Use, Macros and Conclusion
Hey, Look at That - Macros!
The Logitech Harmony software now
includes a method of adding "Sequences" which is Logitechian for
"Macros". Sequences are created in a separate area of the software
and can be selected much like a device. Each sequence is limited to 5 device
steps, and there are no options for delays. This is a step in the right
direction and it provides at least basic support for those who would like to
run multiple commands across different devices while not leaving an activity
(for example, muting the audio while activating closed captioning on a DVD
player).
Timeout!
Logitech apparently believes that programming a remote control is akin to entering in your Social Security number or performing sensitive financial transactions online... or so I would think by the relatively short time-out each session is given. I'm sure they have a legitimate reason (no I'm not) but in either case I was nailed more than once for not saving when I decided to walk away from the desk for a few minutes to attend to another task. When I returned the system lost everything I had just done and informed me that I had to login again. This seems unnecessary and, I imagine, is going to be a real pain for most users. At least store the session variables.
Use and Functionality
The Harmony is as good as the
equipment you use in your home theater. For use with products like the Vizio
display, which do not have dedicated input IR codes, the results can be
unpredictable and frustrating at times. Thankfully, the Harmony One has its
useful 'Help' button which quickly fixes any issues users may have with their
systems by refiring some or all of the macro commands until the system works.
The only thing I'd wish for was a smart on-board processor that recognized
repeated uses of the 'Help' command and factored it into future macro
executions. For example, the controller had a hard time reaching my DVD player
during discrete On/Off commands, and so the player is often left On or Off
unintentionally when an Activity or shut-down macro is issued. Since this has
happened several times, it would do no harm for the Harmony to execute the Off
command (or On command during boot-up) several times to ensure compliance. For
toggling power controls this isn't useful, but for those products which have
dedicated inputs and power controls the results would be better (and the remote
would truly be intelligent). I found that most of my IR difficulties were a
factor of how easy my equipment was to control, and not necessarily the fault
of the Harmony One.
One of the things users, especially novices, will need to reinforce in their minds, is the necessity to keep the remote pointed at the equipment during the Activity start-up process. This is because the Harmony One has no provision for RF functions. Disappointingly the best remote (my opinion) in Logitech's entire line-up is without the ability to send out RF commands to a compatible base station. This is something I'd love to see added into a future model (the Harmony Two?) but as of CEDIA, Logitech hasn't yet indicated that it will be adding RF control to this style of remote anytime soon. There is also no indication that WiFi, barring any surprise announcements to the contrary, will be on the radar in any short amount of time.
Using the Harmony once programmed is easy and I never felt that I was missing any commands or tactile buttons. In fact, the remote seems eerily "psychic" in its ability to deliver the controls you'll need for everyday use. For those less common or obvious commands, the interface has matured enough to allow users to add in their own controls and tell the remote where to place them on the screen. This is excellent and truly makes for a flexible and successful remote control.
Conclusions
About Logitech
Logitech is a world
leader in personal peripherals, driving innovation in PC navigation, Internet
communications, digital music, home-entertainment control, gaming and wireless
devices. Founded in 1981, Logitech International is a Swiss public company
traded on the SWX Swiss Exchange (LOGN) and on the Nasdaq Global Select Market
(LOGI).
— Excellent
— Very Good
— Good
— Fair
— Poor
| Metric | Rating |
| Performance | ![]() ![]() ![]() ![]() |
| Build Quality | ![]() ![]() ![]() ![]() ![]() |
| Ergonomics & Usability | ![]() ![]() ![]() ![]() ![]() |
| Ease of Setup/Programming/Integration | ![]() ![]() ![]() ![]() |
| Features | ![]() ![]() ![]() |
| Fit and Finish | ![]() ![]() ![]() ![]() ![]() |
| Value | ![]() ![]() ![]() |
See also:
Recent Forum Posts:
Recently I came to know that there is a website named AmazingWatcher.Com which is a free website that will watch items for you on Amazon and let you know when amazon has them in stock at regular retail price.It got so awesome!
Good luck everybody!
Cheaper and better. Both.
Last I saw, the RF-20 + blaster combo was $75. This is RF, and I predict that I will never go back to IR-only.
My audioholics review [forums.audioholics.com]
FirstReflection;460091
You definitely need to look down at the remote to make sure you hit the correct touch screen button, so for a future model, I would love for there to be some sort of physical indicator - such as a very slight ridge between each of the buttons. Just enough to give a physical indication of where each button lies on the touch screen.
This has to be the part I hated the most about my Harmony.
I do not want to look at the remote, I want to look at the screen. I can pick up any of my other remotes and simply by touch do all the basic commands I use most often. But not the Harmony, I was always having to look at it and make sure it was in the right "activity", make sure I was hitting the right "button". I think I spent more time looking at that damn remote in an evening then I spent looking at my TV
