Sunfire Universal Subwoofer Wireless Kit First Look
by Tom Andry last modified May 25, 2011
Sunfire Universal Wireless Subwoofer Kit
  • Product Name: Universal Wireless Subwoofer Kit
  • Manufacturer: Sunfire
  • Review Date: May 25, 2011 05:35
  • MSRP: $160 ($80 each for transmitter and receiver)
Specifications
Specifications
SDSWiTX
SDSWiRX
Latency 17 ms 17 ms
Resolution 16 bit 16 bit
Sampling rate 48 kHz 48 kHz
Wireless band 2.4 GHz 2.4 GHz
Error checking no info no info
Weight TBD TBD
Dimensions TBD TBDâ™
Executive Overview
Aside from size, one of the biggest headaches in placing a subwoofer is the cable. Just like the rear speakers, running a cable across the room or even over an open space between the home theater furniture and the best placement for the sub, can cause more than a few fights between otherwise amicable partners. Unfortunately some manufacturers like to make their sub cables bright orange or blue which only exacerbates the situation.
There have been a few wireless speaker solutions released in recent years. Mostly in connection with home theater in box systems. These "wireless" rear speakers are about as wireless as I am armless - not at all. The wireless solution always requires power. This means that you either have to place the speaker near an outlet or (and we've never seen this solution) have to charge your rear speakers occasionally. Subwoofers have the advantage (if you'd call it that) of having to be placed near an outlet. Plus, they are normally located on the floor rather than on stands/walls/shelves. A wireless solution with a sub requires nothing more than an extra outlet.
With subs so ripe for the wireless solution, it was only a matter of time before Sunfire released a solution. The Sunfire Universal Subwoofer Wireless Kit has been purposefully designed for subwoofer use. As you might expect from Sunfire. The "universal" aspect means it will work with any sub/receiver. Which doesn't really need to be mentioned as only a company more interested in keeping all their toys for themselves rather than making money would make a proprietary system. In Sunfire's defense, their website makes no mention of this "universal" aspect probably indicating that someone in their marketing firm made the executive decision to include that word in the title. We're just lucky that same brainiac didn't try to shoehorn 3D or HD in there somewhere.
If there is one concern about wireless speaker systems it is fidelity. You don't want to pay 10x's what it would cost for a cable just to find out that the signal has been changed or there is distortion or interference. Sunfire is using a 2.4Ghz signal with 17ms latency. Sunfire claims the solution has 16 bit resolution and samples at 48hz. The transmission is digital which Sunfire says will provide "100 percent accuracy." That should be true if there isn't any interference or other problems. We'd like to see this claim tested. What we don't know is how many channels Sunfire has the option of using or if it sends out redundant signals on many channels.
One thing that surprised us at first was how the units were price individually. At $80 a pop, why would you want just one? Well, you would if you have a single subwoofer output and plan on using multiple subs. But, again, for a product that is currently shipping, information on how it works is woefully thin. The press material suggests that one transmitter can pair with two receivers but we're wondering why? Why can't you pair as many receivers as you want? Plus, what about those with multiple subwoofer outs with individual calibration for the subs at their receiver? Can you use more than one transmitter in a room? We don't know. Usually we'd take a look at the manual (if there is one) to get our answers or at least a look at the back panel. With the Sunfire Subwoofer Wireless Kit, the manual link downloads a PDF for their Dynamic Series Subwoofers - decidedly NOT the kit.
Sunfire suggests a 25 foot maximum distance which sounds about right to us. Expect less than that unless you can ensure a direct line-of-sight between the transmitter and receiver. Also realize that 2.4Ghz is susceptible to interference from such things as microwaves, cordless phones, or even your wireless network. Without more information on how Sunfire is dealing with these sources of interference, we'd suggest keeping your receipt.
For more information, please visit www.sunfire.com.
Recent Forum Posts:
dmusoke posts on May 27, 2011 16:02
One heck of a latency spec - 34ms total between the transmitter and receiver. If you don't have a room calibration program in your pre-pro such as ARC or Audessy to take these delays in to account, i believe you're in for a world of hurt:o.
ratso posts on May 27, 2011 14:16
scott911;812604
I wonder how successful this concpt has been.
If someone can't be bothered to run a cable - really not that hard if you're at all motivated, even in an appartment - I wonder if they'd be inclinde to want to put the unit anywhere other than right next to their stereo stack in the first place.
what was supposed to be a simple cable run through my living room walls for my surrounds turned into a 6 hour nightmare for my installers. and they are professionals. so be "bothered" to spend hours tearing through walls, fishing wire, drywall repair, and painting or $80 for a box that you plug into the wall? yeaahhh, i can't be bothered.
highfigh posts on May 25, 2011 20:42
scott911;812604
If the sub is in a different location and the electrical system isn't great, ground loops are common and for this price, it may be better to use this instead of a ground loop isolator. I'm doing a job now where the sub wouldn't work next to the electronics because A) the cabinet is in the informal dining area and the speakers are 40' away, next to the TV. The wall houses a fireplace and comes forward from the double doors to the screened-in porch by about 30", so I put a sub in the wall (in a box) to the right of the fireplace. It worked great until the client decided the fan noise from the distributed audio amp was too loud and she asked me to move it. That receptacle is on the same breaker as the rest of the system at my request to the electrician, who understands why it's important. Guess what- instant ground loop and hum. With the isolator, it's OK but I lost a lot of signal level and it has to go 35', across all kinds of old electrical wiring, with no way to run it in conduit or separate the cable. I'm going to pick up one of these and see if it will work in that application, so I can get the results I had before.
sholling posts on May 25, 2011 17:51
Some homes just don't lend themselves to a hard wired run and for us a wireless solution works great. I'm using the Outlaw OWA3 which works just fine. Because it has three stereo channels you can have multiple transmitters driving 1-3 independently calibrated subs or subs and powered surrounds.
scott911 posts on May 25, 2011 09:00
