ER Multichannel Listening and Conclusion
The ER speakers aren't just a stereo pair, but a full system. The remainder of my listening tests were done in a full surround environment which added the Axiom EP500 to fill in the low end.
DVD-A: Blue
Man Group: The Complex
f I had to pick just
one album to bring with me to a listening test, this one would be at the top of
the list. Tons of surround effects, low bass, dynamic range… this album has it
all. After seeing them live in Vegas during the last CES, I can't help but be
more impressed with the mixing of this album. It sounds very much like the live
show. The ER speakers did a phenomenal job with this recording. In the opening
track, Above, the hammer dulcimer
starts off nearly all alone. The sound is vaguely reminiscent of a xylophone.
The ER speakers did an amazing job with this opening sequence. It was well
defined, crisp, and well presented. Once the rest of the instruments came in, I
was again impressed with the dynamic responsiveness of the speakers. There
seemed to be no hold over of any notes. Loud and soft passages were crisply
delineated.
The depth of the soundstage was also remarkable. If you've ever heard (or I guess seen) the Blue Man Group, you know there is just a ton of instruments and sound effects going on. I can literally listen to the same song ten times in a row and focus on a different sound or effect each time and still have some left over. The Emotiva ER speakers presented each of these sounds clearly and articulately. It was very easy to drill down into the music and hear anything I wanted too.
DVD-A: Porcupine
Tree: Deadwing
Right from the
beginning, I suspected that Emotiva had something special with their ERD-1
dipole speakers. The Axiom QS8's are a very highly regarded rear
"quad" pole speaker (a top and bottom woofer and two side angled tweeters
- one on each side all firing in phase). I was surprised to find that the
ERD-1s bested the Axioms on almost every metric I could come up with. The
opening sequence of the first and title track features a keyboard bouncing
around the rears and what sounds to be a train pulling into a station. The ERDs
really performed well not only during the quiet section at the very beginning
but also in remaining articulate during the louder sections. At no point did I
think the ERDs were being overpowered or drowned out. At the same time, they
blended well with the rest of the system. Basically, when I wanted to hear them
I could, when I didn't, they just disappeared. While some might say that a
bipole configuration would be best for multichannel music, I found the dipole
setting to create a nice diffuse sound that still performed well for point-source
effects. As always, we encourage you to experiment for yourself and see what
you prefer. Just make sure to check your levels as you switch between the
settings as the levels are likely to change. While I've always found the Axioms
to be a fine surround speaker, the ERDs are in an entirely different class.
DVD: Spiderman 2
Generally I use this
album for surround effects but this time I found it playing a different roll. I
watch this movie mostly for testing but also because it is just so darn good.
In my opinion, it is probably the best superhero movie ever made. Since the
center channel (an ERM-1 lying on its side)
was inside a cabinet, I noticed that the vocals sounded a little boxy and
reverberant. I quickly switched on the boundary compensation. This helped a
bit, but not enough. Lastly, I added a bit of padding between the ERM-1
and the cabinet which helped with some vibrations I think I was hearing as well
as tilted the speaker up just a tad. This helped as well. While overall I felt
it was performing well, I couldn't shake the feeling that the ERM-1
needed a little more room to breath. Unfortunately, like many others, I don't
have the luxury of setting up a center in the middle of my room and am forced
with this arrangement. I urge Emotiva to develop some sort of felt feet that
can be placed on the bottom of these speakers especially if they can be
adjusted to modify the tilt angle.
DVD: 30 Days of Night
While I understand
that this movie followed the comic pretty well, I found it to be a mediocre and
mostly confusing vampire flick. We're never really sure the vampire's
motivation or reasons (other than the obvious). Perhaps that was part of the
writer/directors intent but it bugged me. In a horror movie, point-source effects
are extremely important and 30 Days of Night was no different. As you'd expect
from a dipole speaker that already impressed with music, the ERD-1s were spectacular
with movies. Ambient music was diffuse and enveloping and point-source effects
were easily localized and convincing. The ERD-1's ability with movies was at
least as good as with music and probably better. I can easily imagine two pairs
of these being used in a 7.1 configuration with the back pair being set to
bipole and the side pair on dipole. The joy is that you don't have to decide
when you purchase - just buy two pairs and try them out. That kind of
flexibility is very rare in a speaker these days.
