You are here: Home Pro Reviews A/V Receivers Denon AVR-3805 Receiver Review Setting Up the AVR-3805 Receiver: Manual and Auto Setup
by Clint DeBoer last modified December 06, 2011
2-1_speaker_configManual setup consists of identifying the number, size and location of your speakers as well as configuring the AVR-3805 to accurately handle audio and video inputs and outputs. For the most part, a tape measure, SPL meter and the Denon's internal pink noise generator will be sufficient to accurately configure the Denon to work within your room.
All measurements for the receiver's configuration should be taken from the listening position, both in measuring distance and SPL levels. For Reference System 3 we came up with the following settings:
Speaker
Size
dB SPL
Distance
Front Left
Large
0
9.3 ft
Front Right
0
9.3 ft
Center
Small
+0.5
9.0 ft
Surround Left
Small
+1
8.6 ft
Surround Right
+0.5
8.6 ft
Subwoofer
Yes
0
10.4 ft
Crossover Setting: 60 Hz (40/60/80/100/12/150/200/250 Hz)
Reference Level Calibration to 80 dB SPL
I love the ability to set speaker distances with a .1 ft tolerance. For overseas users, the Denon even enables the user to configure the system in .01 meter increments. Using .01 meter increments will result in more accuracy regardless of what measurement system you typically utilize (.1 ft = 1.2" increments while .01m = .394" increments.)
Once the system was configured I noted the settings and continued with my evaluation period for several weeks.
Setting Up the Receiver - Auto Setup
clip_image002_0000 Auto setup and Room EQ are emerging trends that now come standard with several models from Yamaha, Denon and Pioneer. Once I decided it was time to test the Auto Setup functions of the AVR-3805, I redid my manual setup to ensure that my system had not changed from the settings I had previously engaged. They were spot on and I recorded their settings for later comparison.
Verify/set your crossover frequency FIRST, before running any tests or auto setup. Auto setup will NOT adjust your crossover frequency.
Next, I proceeded to connect the Denon DM-S305 condenser microphone to the front of the receiver. I was careful to position the omni-directional microphone at exactly the listening position - precisely where the SPL meter was placed during the manual setup. The DM-S305 microphone is a $60 option and is a plug-and-play solution requiring no calibration of its own or level adjustment. This is an advantage for those looking to utilize the automatic configuration and EQ functions of the AVR-3805. It comes with a threaded insert on the bottom of the mic which is surrounded by a thin rubberized pad, providing sufficient isolation when mounted on a camera-style tripod (the mic is not designed for standard 5/8" threaded microphone stands.)
To begin auto calibration, click on "Auto Setup" from the Auto Setup / Room EQ Menu. The Denon will now remind you to Connect the Microphone and verify whether you are using the powered Surround Back speakers. Simply guide the remote down to the Start text and cursor left to begin. A good suggestion would be to run this setup in the evening, when ambient noise generally subsides by about 10dB or more. You will also want to turn off any air conditioning and remove small children from the room prior to performing auto calibration.
During calibration the Denon will produce a 2 second burst of pink noise from each speaker, checking frequency response, distance, level and phase. The starting volume for the test is automatically set by the AVR-3805 so there is no need to pre-set the receiver's volume at any particular level (another advantage of having a digitally-controlled analogue volume.)
1-1_auto_setupThe order for the tests is Front Left, Front Right, Center, Subwoofer (measured twice), Surround Left A, Surround Right A, Surround Left B, Surround Right B, Surround Back Left, Surround Back Right (these last two will not be displayed or tested when Zone 2 or Zone 3 is configured in the Auto Setup menu. Each test burst is accompanied by the word "Measuring" which appears on the monitor output as well as the Denon's digital display.
This single pink noise burst not only results in distance, speaker type and level settings, but also configures the parametric EQ settings as well (which by default are off.) At the conclusion of the Auto Setup you will be able to view the speaker configuration, delay times, and channel levels as set by the Denon receiver. Auto Setup rendered my system in the following manner:
Speaker
Size
dB SPL
Distance
Front Left
Large
-1.5
9.3 ft
Front Right
0
9.3 ft
Center
Large
0
8.9 ft
Surround Left
Large
-0.5
8.6 ft
Surround Right
0
8.6 ft
Subwoofer
Yes
+2.5
9.3 ft
You can see by the highlighted numbers that the AVR-3805, while not wrong configures speaker systems according to a fixed set of rules (see inset "Important notes on Denon Room EQ"). I would not, for example, consider the high performance RBH Sound 61-LSEs to be Large speakers as they perform strongly down to 45Hz but are not equipped to handle crucial lower frequencies at high SPLs.
In Reference System 3 I generally prefer sending all frequencies below at least 60Hz to the subwoofer. Every room and system is different, however and you may not choose to do the same in yours. In addition to this, I have been experimenting with utilizing the THX standard of 80Hz for home theater and music use which has produced excellent results as well.
Important Notes on Denon Setup and Room EQ
After re-reading the Denon manual, we realized that Denon rates speakers as being Large or Small based on the crossover frequency set by the user. We also re-ran the Auto Setup several times and verified that Auto Setup DOES NOT CHANGE the crossover setting. This is odd since the user may set the crossover to 60Hz for speakers that go down to 45 Hz - but if they are consequenctly set to Large by the Denon, then you lose all frequencies below the potential of the speakers. In addition, the user manual does not instruct the user to first set the crossover setting prior to performing an Auto Setup. It would be more accurate and beneficial to the user to have an Auto Setup system that actually evaluated and correctly determined the best crossover frequency for the given speaker system.
When running the Auto Setup, the Denon's short white noise burst pattern runs only once per speaker (except for the subwoofer test which runs twice). This single test is used for both size, distance and speaker type as well as Room EQ settings. This is very detrimental to the system as a whole as it basically means the Denon is setting the parametric EQ based on the same test it used to determine the speaker's most fundamental characteristics. The three Room EQ modes (Normal, Flat and Front) are also calculated from the same test burst, meaning that a mathematical equation is used to determine each of those settings, rather than a separate set of measurements which we feel would be more appropriate. Based on these evaluations, we don't see how the system can perform optimally beyond a very basic "one-shot-cures-all" enhancement that is not truly geared for detailed room correction.
