You are here: Home Pro Reviews A/V Receivers Onkyo TX-SR805 AV Receiver Review TX-SR805 Conclusions and Recommendations
by david last modified November 13, 2007
The Onkyo TX-SR805 represents the current pinnacle of value at its price point. It sounds good, decodes all the latest HD audio codecs, sports a large power supply, has an impressive feature set, THX Ultra2 certification, and Audyssey MultEQ at a price well below what the competition offers. This high level of value is not just limited to this particular model; Onkyo has spread value and features across their entire product line with some of the most notable models and key features listed below at various price points:
  • Audyssey 2EQ starts at $379 with the TX-SR505
  • Dolby TrueHD and DTS MA decoding starts with the TX-SR605 at $599
  • THX Select2 certification and Audyssey MultEQ XT starts at $899 with the TX-SR705
  • THX Ultra2 certification starts at $1099 with the TX-SR805
No longer limited to expensive top end offerings, every one of the new xx5 series receivers Onkyo has released includes some form of Audyssey room correction and Onkyo has even started including basic Audyssey EQ functionality on newly released HTiB offerings. Starting with the TX-SR505 receiver, Audyssey 2EQ is included and sells for $299 at retail. Depending on what Onkyo decides to do when the entry level TX-SR304 is updated to the TX-SR305, it may well be as low as $199 to get basic Audyssey acoustic room correction into even entry level home theater components. It would be extremely hard to beat that.
The design approach applied to the TX-SR805 is clearly geared more for audio performance. All of the audio processing is cutting edge and the amplifier section walks all over the competition. Video processing is adequate, but is not by any stretch cutting edge. As I previously stated, if one wants or needs the additional video performance, the TX-SR875 is looks to be everything that the TX-SR805 is with the addition of HQV 1080p video processing.
The good news with the TX-SR805, while the video processing is limited, it conforms to the latest enhancements that HDMI 1.3a offers, so it will not bottleneck system performance as 1080p and high bit Deep Color become the norm.
Based purely on audio quality of the receiver itself, the TX-SR805 will easily compete with any offering at or near its price. With lossless decoding and Audyssey engaged, nothing comparably priced that does not include HD audio or Audyssey will even come close.
Onkyo has clearly upped the ante with the TX-SR805. With the level of audio performance, HD audio decoding, high build quality, THX Ultra2 certification, and the myriad of cutting edge features, the TX-SR805 is highly recommended.
Onkyo USA Corporation
18 Park Way
Upper Saddle River, New Jersey 07458
800 229-1687
Fax: 201-785-2650
www.onkyousa.com
  • StarStarStar — Good
  • StarStar — Fair
  • Star — Poor
MetricRating
Multi-channel Audio PerformanceStarStarStarStarStar
Two-channel Audio PerformanceStarStarStarStarStar
Video ProcessingStarStarStar
FeaturesStarStarStarStarStar
Remote ControlStarStarStarStar
ValueStarStarStarStarStar
Buy Now
Recent Forum Posts:
Lordoftherings posts on November 17, 2009 10:43
^ That's me!, that's me!, that's me!... ...and you're very welcome Eugen.
> But I was just doing my job.
* Anyway, I know that you won't be able to read this, but still, it is good news,
and I'm very glad for you & your friend.
EugenT posts on November 17, 2009 09:56
Just wanted to thank those people who recommended the fan combination below (in this thread).
Me and a friend both own TX-SR805, and this fan made a huge difference on our receivers. Receivers run cool and the fans are nearly silent at 9V (voltage is adjustable between 6 and 12V - could be 4.5v on the lower limit, have to check that).
http://www.buyextras.com/evavcoblfanf.html [buyextras.com]
ranjosh posts on July 03, 2009 21:04
thanks for the help
Lordoftherings posts on June 28, 2009 21:07
bandphan;588528
Run a full set of the Sonus Faber Minima Amator @ 90dbs for a few minutes
4 ohm with 1 ohm dips, 82bd 1w 1m, but sound fantastic
Thanks for the tip, I'll check who carry them near the area where I live..
If I can get get my hands on these, that should take care of my strange behaviour lately.
bandphan posts on June 28, 2009 19:59
Lordoftherings;588511
I've been acting very strange recently, and it is related directly to my Onkyo TX-SR805,
which is putting out less heat than usual! (About a couple degrees less.)
So I'm worry about the coming of next winter. Will it affect my heating bills in the upward direction?
I'm really counting on my 805 to keep me warm comes winter, and to save me the most possible on my my heating bills.
Anyone with a solution? That would be very appreciated.
Thanks,
Bob
P.S. By the way, I did remove the two internal fans, but it did not raise the temperature!
