Infinity P162 Build Quality
The Infinity Primus P162
Bookshelf speakers have been selling like hotcakes at the Audioholics store -
that's just a fact. They've got a lot of buzz right now and people on audio
forums all over the net are excited about them. It doesn't hurt that they've
also been on a bit of sale at just under $200 a pair. That's got a lot of
people excited about value as well. The store guys (the editorial staff of
Audioholics doesn't actually run the store contrary to popular belief)
approached me about a review of these speakers. I'm thinking they don't
actually read my reviews or they'd know that I'm a no-holds-barred kind of guy
who is not easily swayed by public opinion or mass hysteria. I'm going to
review these speakers as I would any other. That's what my readers expect and
that's what I'm going to give them.
Build Quality
As
you'd expect from a company like Infinity, the Primus P162s came well packed in
custom boxes with cardboard tops and bottoms with foam edges glued to them.
This is a very efficient method of packaging which provides the maximum
protection with the least amount of foam. It also ensures that the foam doesn't
move or slip during handling keeping the speaker very well isolated from
outside damage.
The speakers themselves are rather large for this price point (around $320 a pair) at over a foot tall and nearly a foot deep. The black wood-grain vinyl wrap is on par with the quality of other offerings at this price point - which to say is that it is barely passable. The edges had a tendency to peel up at the slightest provocation. The front of the speaker sports a rounded baffle and a grey plastic faceplate. The drivers (one .75" tweeter and a 6.5" woofer) are also grey. The speaker is front ported just below and to the left of the woofer. The logo is on the lower right of the faceplate and at the bottom center of the grill.
The grill is interesting in that
it wraps up around the rounded enclosure at the top. This gives the speaker a
sort of "swept back" look though it is really just a rectangular box.
With the grill off, the grey faceplate seems to float in the center of the
enclosure. The grill attached VERY firmly on plastic posts. Unlike other grills
I've experienced, this one feels sturdy and stable with plenty of molded
plastic reinforcement. The posts, while plastic, are thick and strong so that
even though you have to fight a bit to get the grill off (a good thing for all
of us with kids), you don't feel like you are likely to break anything.
The
back of the speaker shows a bit of overlap of the walls, top, and bottom of the
speakers with the back panel. This is actually quite common and something I've
seen in higher dollar speakers like the DALI LECTOR 8s and Krix Phoenix. It isn't
my favorite design choice but it is on the back so it really doesn't matter.
There is a single pair of 5-way binding posts with plastic caps in a black
plastic housing on the back of the speaker as well.
The speakers arrived with a generalized manual for the entire Primus line, a paper specifying a limited 3/5 year warranty, and rubber feet to stick to the bottom for shelf mounting. If you have stands, I HIGHLY recommend you NOT place the rubber feet on the speaker and instead on the top of the stand (many stands come with rubber pads for the tops these days). This eliminates any problems you may have with placement on top of the stand in trying to make contact with the pads on the bottom of the speaker. Word of note, the warranty is transferable between owners which is nice for those that want to try the P162s out but think they may sell them later down the road.
Taking the speakers apart, I
quickly noted that the woofers were shielded. A quick test of placing the
speaker up to my ancient CRT monitor confirmed that the shielding was working
effectively. The cabinet is about 5/8" thick MDF (it's a bit hard to tell
with the plastic face plate - may be as thin as 1/2"). The port is very
short but flared slightly on both ends. The cabinet has a bit of acoustical material around the top portion of the
box (around the tweeter) but only on the side wall opposite the port on the
bottom portion. There is one brace across the middle of the cabinet. The knock
test doesn't sound so hot with these speakers with a bit of a ring everywhere
including where the brace is located.
The woofers have stamped
baskets and the tweeter is mounted to a plastic housing. Usually, tweeters and
woofers are made out of different materials but with the P162s, they are both
constructed out of Metal Matrix Diaphragm (MMD)
material. This is essentially aluminum that has been anodized on both sides. Usually,
we'd expect tweeters (at least) to be made out of something harder like
titanium or aluminum but Infinity claims that MMD
"…is 3 times as rigid as titanium, and 85 times more rigid than felted
paper. This unique design is capable of eliminating unwanted tonal resonances
in the signal path. The end result is a full, clear, tight reproduction of low
and high frequencies." At the very least, if your feng shui is all about
matching, you've found a speaker with drivers that finally do. For me, the sort
of dull grey looks more like plastic than metal which inspires a feeling of
cost cutting rather than cutting edge technology. If I were Infinity, I'd
research some ways to make MMD
look more like metal and less like an old iPod case. The crossover is a rather
elaborate network consisting of one air core inductor, a few iron core ones and
electrolytic caps as cost saving measures. Without seeing a schematic, I’d
guesstimate Infinity employed 2nd order crossovers on the woofer and tweeter
and based on the smooth impedance plot below, also incorporated a zobel network
or two. It is obvious some good thought went into this crossover unlike most
speakers in this price range that simply slap on a series cap on the tweeter
and run the woofer full range.
