You are here: Home Pro Reviews A/V Receivers Pioneer VSX-94TXH 7.1 A/V Receiver with HDMI 1.3a
by Clint DeBoer last modified April 28, 2008
Contributors: Gene DellaSala
Pioneer VSX-94TXH 7.1 Receiver
  • Product Name: VSX-94TXH AV Receiver
  • Manufacturer: Pioneer Electronics
  • Value Rating: StarStarStarhalf-star
  • Review Date: April 28, 2008 02:55
  • MSRP: $ 1800
Specifications
HD Audio Support: Dolby TrueHD, Dolby Digital Plus, dts-HD Master Audio
DSP: 3rd Gen. Analog Devices SHARC + 48-Bit Freescale DSP
Power Ratings: 7 x 140 watts per channel (8 ohms, 20 Hz-20 kHz, <.09%THD)
Audio DAC: 192 kHz/24bit DAC x 7
HDMI: 1.3a with support for Deep Color, 24p and SACD/DVD-Audio support
Crossover: 50, 80, 100, 150, 200Hz
Remote: Programmable/learning remote (glow keys, not backlit)
Video Inputs: 4 x HDMI (1.3); 3 x Component Video (100MHz); 7 sets composite and S-video inputs
Video Outputs: 100MHz Component video output, 3 composite/S-video outputs, Multi-Zone composite video output
Audio Inputs: 7.1 multi-channel inputs, 6 assignable digital inputs (4 optical, 2 coaxial), 8 analog inputs
Audio Outputs: 2 optical digital outputs, multi-zone stereo pre-amp level audio outputs, 7.1 preamp outputs
Additional Connections: RS-232C port for third party control Systems, remote I/O ports, 2 assignable +12V triggers
Dimensions: 16 9/16" x 7 3/8" x 18 1/16"
Weight: 41.1 lbs
  • THX Select2 Certification
  • 4 x HDMI 1.3a inputs
  • Deep Color, xvYCC Support
  • RS-232C control & dual 12V triggers
  • Home Media Gallery system
  • No Zone 2/3 Remote
  • Using S/PDIF source alongside HDMI video requires front panel setting
  • Cluttered remote control w/ no backlight
  • Non-removable power cord
  • Confusing Setup/Menu interface
Introduction
The last Pioneer receiver review I personally did was in 2005 on an entry-level product (the VSX-815) which struck me as a good balance between available features and power. It will seem pretty obvious when I say that this flagship Elite AV receiver product trumps my last experience by quite a bit. It also, however brings a certain amount of expectation. Being a top of the line model, the VSX-94TXH has a lot of competition and is going to need to distance itself in some areas before being crowned the leader in any particular department.
Recent Forum Posts:
TheFactor posts on May 08, 2008 01:56
Wow thats a bummer, I think my surge protector has a in and out for cable and figured I didnt need it and was afraid it might effect the picture but after what you said I might be looking a little closer at that. I think the warranty might be a good idea after all.
Thunder18 posts on May 07, 2008 22:40
No problem. Great feedback on the receiver by the way.
In my experience i've always bought the warranty and the only time I used it is when my receiver was electrocuted. The warranty covered that replacement and several other warranties covered my TV, PS2 and powered subwoofer that all received the power surge from the receiver. (Surge came over the cable line, traveled to my receiver via the s-video cable which subsequently sent it to all my other equipment) The only item that didn't have a powered subwoofer and Circuit city fixed it for a nominal charge. This is all because I didn't have a surge protector that protected the 2 coax inputs going to my cable box.
TheFactor posts on May 07, 2008 21:45
Thanks again Thunder18 For posting that link review for me on my original thread and your input had a lot to do with my Decision and I couldnt be happier. Thanks again
TheFactor posts on May 07, 2008 21:37
Now I just have to decide if I want to spend another 149 dollars for a four year if they cant fix it they'll replace it warranty. Im a little gun shy sorta speak from previous receivers so I might get it just for a peice of mind .
TheFactor posts on May 07, 2008 21:31
Thunder18;410217
Congrats. Did the audioholics review sway you any? I really like that receiver, but I just can't seem to stand the remote ;-p
Ah well, from the looks of the other post, it looks like you're happy with it. Good luck with this one. I've had 4 Pioneer receivers and none of them have ever had a lick of trouble save the one that was electrocuted.
Thanks and actually the review made me lean towards it more, I like the power it has and how cool it runs. I put it and my paradigms threw some tests for sure by that I mean listening to it louder than I normally would, im in a house so I can crank it up when im in the mood and probably dont tick off to many of my neighbors lol im pretty considerate though after 10 but anyway my point is after a 2 hour movie with the volume loud enough to were I was reaching for the remote so I wouldnt go deaf and the 94 was just warm. All my other receivers were pretty hot by then especially above the receiver on the audio rack was toasty hot with others but not the 94 it was just warm. Im very impressed with the sound quality and picture to. I think what sold me on the review was the statement at the end " if you want a powerhouse look no further " I think with out going seperates this reciever should should keep me happy for a long time and it makes me even happier to know your pioneers have been good to ya actually im getting use to the remote its not that bad and im learning were all the important buttons are on it like for quick access for speaker level ect, thx, adv surround and so on can easliy be navigated in the dark movie mode now : ).