HD DVD: Harry Potter and the
Order of the Phoenix
One thing I found in
all my listening tests but was accentuated with the below average recreation of
J.K. Rowling's book was that the ER speakers could definitely use some better
amplification than the Denon 2307CI. While I really like this receiver, and the
amp section kept up admirably, I definitely felt that I was having to push the Denon
harder than I did with many of the other speakers I've reviewed. This is
probably partially due to the fact that the speakers were so clean and
responsive that I could play them louder without them sounding pushed. Where I
generally have movie night at between -20 and -10 on the dial, the ERs required
more like -15 to -5. While this
isn't a huge change, it is something. With some external amplification (or a
receiver with a beefier amp section) and a sub or two, I expect these speakers
to easily fill a medium to large sized room. The fact that they are bookshelves
means that they also will do well in a smaller room with a more reasonably-sized sub.
It's not hard to gather that I am impressed with these speakers
- especially from a performance perspective. They seem to try to be all things to
all listeners. With the Tweeter adjustment, Boundary compensation, and dipole/bipole
options, there is nary a room that these speakers wouldn't blend in to.
Flexible, crisp, articulate… I could come up with a hundred positive adjectives
to describe the ER speaker from Emotiva… except pretty. If performance is what
you are after, the Emotivas have it in spades. I for one never would have
expected an amp and processor company to come out with such a great performing
speaker.
I'm happy to say that I was proven wrong.
Emotiva ER 5.0 Speaker System
$1246
Emotiva Audio
106 Mission
Court
Suite
101
Franklin,
TN 37067
615-771-1224
877-EMO-TECH
www.emotiva.com
About Emotiva
Audio
Emotiva
engineers believe that the experience of enjoying home audio and home theater
components begins with thoughtful design, robust engineering, superior quality
materials and a deep understanding of what the audio/video enthusiast wants and
needs. It occurs all too often; designers and manufacturers consider technology
and ease of use to be mutually exclusive qualities in a product. Emotiva
engineers think differently. Technologically superior and user friendly
products are paramount to the Emotiva design philosophy and are qualities that
allow Emotiva users to appreciate their purchase in the future as much as they
do today. We utilize only premium components with proven, critically evaluated
circuitry in the audio and video paths to preserve the original quality of the
sound and vision experience. Emotiva products compliment the entertainment
experience and bring it up to a level rarely experienced with other mass produced
products.
— Excellent
— Very Good
— Good
— Fair
— Poor
| Metric | Rating |
| Build Quality | ![]() ![]() ![]() ![]() ![]() |
| Appearance | ![]() ![]() ![]() |
| Treble Extension | ![]() ![]() ![]() ![]() ![]() |
| Treble Smoothness | ![]() ![]() ![]() ![]() ![]() |
| Midrange Accuracy | ![]() ![]() ![]() ![]() ![]() |
| Bass Extension | ![]() ![]() ![]() ![]() |
| Bass Accuracy | ![]() ![]() ![]() ![]() ![]() |
| Imaging | ![]() ![]() ![]() ![]() |
| Soundstage | ![]() ![]() ![]() ![]() ![]() |
| Dynamic Range | ![]() ![]() ![]() ![]() ![]() |
| Fit and Finish | ![]() ![]() ![]() ![]() |
| Performance | ![]() ![]() ![]() ![]() ![]() |
| Value | ![]() ![]() ![]() ![]() ![]() |
Recent Forum Posts:
I think you're right, most places would charge extra for the new grills, but I'm not surprised Emotiva didn't, doesn't seem their style.
Just something else that makes me pleased with my decision to go with the ERDs... -TD
Not that there was anything wrong with the old grills. They just weren't happy with them. The new grills have a little darker black appearance and don't have the slight sheen of the older grills. They also include a new circular chrome company emblem with the "E".
I received mine last week. They make a great speaker even better.
Most companies would just add a new item to new sales and call it an "upgrade".
But they went through the expense of shipping them to all owner.
Initially, I thought they were very good surrounds for the money, this was back when they dropped the price from $350 to $315. Now that they are selling at $250 a pair, I'd have to say these are an outstanding deal.
My first objective was to compare them to the performance of the Axiom QS8s that I'd previously owned. While they didn't quite seem to measure up to them at the time, I'd have to say after having them for a couple of months now, they more than hold their own for movies and I'd have to say outperform the QS8s with music. I thought the QS8s would be be impossible to best at their price, but the ERDs hold their own and then some. When you see/hear how well the ERDs perform, you'll be amazed at how tremendous a value they really are... -TD
http://emotivalounge.proboards54.com/index.cgi?board=speakers&action=display&thread=1876 [emotivalounge.proboards54.com]
babs;444899
Though I'd certainly never expect the ERM's to hang with B&W 805's at $2k+,
The ERM-1 display many of the qualities I prefer in speakers at any price point. I found them to be clear and detailed without being bright, neutral and without the resonant midrange that I find in a lot of speakers. I think it's an outstanding speaker for the list price, but free is even better. Combined with a good sub, they will be hard to beat (at least to my ears).
