You are here: Home Pro Reviews A/V Receivers Pioneer VSX-516 Receiver Review
by Tom Andry last modified May 31, 2007
  • Product Name: VSX-516 Receiver
  • Manufacturer: Pioneer
  • Review Date: May 03, 2006 20:00
  • MSRP: $ 199
Specifications
Power
  • Power Amplifier Design - Pioneer Hybrid Amplifier Design
  • Surround Power - 100W per channel (8 ohms, 1kHz, 1.0% THD) (front); 100W (8 ohms, 1kHz, 1.0% THD) (center); 100W per channel (8 ohms, 1kHz, 1.0% THD) (surround);100W per channel (8 ohms, 1kHz, 1.0% THD) (surround back)
  • Stereo Power - Continuous average power output of 100 watts at 8 ohms, from 20Hz to 20kHz with no more than 0.7% total harmonic distortion
Digital Decoding & Processing
  • Digital Engine - New Freescale 180MIPS Processing DSP
  • DSPs - Dolby(R) Digital 5.1, Dolby Digital EX, DTS(R) 5.1, DTS-ES Discrete 6.1, DTS 96/24, DTS Neo:6, Pro-Logic II, WMA9 Pro, 9 Advanced Surround Modes, 7 Channel Stereo, Virtual Surround Back, Mid-night Listening, Dialogue Enhancement, Loudness
  • Calibration - Speaker Configuration, Speaker Size, Speaker Level, Speaker Distance, Acoustic Equalization
  • Analog to Digital Conversion - 96kHz / 24-Bit
  • Digital Analog Conversion (DAC) - 192kHz / 24-Bit
Connectivity
  • Audio (Tuner Included) / Video Input - 3 Audio / 3 Audio Video
  • Audio/Video Output - 1 Audio / 1 Audio Video / 1 Video
  • Digital Inputs - 3 (2 Coaxical, 1 Optical)
  • Optical In - 1
  • Coaxial In - 2
  • Multi-Channel Input - Yes
  • Audio Preamp Output - Yes
  • Composite Video Input - Yes
  • Composite Video Output - Yes
  • Component Video Input - 2
  • Component Video Output - 1
  • Headphone Output - 1
Conveniences
  • FL Dimmer - 4 Steps
  • On-Screen Display - Yes
  • Remote Type - Easy-to-use SR Remote Capable of Operating Pioneer’s DVD Players and Recorders
Dimensions
  • Dimensions (inches) - 16-9/16x6-1/4x13-7/8 inches (WxHxD)
  • Weight - 19lbs. 13oz.
  • Component Switching
  • Bi-ampable/wireable
  • Plenty of power
  • 5.1 inputs
  • Near useless automatic setup
  • Can’t see volume display from a distance
Introduction
Budget receivers… I remember a time not so long ago that budget was synonymous with serious deficiencies. When I bought my first receiver, budget meant the difference between analogue and digital. I was broke so I had to go analogue which meant my receiver was hopelessly outdated almost immediately. Now, budget is the difference between multiple zones and number and type of connections. Sure, amp quality and power handling is a factor as well, but for most of us, there isn’t a receiver out there that can’t push our 8-ohm speakers to ear bleeding levels. You may have to do with out the automatic room calibration but the majority of reports that I’ve read indicate that such technology isn’t quite as refined as the manufacturers would have you believe. What does this boil down to? For many of us, it is possible to run around your home theater and count the number and types of connections and find a receiver that matches. Paying for additional zones and connection types (DVI, HDMI), scaling, upconverting, and other functionality may prevent premature obsolescence, but I know that for many, home theater equipment doesn’t change for a very long time following a purchase.
