You are here: Home Pro Reviews A/V Receivers Denon AVR-3805 Receiver Review
by Clint DeBoer last modified June 08, 2004
Denon AVR-3805
Denon AVR-3805
  • Product Name: AVR-3805
  • Manufacturer: Denon
  • Review Date: June 08, 2004 20:00
  • MSRP: $ 1200
Specifications
Surround Formats: Dolby Digital Surround EX, Pro Logic IIx (Cinema, Music and Game Modes), dts ES Discrete 6.1 and Matrix 6.1, dts Neo:6, dts ES 96/24, HDCD
DSP: Analog Devices HammerHead SHARC 32 bit floating point DSP processor
Power Ratings
120 watts per channel (8 ohms, 20 Hz-20 kHz, <.05%THD)
160 watts per channel (6 ohms, 1 kHz, <.7%THD)
Audio DACs: 16 Burr-Brown PCM-1791 24-bit/192 kHz on all eight channels, in differential configuration
Audio ADCs: 24-bit/192 kHz Burr-Brown PCM-1804 on all Stereo analog inputs (Not EXT. Inputs)
Crossover: 40, 60, 80, 100, 120, 150, 200, 250Hz
Remote: EL backlighting pre-programmed/learning remote
Video Inputs: 3 (assignable) 100MHz Component Video, 7 sets composite and s-video inputs
Video Outputs: 100MHz Component video output, 3 composite and s-video outputs, Multi-Zone composite video output
Audio Inputs: 7.1 external wide bandwidth (100 kHz) multi-channel inputs, 5/7 Channel Stereo, DENON Link 3rd (SACD & DVD-Audio compatible), 7 assignable digital inputs (5 optical, 2 coaxial), 10 analog inputs
Audio Outputs: 2 optical digital outputs, 2 multi-zone stereo pre-amp level audio outputs, fixed or variable level
Additional Connections: RS-232C port for third party control Systems, remote I/O ports, 2 assignable +12V triggers, detachable power cord
Dimensions: 17.1" W   x 6.7" H x 16.4" D
  • DENON Link 3rd Edition
  • Component video up-conversion with OSD
  • Three (3) HDTV-compatible component video inputs
  • Can bi-amp front speakers for 240 wpc (5.1 only)
  • Bass output in 2-channel direct mode!
  • Lip Sync delay
  • Can monitor video other than audio source
  • Auto Setup doesn’t set crossover point
  • No IEEE 1394/Firewire interface
  • Aggressive Room EQ (boosts up to +9 dB)
  • No digital sources output to Zone 2/3
Introduction
The review of the Denon AVR-3805 has been a long time in coming, but we have assembled what we hope will be an informative document that does its best to take you through what it's like to own this 7.1 receiver. Our intent is to bring you the most detailed information possible and put forth both the positive and the negatives to present a well-rounded look at this next-generation home theater control center.
