You are here: Home Pro Reviews Remote Controls Universal Remote URC MX-450 First Look
by Clint DeBoer last modified August 18, 2008
Universal Remote MX-450
  • Product Name: MX-450 Remote Control
  • Manufacturer: Universal Remote Control
  • Review Date: August 18, 2008 13:50
  • MSRP: $249
Specifications
  • LCD Size: 2” TFT Color LCD (176 x 220 Pixels)
  • Size: 8" x 2.25" x 1.25" (H x W x D)
  • Weight: 9 ounces (with battery loaded)
  • Learning Capabilities: Standard frequencies (15kHz to 460kHz)
  • Macro Capabilities: Up to 255 steps each
  • Memory: 32 Megabits of Flash Memory.
    Total Customization Capability - Up to 18 devices on 3 Main pages with up to 8 pages for each device; plus up to eight pages of favorite channels for a total of 155 pages.
  • RF Freq: 418 MHz
  • Range: RF - Up to 100 feet when used with MRF-260, MRF-350 or MSC-400 RF Base stations
    IR (line of sight) - Up to 50 feet with fresh batteries.
  • Power Supply: Four AA Alkaline Batteries (included)
  • Warranty: 1 year parts & labor when purchased from an authorized dealer
Executive Overview
Universal Remote Control, Inc. released the new MX-450 a stand-alone IR/RF programmable remote control with 2-inch color LCD screen. Custom installers can program and set up the remote in minutes without a PC or Internet connection and URC's MacroEdit firmware allows for full macro editing on the MX-450’s LCD screen.
The point of the MX-450 seems to be getting a PC-free remote into the hands of custom installers who may not be apt to bring along a laptop to the jobsite. The MX-450 also provides an advanced, GUI-driven macro programming and EDITING interface, something that is new to the remote control world.
Macro programming, which delivers a specific sequence of commands to a variety of components, is usually irksome on standalone remotes, which don’t provide instant feedback. Installers always have faced the challenging task of programming macros on such devices without being able to modify their work on the fly. If one step is wrong in the macro (for example, if a delay is too short), the entire macro must be deleted and completely re-programmed. With the MX-450’s MacroEdit on-screen setup, the installer can see the macro steps clearly displayed on the remote’s screen, and can fine-tune, re-order, adjust delays and add steps to macros without deleting his or her previous work.
The MX-450 can be set up and installed more rapidly than many other standalone programmed remotes. To demonstrate its simplicity, there is no programming manual for the MX-450. All the information installers presumably need is available on-screen in the form of programming tips and step-by-step instructions that simplify the setup process. Experienced installers can bypass the tips and instructions completely for even faster setup.
A beautiful two-inch color LCD display (176 x 220 pixels) delivers bright color graphics for all home theater activities. Labels for every button are customizable, and channel logos are even available for up to 48 of the client’s favorite TV channels. The MX-450 features LED backlighting of its LCD screen and all buttons, making it easy to read every button even in complete darkness and extending battery life. The MX-450 requires four AA batteries. To extend battery life, URC's "PowerSaver" circuitry enables the color LCD screen to operate at maximum efficiency. The MX-450 can control up to 18 different devices and can serve as an infrared (IR) or radio frequency (RF) remote (URC RF Base Station required).
The MX-450 is now available for an MSRP of $249. For more information on Universal Remote Control, please visit www.universalremote.com.
Recent Forum Posts:
highfigh posts on February 24, 2011 17:04
I wouldn't rule out the Harmony 1100 with the RF extender. It's very versatile and customizing buttons is easy. Unfortunately, creating different macros doesn't work.
highfigh posts on February 24, 2011 17:02
zamboni99;795352
will the mx 450 work with the rfs 100 base station?
Get one of the base stations with assignable outputs. It makes life a lot easier. Don't just go for the cheapest in this stuff- that only leads to immense frustration.
adk highlander posts on February 24, 2011 14:10
They both run in the 418mhz RF frequency so they should work together. I would email URC just to make sure.
zamboni99 posts on February 24, 2011 13:55
bandphan posts on September 11, 2008 08:01
Midcow2;454109
I have thought about doing this, especoaily since All my equipment, except for the DsiHNetwork receiver and TV are behind cabinet doors. But if I understand a MRF350 cost about $250 and the MX-450 about $250 , so you are talking about $500 correct?
Also, how good is it at emulating all of the satellite controller functions ?
Thanks and very interesting thread , at least to me?
MidCow2
I have bought some cheaper univerals, but they never did fully work to my satisfaction. I can program most of the stuff into the marantz controoler except for some of the DVD and a lot of the Satellite receiver. Maybe, I just haven't spent enough time.
I have found very few peices of equipment that there are no work arounds for. The URC remotes will replace your oem remotes, all functions to be programmed. The base stations with assignable ir outputs allow for control of identicle gear without conflict and with URC partnering with Lutron, new remotes get native rf control over their products.
