You are here: Home Pro Reviews A/V Receivers Sony STR-DG810 AV Receiver
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Gary Benfield last modified May 23, 2008
  • Product Name: STR-DG810 AV Receiver
  • Manufacturer: Sony Electronics
  • Review Date: January 27, 2008 11:02
  • MSRP: $399
Specifications
  • 110 watts x 6 channels (8 Ohms, THD 1.0%)
  • Dolby Digital EX
  • DTS ES, DTS 96/24, DTS NEO:6
  • Dolby Pro Logic, Dolby Pro Logic IIx
  • 6 DSP fields: 3 cinema, 3 music
  • BRAVIA Theatre Sync
  • 30 AM/ 30 FM radio station presets
  • 30 XM Radio presets
  • Front Panel A/V Input
  • 2 Optical Audio Inputs, 1 Coaxial Audio Input
  • 3 HD HDMI video inputs/ 1 output
  • 3 HD component video inputs/ 1 output
  • Single Zone
  • Dimensions: 17" (W) x 6 1/2" (H) x 12 3/8" (D)
  • Weight: 17 pounds, 3 ounces
  • Warranty: 2 years Parts & Labor
Executive Overview
If you are like me, you may have acquired more high definition sources than your current AV receiver can accommodate. My case isn't made any better by the fact that my projector is just old enough to not offer any HDMI input. What to do?  Well, for under $300, Sony now offers the STR-DG810 AV receiver that will allow you to connect up to three new HDMI-based high definition sources via HDMI or even use the three component video inputs for game systems or other standard definition or HD sources.
STRDG-810 Rear Panel
As we mentioned, the Sony STR-DG810 offers you an integrated 3x1 HDMI switcher as well as three component video inputs. These HDMI inputs can accept resolutions up to 1080p/60p and will successfully pass-through up to 8 channel of linear PCM audio to a display. You can also tell the Sony to disiable the HDMI audio so your TV only receives video signals from the receiver. You have three assignable digital audio inputs to choose from, two optical and one coaxial.  Sony rates the receiver at 110 watts per each of its 6 channels.  The rear panel is rounded out with the usual suspects including AM and FM antennae connectors, 5-way speaker binding posts (for A speakers and spring clips for B), XM radio port, DMPort (more details below), and a subwoofer output to connect a powered subwoofer.  Onboard decoders can handle Dolby Digital EX, DTX ES, , DTS 96/24, DTS NEO:6, Dolby Pro Logic IIX, Dolby Pro Logic II, and Dolby Pro Logic playback for all your favorite surround sound sources.
Sony's Digital Media Port gives you the ability to connect and control just about any of your favorite digital devices with the corresponding optional attachment.  Current DMP accessories include a Wi-Fi PC Client Ready device for streaming music from your PC, a Bluetooth device, and audio docking stations compatible with Network Walkman and iPods.  BRAVIA Theatre Sync will also allow simple, easy operation of select other Sony products like LCD TVs and DVD players.  It is also XM ready and equipped with 5.1 Neural decoding
While the ability to connect three HDMI high definition sources is a great capability, there were some legacy capabilities missing from this receiver.  For one, there are no multi-channel analog audio inputs included on this receiver's rear panel, so multi-channel music lovers should make note of that limitation.  Also, the receiver has no S-video inputs, so if you have older components (say a VCR or 480i DVD player) you'll be forced to connect them using the less-desirable composite (yellow) video inputs.
All in all, the ability to connect three HDMI components makes this receiver worth checking out, provided you don't require 5.1 analogue inputs or the ability to decode HDMI audio. If you're even thinking about adding a high definition DVD player to your system in the future, then this receiver is probably worth adding to your short list to audition.
Recent Forum Posts:
lsiberian posts on March 29, 2009 19:42
tom67;545171
Its the experts that test them at Audioholics and CNET you disagree with...Like I said I would rather have a Yamaha, Denon etal....user reviews are questionable as users tend to validate their own choices and the limited mix of people on any forum render the opinions anecdotal...They no doubt love the Sony stuff on their forum and a some other general ones....beyond that, every so often you have to revisit some of these companies as some change for the better when you arent looking....believe me, I'm no Sony audio fan based on their past offerings
http://www.audioholics.com/reviews/receivers/sony-str-da7100es-receiver-review/ [audioholics.com]
Is the only review of a Sony AH even has. First looks aren't reviews.
I tend to go with User reviews over Magazine reviews which rarely are negative on anything. Including AH.
User reviews can be a very good source for information. Especially for issues. I suggest a visit to AVS for any receiver. They usually have a dedicated thread.
But we don't know true quality for years. I could say my receiver is great, but in reality it could break in 3 years and actually be a bad receiver.
tom67 posts on March 29, 2009 17:12
lsiberian posts on March 29, 2009 15:28
tom67;545052
nope....Sonys have better connectivity than Yamaha etal at this point for less money....there is anti Sony bias here not based on fact
http://reviews.cnet.com/best-value-av-receivers/?tag=centerColumnArea1.1 [reviews.cnet.com]
I disagree strongly. Check the user reviews. The Yamaha isthe best of the entire list based on user reviews. Sony also makes one of the least reliable AVRs in my experience.
tom67 posts on March 29, 2009 12:31
have always been a Yamaha fan but might take a look now....New Yamahas have also gone on a diet and the RXV 565 now weighs 18 lbs.....
http://reviews.cnet.com/home-theater-receivers/?tag=leftColumnArea1.1 [reviews.cnet.com]
tom67 posts on March 29, 2009 12:27
