You are here: Home Pro Reviews Projectors Sony VPL-HS51A Cineza Projector Review VPL-HS51A Setup, Installation & Connections
by Clint DeBoer last modified February 13, 2007
The presence of a lens shift assembly makes this projector easy to mount, or if you prefer, place it on a tabletop. For this review we utilized a 100" diagonal Stewart Luxus Deluxe ScreenWall (with ISF-certified Studiotek 130 screen). This is a very high quality screen with very even dispersion characteristics and color uniformity and is optimized for excellent white levels while allowing for deep, rich blacks in a light-controlled room. For those considering the Sony VPL-HS51A in their home theater room, take a look at the 16:9 throw chart:
Throw Chart for Distancing the Projector from the Projection Screen
Screen Size
Diagonal (inches)
Size (Inches)
Distance (Feet)
width
height
wide
tele
70
61.0
34.3
6.8
10.4
80
69.7
39.2
7.8
11.9
90
78.4
44.1
8.8
13.4
100
87.2
49.0
9.8
14.9
110
95.9
53.9
10.8
16.4
120
104.6
58.8
11.8
18.0
130
113.3
63.7
12.8
19.6
150
130.7
73.5
14.7
22.4
170
148.2
83.3
16.7
25.4
200
174.3
98.1
19.7
29.9
Per the Sony manual, if you want to do the exact calculations, use this (in meters):
Maximum distance (telephoto) = {(diagonal screen distance [meters] x 21.3/0.7) - 35.2} x 1.025
Minimum distance (wide) = {(diagonal screen distance [meters] x 33.9.7) - 37.7} x 0.975
Note: 1 meter = 3.281 feet
Or you could just go to our friends at Projectorcentral.com and use the pretty sliders (highly recommended.)
Ambient Light Control and Screen Recommendations
Keep in mind that the room you are using this in should be light controlled if at all possible. By "light controlled" we mean that the room should:
  • Not have more than 4-5% ambient light entering it at any time it is being used for watching movies
  • Not have an abundance of bright or reflective surface areas. I have known a couple people who painted their entire theater rooms a neutral medium-dark color only to realize that their ceiling, furniture and adjoining room cast so much reflective light it rendered their paint choice useless.
If you cannot do a thorough job of controlling ambient light, not all is lost. You can compromise by using a reduced gain gray screen (like the Stewart GrayHawk RS, FireHawk G2 , or Carada's High Contrast Gray ) which will aid in attaining black levels and delivering a more pleasing picture. For those who can control light, we recommend a white screen similar to the Carada Brilliant White or Stewart Studiotek 130.
We ran two different cables to the projector for our tests. A well-shielded component video cable was supplied by Impact Acoustics and gave us an excellent analogue connection from the Denon DVD-5910 player's component outputs. A well-built SHR HDMI cable, supplied by DVIGear , enabled us to compare the digital inputs of the Sony as well. We ran all of the HDMI source components through a PureLink HDMI Switcher (HDS-41R) which allowed us to send the projector a myriad of sources including multiple DVD players and HDTV from our Scientific Atlanta 8300HD cable box.
We did not test the composite and s-video inputs. Our theory is that if you are spending this much money on a projector, you shouldn't be using those inputs. If you are, it's likely out of necessity and you won't be too concerned with comparing those to the high resolution inputs.
Editor's Note
A couple things to note about the "starter" settings for the Sony include making sure you set the Picture Mode to Cinema, leave Advanced Iris On (or Auto) , and set Color Temp and Lamp Control to Low . This will get you in the ball park in terms of dynamics, color and contrast for watching movies and enable you to have the best starting position from which to calibrate using common tools such as AVIA Guide to Home Theater or Digital Video Essentials .
If you're unpacking this projector for Monday Night Football - forget what I said. Engage Dynamic mode, turn Off the Advanced Iris, and crank up the Lamp Control and Color Temp to High . That will give you a nice, bright picture and you don't have to trip over each other when going for the chips.
