Canyon Audio Series 310-TSC Loudspeakers Review
by Clint DeBoer last modified April 03, 2005
  • Product Name: Canyon Audio 310 Series Loudspeakers
  • Manufacturer: Canyon Audio
  • Performance Rating: StarStar
  • Value Rating: Star
  • Review Date: April 03, 2005 20:00
  • MSRP: $ 1397
Specifications
Series 310-T
Type: 3-way rear-ported bass reflex Woofer: 10" side-firing paper cone
Midrange: Two 6.5" aluminum bullet cones
Tweeter: 1" silk dome
Frequency Response: 45Hz - 20kHz (+/- 3dB)
Nominal Impedance: 8-ohms
Crossover: 400 Hz /  2 kHz 2nd order
Sensitivity: 90dB
Recommended Power: 10-250 Watts RMS
Magnetic Shielding: Yes
Dimensions: 42" x 8.25" x 14" (107cm x 21cm x 36cm)
Weight: 55 lbs (121 kg) each
Series 310-C
Type: Sealed box, 2-way, D'Appolito array
Series 310-C (cont'd)
Crossover: 2 kHz 2nd order
Sensitivity: 88dB
Recommended Power: 10-120 Watts RMS
Dimensions: 23.5" x 8.25" x 10.5" (60cm x 21cm x 27cm)
Weight: 20 lbs (44 kg) each
Series 310-S
Sensitivity: 88dB
Magnetic Shielding: No
Dimensions: 15.5" x 8.25" x 10.5" (40cm x 21cm x 27cm)
Weight: 15 lbs (33 kg)
  • Good looking system
  • Very inexpensive for a $500 full-size set of home theater speakers
  • Perform on par with $500 5.1 speaker systems but look more impressive.
  • No subwoofer
  • Uneven frequency response, partially due to mediocre drivers and non-removable decorative speaker covers
  • Somewhat muddy mid-range
Introduction
Every once in a while we'll take in a set of speakers from a relatively unknown company in order to see what's available on the market and if some independent shops have some value products available for consumers. Canyon Audio is a manufacturer based in Nevada who works with some domestic designers to have custom modifications made to products which are then manufactured overseas to keep costs down.
