: 2000Hz
Drive components: Two-way system utilizing one 4.5" fiber-composite lightweight cone woofer and two 1" aluminum dome tweeters mounted in dual 4.5" square 90º X 90º XT Tractrix® Horns in a WDST configuration
Dimensions: 6.75" (17.1 cm) x 15" (38.1 cm) x 6.5" (16.5 cm)
Weight: 7.5 lbs (3.4 kg)
Finishes: Black vinyl with furniture-grade black wood veneer top and bottom capSynergy Sub-12 ($500)
Frequency response: 24-120Hz +/-3dB
Amplifier power: FTC Rated Power: 300 watts continuous @ 1% THD, Dynamic Power: 650 watts
Maximum acoustic output: 117dB @ 30Hz 1/8 space, 1m
Drive components: 12" (30.5cm) fiber-composite cone, down-firing woofer
Amplifier: BASH® digital hybrid
Phase: Switchable 0-180 degrees
Enclosure type: Bass-reflex via rear-firing port
Inputs: L/R line-level RCA jacks, L/R high level speaker binding posts
Outputs: L/R High level speaker binding posts (passthru)
Dimensions: 18” (45.7cm) H x 15” (38.1cm) W x 19.9” (50.5cm) D
Weight: 40 lbs. (18.2kg)
Features: Volume, Lowpass, Phase, Auto Power
Voltage: 110/120 VAC 60Hz
Export voltage: 220 VAC 50/60Hz
- Dynamic
- Great at moderate volume
- Fatiguing at higher volumes with music
- Midrange a bit thin
Introduction
Recent Forum Posts:
SC 35 avr
VF 36 mains
VS 14 front height
VS14 surrounds
VF 35 surround back
VC 25 center
AA RW 15in sub
Matt34;497873
That's what I don't understand, are they going to be reference replacements? Because you can get RF-82 for just about the same price and even less if you shop ebay.
I would have no qualms about having a set of Ref in my HT setup.
They are not the replacements for the Ref series, those are the Icon W's, which perform far better than the V. I just find it interesting that they are at the same price point and there is such a very pointed difference between two in quality. For my money, I'd be all over the Ref.
Matt34;497873
It is peculiar to say the least. You can't blame Klipsch as a company though for pairing with best buy to put out a speaker line. In fact its quit genius. Companies like Paradigm, B&W, and other require a visit to the specialty shop where as Klipsch is positioning themselves to be in the face of anyone shopping for electronics because lets face I say "electronics" most people think "Best Buy".
My only hunch would be that in the push to capture huge market share that BB can deliver Klipsch does not want to put its own Reference line out to be smeared. Most audiophiles will likely dismiss any speakers available in a big box store as high profit low quality knock offs for the mass public. IMHO the RF series can hold its own (I own RF-82's) The possible poor rap the company's premier line could get for just being perceived as cheap just for being on the big chains shelf is worth making a whole new line to prevent.
Just my thoughts.
Now maybe a mediocre speaker is adequate for reproducing the car crashes and bombastic surround sound of the latest "hero outrunning an explosion" movie but not for reproducing the sublime work of Rozsa, North, Elmer Bernstein, Tiomkin, Newman, Rogers & Hammerstein and others.
The reviewer also thought that the speakers in question would need a subwoofer with "all" movies. All? Do we need subwoofers for "Gone With the Wind" and "Sunset Blvd"?
