SR7002 RC8001SR Remote and HD Audio Support
The RC8001SR is a nice overall
learning remote. It features a backlit LCD screen with 5 soft keys that control
additional features (up to 4 pages per device). These soft pages can support up
to 5 additional soft functions which can be learned in addition to whatever
functions show up from the pre-programmed codes. The soft keys are fully
editable and configurable to ensure that the features you need are available
and accessible. For a standard remote this is extremely flexible and one of the
best and most usable remotes I've seen included with an AV receiver. It will
take you some time to wade through the setup steps, but it's all spelled out
very clearly in the User Manual.
The remote can handle up to 20 macros, each of which can issue 20 IR commands. The 20 macros are accessed by pressing the M button at the top of the remote's LCD screen and you can rename all 20 macros as desired (up to 7 characters).
The RC8001SR has no CableTV button. In addition, the input buttons do not allow you to assign any 4-digit pre-programmed code from the list. This means that, for example, the DSS and TV buttons won't allow themselves to be configured for cable set-top box codes. During programming the remote will simply give you a WRONG CODE error. If you have a Scientific Atlanta or Pioneer CableTV box you'll need to assign this to Aux1 and that's the source you'll need to select for CableTV. Apparently, the folks at Marantz think that CD-Rs, MiniDiscs and VCRs are far more popular than CableTV. We politely disagree and hope they will reconsider both labels and pre-programmable code functionality in their next model. Additionally, we found that the slight delay from hitting a button to getting the desired action was a bit frustrating at times.
Backlighting is effective on this remote in that everything is adequately lit. The backlight time can be set using the Setup menu of the remote control and is activated by pressing either of the dedicated light buttons at the bottom of the remote. The only downside is that there is no way to have the backlight come on automatically when any control is pressed on the remote.
Source Switching
When you first select a Source button you are then able to control functions for that device. If you double click the source, you cause the receiver to switch inputs to that source. I really liked the way this worked. It makes sense and seemed a practical way to ensure you could still gain easy access to your components without always switching inputs. What isn't always intuitive is that, without dedicated AV receiver buttons, you'll always need to remember to hit the "Amp" button before controlling any receiver -specific functions.
Noteworthy
is the fact that activating the Main Menu via HDMI will disrupt any audio being
sent to the system for approximately 3-4 seconds.
RC101 Zone 2 Remote
The supplied Zone 2
remote works very well in its general use. In fact I really liked the automatic
backlight, easy key layout, source selection and size. If you are utilizing the
amplifiers in the SR7002 you will not initially be able to control the output
volume as the remote comes configured to control the level of the Multi Zone
preamp outputs. To switch the remote to control the volume of the Multi Speaker
outputs (the amplifiers of the SR7002) you need to simultaneously press the 'Set'
and 'Power On' buttons, then press the #2 button (also labeled 'DVD'), and then
push the Enter button. Doing this will lock in the new volume control mode. The
other thing that is very nice about the Zone 2 remote is the discrete On/Off
controls for both the Multi Speaker Zone and the selected source. This is
something even the main RC8001SR remote lacks (for Sources).
HD Audio Support
Not only does the SR7002 support Dolby TrueHD, Dolby Digital Plus and dts-HD formats via HDMI, it has dedicated 7.1 analogue inputs for legacy DVD-Audio and SACD players that may not be able to send those formats via HDMI. This means that if you are an audiophile with a very nice SACD player you're not left out in the dust - and you don't have to upgrade to a newer HDMI-enabled universal player to retain the quality of your recordings. No matter what format you're looking to send to the Marantz SR7002, it's going to have a way to handle it.
The Testing System
We updated Reference System 2 a few weeks ago to introduce higher quality speakers into the RBH Sound CinemaSITE system. It now contains updated Signature SI-760/R speakers which have an updated driver design which really brings out the detail and clarity in music. The always difficult-to-get-right midrange is particularly impressive. As it is configured now, the system contains three SI-760/R speakers across the front, a pair of 66-SE dipole surround speakers and a pair of SI-1010P powered subwoofers. With the exception of the dipole surrounds, the Signature in-wall speakers reside within the CinemaSITE structure, which also supports the 92-inch Masquerade projector screen masking system from Carada. I am able to utilize the Audyssey MultEQ system to aid in smoothing out the subwoofer response in this room and have treated the room with acoustical material provided by RPG Diffusors. All audio electronics are conditioned and protected by an APC S15 system with additional SBATT. When the power goes out in Central Florida, this home theater can continue to play a movie all the way through the credits. As far as audio goes, that just about sums it all up.
See also:
Recent Forum Posts:
mpedris;408262
How might the SR-7002 drive a 4 ohm or 6 ohm load continuously?
A friend is considering buying this receiver to drive the Mirage OMD-5 (rated at 6 ohms) or Sonus Faber Concertino (rated at 4 ohms).
Might a Denon AVR-3808 do a better job at driving the said speakers?
Thanks in advance for any help.
IMO, I wouldn't even consider driving 4ohm speakers continuously on a receiver point.
6ohm might be ok... check the manual/call for tech support.
What is your experience with the latest Harman Kardon AVR 247 product?
I am putting together my HT setup and purchased this unit, still new in the box, and haven't installed it yet but reading all the current "problems" should I switch to the Onkyo 605 or 606 for better quality and sound?
Being new to HT, is there an appreciable sound/video quality difference with 1.3 vs. my Harman AVR 247's 1.1 (1.2?) setup?
I would like the best sound and picture in this price range.
Thank you for any help!
Gary
Regarding its video capabilities, if I get a Blu Ray player such as the Panasonic BDP HDK 50 (or 30) and play a regular DVD (not Blu Ray), will the Blu Ray player upscale to 1080p, and so are the "limitations" of the Marantz video upscaling irrelevant (it only upconverts 480i/p via HDMI)?
Thanks, geraldan (a newbie to all of this technical stuff!)
