Pioneer VSX-1021-K Receiver First Look Preview
Pioneer VSX-1021-K
Pioneer VSX-1021-K
  • Product Name: VSX-1021-K Receiver
  • Manufacturer: Pioneer
  • Review Date: March 11, 2011 02:30
  • MSRP: $549
Specifications
AMPLIFICATION
120W x 7 (1 kHz, THD 0.05% @ 8 ohms)
90W x 7 (20 Hz – 20 kHz, THD 0.08% @ 8 ohms FTC)
AUDIO FEATURES
Dolby® TrueHD / Dolby Pro Logic IIz / Dolby Digital EX / Dolby Digital Plus
DTS-HD® Master Audio / DTS-ES / DTS Neo:6
Digital Core Engine with Texas Instruments AureusTM DSP
192 kHz/24-bit DAC(S)
96 kHz / 24-Bit PC Audio playback(FLAC)
192 kHz / 24-Bit PC Audio playback(WAV)
Pioneer Advanced MCACC Room Calibration
  • 3D Time Axis Measurement
  • Polarity Check
  • Automatic Crossover Detection
  • Reverb Before and After Calibration Results (OSD or AVNavigator)
  • Standing Wave Control
Pioneer Sound Enhancements
  • Phase Control
  • Phase Control Plus
  • PQLS Bit-stream
  • Sound Retriever (Multi-channel)
  • Sound Retriever AIR Wide Surround Movie & Music
  • Front Stage Surround Advance Wide & Focus
  • Virtual Height & Surround Back
  • Auto Level Control (Multi-channel)
  • Advanced Surround (16 + 1 Modes)
  • Headphones Surround
VIDEO FEATURES
HDMI Latest Features
  • 3D Ready (Blu-ray Disc® and Broadcast)
  • Audio Return Channel
  • Deep Color and x.v.Color
  • 1080p Compatible
Anchor Bay® 1080p Video Scaler
Video Conversion to HDMI
Pioneer Advanced Video Adjust
HOME NETWORK FEATURES
AirPlay
DLNA Certified® (1.5)
Internet Radio with vTuner
Pioneer iControlAV21
  • A/V Receiver and Blu-ray Disc player control from iPad, iPhone, iPod touch
  • Free via the App Stores
Pioneer Air Jam App
  • Connects via Bluetooth to share music and create playlists
  • Free via the App Store (Optional AS-BT200 Bluetooth Adapter Required)
Firmware Upgrade via Ethernet or USB
CONNECTIVITY
Compatible with iPod, iPhone, iPad Front USB Input
  • Charges iPod, iPhone, iPad
  • Combination USB / Composite Video Cable Supplied
HDMI Terminals (5 In / 1 Out)
Ethernet Port
Wireless LAN Converter Ready (Optional AS-WL300)
Front AV Inputs
Bluetooth® Port (Optional AS-BT200 or AS-BT100 adapter required)
Component Video Terminals (2 In / 1 Out)
Digital Inputs (2 Coaxial, 2 Optical)
Analog AV Inputs (5 AV, 2 Audio)
Sirius Satellite ready2
Zone 2 AV Outputs
Subwoofer Pre-Out
Large Speaker Terminals (FL/FR/C/SR/SL/SBR/SBL)
CONVENIENCE
AVNavigator System Set-Up CD-ROM
Full Color Graphic User Interface (GUI)
Album Art Via USB/Ethernet
Auto Power Down
Power Save for HDMI Standby Through
Sleep Timer
Learning Remote Control
Executive Overview
VSX-1021-K_iPad_CableManufacturers are jumping on the AirPlay bandwagon like Apple was handing out BBQ sauce at a rib cookoff or free golf shirts on day three of CES. They literally can't get the products out of the door fast enough. Pioneer is the latest to hop onboard the Apple iWagon with their latest round of receivers. The new '21 series consist of the VSX-521 ($249), VSX-821 ($349), VSX-921 ($449), and the VSX-1021. We'll be taking a close look at the $549 VSX-1021 today.
Pioneer was quick to support Apple with their receivers and, in many cases, they are still very much ahead of the curve. While other manufacturers will require the purchase of a dock for full iPod/iPhone/iPad support, Pioneer has been providing a free cable and out-of-the-box Made for iPhone certifications with their receivers. Adding AirPlay, the ability to stream content from your Apple iWhatever to the receiver wirelessly, was a no brainer... and inevitable from our standpoint. But that's not the only tool in the VSX-1021 chest.
Let's start with the basics. The Pioneer VSX-1021 is a 7.1 channel receiver boasting 90 watts per channel or 120 watts if you don't mind your measurements being flimsy and artificially inflated. Don't worry, 90 watts will be plenty for most consumer applications and speakers. The VSX-1021 supports all the latest HD audio decoding, sports HDMI 1.4a connections, and has high quality 192kHz/24-bit DACs. The receiver will pass all the latest 3D formats and also supports Deep Color and Audio Return Channel. Noticeably absent from the feature list is HDMI pass-thru. But we've learned that just because a feature isn't listed doesn't mean it isn't included. It's like a manufacturer Easter egg. We'll have to wait and see on that one since it seems like it should be included. Edit - Found it. HDMI Standby Pass-thru is listed under "Convenience" rather than "HDMI Latest Features."
