- Product Name: W3 In-wall/On-wall speakers
- Manufacturer: Axiom Audio
- Review Date: September 25, 2007 19:00
- MSRP: $500/pair
- Specifications
Max Amp Power:175 WattsMin Amp Power:
10 Watts Response +/- 3dB:60 Hz – 22 kHz Response + 3dB/- 9dB:50 Hz – 22 kHz Impedance (Ohms):8 OhmsSPL in Room1w/1m:91 dBSPL Anechoic 1w/1m:87 dBX-Over2.2 kHz Tweeter:Single 1"Woofer:Single 6.5"On-wall Dimensions HWD mm:345 x 244 x 91 In-wall Dimensions HWD mm:244 x 106 x 86 On-wall Dimensions HWD inches13.6 x 9.6 x 3.6 In-wall Dimensions HWD inches9.6 x 4.18 x 3.4 Weight kg each4.08 Weight lbs each9
Executive Overview
In this video, we discuss the design of this product, get a detailed overview of how it works and learn about the various custom veneer finishes that can be ordered to better match your room decor. Alan discusses the process Axiom used when designing these products to ensure they closely matched the performance of their boxed counterparts. This video focuses mostly on the W3's we later install in one of the bedrooms of the Audioholics Showcase home.