Connections
Don't say it - I know what you're thinking. What's a USB connector doing on a home theater projector? The USB connection allows the user to interface with the projector using ImageDirector 2 . ImageDirector 2 allows users to adjust the projector's gamma value from a computer connected to the projector. The software allows you to adjust the gamma value by adjusting the luminance curve of the incoming signal. In addition to using the gamma value that has been adjusted and preset at the factory, you can also adjust the gamma curve yourself. Now that's pretty nifty. We had to give it a whirl, but first let's go over the more expected inputs and functions (I'll cover the USB connected gamma corrections in the Calibration section).
The Sony projector comes with a remote, batteries and power cord - no cables are provided. Should you have the desire, however, you can fill up a composite, s-video, HDMI-HDCP, RGB/HD15, and one component video input to your heart's content. There is no RS-232 control for this projector, though it does have a 12VDC trigger output.
As previously mentioned, we primarily utilized the HDMI inputs, but tested the upscaling and deinterlacing performance of the display using the component inputs. We sent 480i interlaced signal from the Denon DVD-5910 to the Sony projector and allowed the onboard deinterlacer to convert the signal to progressive scan, performing all deinterlacing functions as well as 2:3 pulldown (more on this later). The connections are well-spaced out and easy to work with so you shouldn't have any problems plugging things in.
Recent Forum Posts:
mtrycrafts posts on February 23, 2009 22:50
Driver_King;527150
I know this is a really old thread but I need some opinions here. I can get a Sony HS51A with a new bulb for $800 shipped. Would a Panasonic PT-AX200U be a better choice? What is the best projector I can get in the range do you think? I like what I've seen about the HS51A. I'm actually upgrading from my ISF calibrated Sony VPL-VW10HT projector because of the extreme lack of black detail on it. I moved from CRT blacks to virtually no blacks and am really wanting my black levels back! I have a completely light controlled room by the way if that helps any. Thanks!
I am far from being the expert on this projector or the Panny and tradeoffs.
Don't forget that Sony is only a 720p projector, from briefly reading Clint's post. Not sure if you are going BluRay or not, but today, buying a 720 may be a mistake no matter what. The larger the picture, the more you need the higher resolutions.
You may want to check out some older posts on this projector at AVS
http://www.avsforum.com/avs-vb/forumdisplay.php?s=&daysprune=&f=24 [avsforum.com]
and search for both projectors. Some of those guys live and breath these
That vinyl screen, who make it?
Driver_King posts on February 21, 2009 23:05
I'm also getting a 92" screen to go in my bedroom setup.It is a white vinyl screen and I'm not sure if that has to do with anything.
Driver_King posts on February 21, 2009 23:01
mtrycrafts posts on February 08, 2006 21:44
LEVESQUE
5 clicks and your in the factory mode. Really easy to do. I don't know if I can post factory settings here, but here it goes. But don't try those settings if you don't know what you are doing!
In the factory mode, "Other" directory, change:
#43 to 140
#44 to 700.
Those are controlling the way the iris reacts from both ends of the luminance spectrum.
5 ip/sharp limit. Default at 255. I set it to 0
8 IP-VS 0 is off, default 1 is on I turned this to 0= off.
18 IP-VS LIMIT default 64 I set this to 0
19 IP-VS CORE 4. Set it to 0
No more ringing.
Great. I made notes and attached to my preplanning papers The 8ip, 18ip, 19ip also needs to be adjusted to eliminate the ringing? Gary only mentioned #5.
Did you notice a decrease in lumens from these changes?
Is there are sheet what all those setting are for?
LEVESQUE posts on February 08, 2006 09:32
What tweaking did you do in the factory menu? Easy to get into it??
#43 to 140
#44 to 700.
One post by Garry, the WS reviewer, mentioned that the factory sharpness is defaulted to 255, yielding visible ringing issues and resetting to 0 caused it to disappear.?
No more ringing.