Anchor Bay will provide scaling duties up to 1080p on the VSX-1021 and all video sources can be upconverted to HDMI. Along with AirPlay, DLNA 1.5 certification is present which allows you to stream from compatible networked computers and drives (for you Mac guys, check out an application for Mac OS X called Playback). The Pioneer will stream Internet Radio with VTuner and can be updated over the Internet. Pioneer, like just about everyone else, has released their own remote control app called iControlAV21 (it just trickles off the tongue, doesn't it?). With it you can control not only the receiver but your Pioneer Blu-ray player. It, of course, is free. Pioneer as also added a second app called Air Jam. With it you can connect via Bluetooth to share music and create playlists. For this to work, however, you'll need to buy the optional AS-BT200 Bluetooth Adapter. With Air Jam, up to four devices can be paired via Bluetooth. Once connected, each user can cue songs from their music libraries to create a collective playlist to play back on their A/V Receiver. Each connected device will display the list of songs added by all users and the device each song will play from. The Air Jam App will also keep the list of songs from each session on each device for future purchase through the iTunes Store.
VSX-1021_Back_large
But we digress. There are five HDMI inputs (all on the back) and one output. While there are only seven channels of amplification, there are nine pairs of five-way binding posts on the back for easily changing configurations in the menu system without switching out cables. The VSX-1021 has two component video inputs and one output plus two each coaxial and optical digital audio inputs. Of course there an a slew of analogue audio and video inputs including RCA outputs for Zone 2. Absent are any analogue inputs or outputs for integrating legacy gear or external amplifiers. This isn't really all that much of a knock against a receiver at this price point. Now the setup menu... that we can knock (Pioneer's menu systems are atrocious and notoriously anemic at this price).
Pioneer has their own MCACC auto-calibration system which is included in the VSX-1021. It supports Dolby ProLogic IIz height channels which you can allocate your rear channels to if you're planning on running a 5.1 system. The included iPod/iPhone/iPad cable streams video as well as audio and charges the device at the same time. One of the more unique features is an AVNavigator System Set-Up CD-ROM. Designed to simplify the physical and software setup of the receiver, AVNavigator is a suite of PC applications, consisting of two key applications, Wiring Navi and the Interactive Manual.
  • Wiring Navi – Users simply answer a series of questions about the hardware connected to the system and the application will automatically update the receiver with all of the correct settings.
  • Interactive Manual – Once the receiver is connected using the Wiring Navi set up, the Interactive Manual application provides a linked two-way interactive manual giving users a way to quickly learn about all of the new features of the AV receiver (i.e. a push of the ALC button on the front of the receiver will take the user directly to the portion of the manual that explains the Automatic Level Control feature). Alternately, users can click on a section of the owner’s manual and the feature of the receiver will automatically activate (i.e. when the user clicks on the FL Dimmer section of the owner’s manual, the Front Panel Display of the receiver will dim).
The Pioneer VSX-1021 is definitely full featured for its price point. Like other recent Pioneer offerings, the VSX-1021 is pushing hard to connect to your hand held and portable devices. At the same time they are providing the buzzword features that consumers are expecting. As a budget offering, the VSX-1021 is very attractive. With Apple AirPlay, Made for iPhone certification, Dobly ProLogic IIz, and streaming of Internet Radio and networked sources, the VSX-1021 should turn heads. Add to that seven channels of amplification, Anchor Bay video scaling, 192 kHz/24-bit DACs, and MCACC room calibration not to mention an interactive manual for setting up and learning your new receiver, and there is a lot to be interested in. We're looking forward to getting our hands on one of these when they ship sometime this month.
For more information, please visit www.pioneerelectronics.com.
rsquared66 posts on May 11, 2011 23:25
bullman1785;808981
Amazon delivered my VSX-1021 on late Friday. I spent Friday replacing my trusty Yamaha receiver with the new Pioneer.
Initial thoughts:
  1. Sound quality is excellent. My old speakers seem to be clearer!
  2. Airplay is fantastic and works like a charm
  3. Took a bit longer to get the ARC - Audio Return Channel to work with my Panasonic Plasma and receiver
  4. Getting my harmony one to work with this is about 90% done. I think Logitech has to update their database with a few more tweaks. For example, when I turn on the receiver using Harmony One, it cycles through the inputs before settling on a wrong one Need to get this sorted out with either Logitech or Pioneer
  5. Haven't been able to get HDMI Pass-Through to work yet.
  6. More to Follow as I work through it...
Did you figure out HDMI Pass-Through?
I have a Panasonic 55gt Plasma connect to my 1021 by ARC HDMI and can not get it to work either....
by the way how do you get 1021 in standby....is it just turn off the receiver?
is it worth buy the Harmony one....?
thanks bullman1785
bullman1785 posts on May 02, 2011 10:51
Initial thoughts:
mdbrown posts on March 30, 2011 20:24
Can't speak for the 1021-k but I do have an Elite VSX-30 that features advanced MCACC. It calibrates for 1 spot only. It is superior to Audyssey though as it allows full manual adjustments once the process has run. It gives you a graphic picture of the response curves and shows all the adjustments it has made so you can change them if you need to.
My Onkyo had Audyssey 2EQ and it would put out a single test tone per speaker, the advanced MCACC on this unit puts out several test tones in different frequency bands to get a more accurate reading of the rooms acoustics. It also compensates for standing waves and reverberation.
All in all I'll take it any day over audyssey 2eq. As for ALC, I prefer it to audyssey. Have not heard dolbys volume solution but I have heard form multiple sources that it is better than both mcacc and audyssey.
Sugarbear posts on March 14, 2011 22:29
MapleSyrup;799792
I appreciate the opinion matelli but I guess what I want to know is does the Pioneer offer anything along the lines of dynamic and volume EQs in its calibrations. Also, does the MCACC, good sofware from my understanding, calibrate only one sweet spot of multiple. My understanding is that this is a significant difference in audiobility.
Lack of Audyssey is also my biggest hangup with Pioneer receivers. I like them a ton, but I can't bring myself to buy an AVR without Audyssey...
Ziontrain posts on March 12, 2011 16:29
zieglj01;799505
If so, then it will be interesting.
Ditto, is all I can say!
Submit News!
