You are here: Home Pro Reviews A/V Receivers Yamaha RX-V4600 Receiver Review RX-V4600 Power Measurements and Analysis - Part 2
by Gene DellaSala last modified December 07, 2006
Amplifier Output Impedance and Damping Factor Measurements
Test Notes:
  • All amplifier power references were conducted under load and compared to open circuit voltages to determine output impedance as per our Basic Amplifier Measurement Techniques Guidelines.
  • All max power tests represent 0.1% THD at 1kHz as a reference
  • Distortion at 20Hz and 20kHz was also checked to ensure THD was always under 1%
  • Line Voltage was monitored to ensure no sag was present (115Vrms recorded)
  • Reference 1 watt = 2.82Vrms into an 8ohm load
RX-V4600 power measurement 1
The output impedance of the RX-V4600 was commendably low for a single pair transistor push-pull amplifier stage. It also appeared to be more uniform than what we have seen in the RX-V2500 indicating that the series output inductor after the last output stage to increase stability may have been eliminated or its value reduced.
RX-V4600 power 2
Damping factor remained stable and uniform at into an 8-ohm and 4-ohm load. Based on the principle of voltage divider, we see roughly a little less than ½ the damping factor for the 4-ohm load. Ideally it would have been exactly ½, but this is certainly better performance than we have seen with the RX-V2500. The damping factor remained close to our minimum recommendation of 50. For more information on this topic, read our article on Damping Factor: Effects on System Response .
RX-V4600 power 3
RX-V4600 power 4
Amplifier output impedance and damping factor at full power (128wpc 8-ohms, 200wpc 4-ohms; respectively) remained highly linear. The RX-V4600 excelled on this test in comparison to the RX-V2500.
