You are here: Home Pro Reviews Speakers Architectural & Outdoor Axiom Audio Algonquin Outdoor Speaker System Review
by Gene DellaSala last modified July 29, 2008 12:05
  • Product Name: Algonquin Outdoor Speaker
  • Manufacturer: Axiom Audio
  • Review Date: February 25, 2008
  • MSRP: $330/pr (shipping included)
Specifications
  • Enclosure: Vortex / Reflex
  • Max Amp Power: 175 Watts
  • Min Amp Power: 10 Watts
  • Freq Resp +/-3dB: 60 - 22 kHz
  • Freq Resp +3dB/-9dB: 50 - 22 kHz
  • Impedance (Ohms): 8 Ohms
  • SPL In-Room 1w/1m: 92 dB
  • SPL Anechoic 1w/1m: 88 dB
  • X-Over 2.2 kHz
  • Tweeter: Single 1"titanium
  • Woofer: Single 6.5"aluminum
  • Dimens. H W D (inches / mm): 13.5" x 8.5" x 8.25" / 343 x 216 x 210mm
  • Weight (lbs/kg) each 9.05 lbs / 4.1 kg
  • Great sound for an outdoor speaker
  • Plenty of bass extension
  • Custom color matching
  • Not fully weatherproof design
  • Pricey mounting brackets
Introduction
The Axiom Algonquins proved to be among the best sounding speakers I've heard in this price class. Their ability to give you a full spectrum of sound, solid bass extension, and plenty of efficiency and power handling makes them ideal for those looking for quality bookshelf type speaker systems for their gaming room or covered barbeque area. Axiom’s color matching, prompt and unparalleled customer service and very generous return policy makes them a safe buy for anyone not sure if these speakers are right for them.
  1. Algonquin Build Quality and Setup
  2. Algonquin Listening Tests
  3. Algonquin Measurements & Analysis
  4. Algonquin Conclusion
