Energy Connoisseur CF-50 Floorstanding Loudspeaker System First Look
Energy CF-50 Floorstanding Speaker
  • Product Name: Connoisseir CF-50
  • Manufacturer: Energy
  • Review Date: September 24, 2010 03:20
  • MSRP: $800/pair
Specifications
System Type 2.5-way floorstanding, magnetically shielded bass reflex with front-firing port
Frequency Response 39Hz - 20kHz
Recommended Amplifier Power 20-250 W /channel
Impedance 4 Ohms min / 8 Ohms nominal
Tweeter 1-inch (25.4mm) hyperbolic aluminum-dome
Woofer 3 x 5.5-inch (140mm) w/Ribbed Elliptical Surrounds
Sensitivity (2 speakers in a typical room) 96dB
Crossover Point 2kHz, 1.2kHz
Inputs Dual gold plated 5-way binding posts
Overall Dimensions HxWxD (including feet)
38.6 x 7.1 x 14.6 inches
98.1 x 18 x 37cm
Weight Product: 39.3 lbs / 17.8 kg (each)
Packed: 45.3 lbs / 20.5 kg (each)
Finishes High gloss black baffle with black ash cabinet
Included Accessories Manual, port plugs
Executive Overview
Canadian based loudspeaker company Energy is making a comeback with a completely revamped model line starting with their new Connoisseur series.  The CF-50 is a 4 driver 2 1/2 way vented floorstanding speaker system sporting dual 5 1/2" midbass phase plug drivers with ribbed elliptical surrounds, one 5 1/2" phase plug midrange, and a 1" aluminum tweeter.   In speaking with the Energy rep at CEDIA, they informed us that the Connoisseur line is based on their flagship Veritas line which has recently be refreshed and re-released to the market.
Some key features of the CF-50 that Energy is touting includes:
  • Exclusive Convergent source Module features woofer and tweeter uniquely integrated for accurate sound and expansive soundstage.
  • Triple 5.5-Inch Woofers feature patented Ribbed Elliptical Surround suspension for greater dynamics, output and lower distortion
  • Exclusive 1-Inch Hyperbolic Aluminum tweeter provides high frequency accuracy, high power-handling and wide dispersion
  • Rigid, low-distortion cross-braced MDF enclosure with attractive Black Ash Finish and Black High Gloss trim.
  • Port plug & carpet spikes included.
Don't be fooled by their small footprint or asking price, the CF-50 are rated to play down to 39Hz which is excellent extension for a speaker of its size.  The Energy CF-50 is designed for a wide range of multimedia applications, including movies, music, and gaming.  The build quality looks to be genuinely excellent and we were particularly pleased that the phase plug drivers actually used real phase plugs that were not attached to the cone like so many budget model speakers employ for cosmetic reasons.
Editorial Note About Phase Plug Drivers
The phase plug essentially eliminates the need for a dust cap, which in turn, reduces cone mass, permitting extended frequency response. It allows more airflow through the motor structure, which improves cooling and thus increases power handling. A Phase plug also helps to reduce on-axis beaming by dispersing higher frequencies that the cone is producing. Beware, many loudspeaker manufacturers use a quasi phase plug which looks like a phase plug for marketing purposes, but does not physically separate from the cone of the driver. These "so called" phase plugs can do more harm than good as they provide an inconsistent surface area and can also increase mass of the cone yielding poorer frequency response and linearity.
We've always been fans of Energy loudspeakers and glad to see their entire model lineup has been refreshed.  At $800/pair packed with some impressive technology developed by Energy, the CF-50s should perform as good as they look. We have high expectations for this series and look forward to taking a closer look in a formal review.
For more information, visit: Energy Loudspeakers
tom67 posts on September 24, 2010 16:04
Yup, wedge a horn in there someplace and make them edgy and a little more interesting...
3db posts on September 24, 2010 06:45
98.1 x 18 x 37cm
These look to be better built then their latest Veritas update... I see their efficiency is way up too.. I still withhold my judgement on these until I hear them based on my prebias that Klipsch got their mits on these.
Submit News!
