You are here: Home Pro Reviews Speakers Architectural & Outdoor Axiom Audio Epic Accent M0 On-Wall Speaker System Review
by Tom Andry last modified August 25, 2010
  • Product Name: Accent M0
  • Manufacturer: Axiom Audio
  • Review Date: October 02, 2009 14:00
  • MSRP: $ 135/each or $998 (5.1 w/EP125) or $1686 (5.1 w/EP400)
Specifications
Specs
M0
Enclosure:
Sealed
Response +/- 3dB:
160–20 kHz
Impedance (Ohms):
8 Ohms
SPL in Room1w/1m:
87 dB
SPL Anechoic 1w/1m:
83 dB
Tweeter:
1" titanium dome
Woofer:
3" aluminum cone
Dimensions HWD (inches):
6.5" x 6.1" x 2.3"
Weight (lbs) each
2.95
Max Amp Power:
150 Watts
Min. Amp Power:
20 Watts
Specs
EP125
Enclosure:
Vortex / Reflex
Max Amp Power:
125 Watts
Cross-over Adjust
60 - 120 Hz
Phase
0 & 180
Woofer Size
8"
DSP Controlled
No
Line In and Out
Yes
Balanced Line In and Out
Yes
High Level In
Yes
Room Trim
No
Dynamic Power Supply
No
Anechoic Resp. +/- 1.5dB
Anechoic Resp. +/- 3dB
35 - 150 Hz
Room Resp. + 3dB/- 9dB
25 - 150 Hz
Max SPL Anechoic
104 dB
Max SPL In Room
114 dB
Dimensions HWD inches
14.5 x 12 x 12
Weight lbs each
20 lbs
Specs
EP400
Enclosure:
Acoustic Suspension
Max Amp Power:
500 Watts
Cross-over Adjust
40 - 150 Hz
Phase
0 & 180
Woofer Size
8"
DSP Controlled
Yes
Line In and Out
Yes
Yes
High Level In
Yes
Room Trim
Yes
Yes
18 - 150 Hz
18 - 150 Hz
17 - 150 Hz
Max SPL Anechoic
106 dB
Max SPL In Room
116 dB
Dimensions HWD inches:
13.75" x 10.5" x 16.8"
Weight lbs each:
48.55 lbs
  • Innovative bracket/termination system
  • Small size
  • Uniform off axis response
  • Bracket screws strip easily
  • Speaker sits far enough off wall to allow visibility of the hole/wires
  • Occasional disengagement of speakers from brackets can disrupt playback
Introduction
From the magnetic grills to the innovative (if quirky) wall mounting bracket system, the Axiom Audio M0s are a speaker unlike any other. Of course, coming from Axiom you'd expect them to deliver sonically - and they do. If you are looking for an unobtrusive on-wall system for a smaller room, the M0s are a very good choice and deserve to be on your short list. At $135 each and with a free 30day in-home trial, you've got little to lose except your preconceptions about what a small speaker can do.
Recent Forum Posts:
cwall99 posts on October 02, 2009 23:33
Cool. Thanks.
gene posts on October 02, 2009 16:10
refresh your browser. I accidentally posted the forum thread before publishing it live on the site. Its working.
cwall99 posts on October 02, 2009 14:58
I keep getting 404 site not found errors when I click on either the Next button or select one of the items from the page menu for this article.
I would have posted this message on your site admiinistrator's page (as directed by the 404 error message page), but when I click on the link (on the 404 error page), I still get the 404 site not found error.
Just an FYI that something's goofy with this article.
