You are here: Home Pro Reviews Projectors Sony VPL-HS51A Cineza Projector Review
by Clint DeBoer last modified December 07, 2007
Sony Cineza VPL-HS51A
  • Product Name: VPL-HS51A Cineza Projector
  • Manufacturer: Sony Electronics
  • Review Date: February 03, 2005 19:00
  • MSRP: $ 3499
Specifications
Brightness: 1200 ANSI lumens (max)
Contrast: Up to 10,000:1 (stated full on/off)
Resolution: 1280 x 720 native HD resolution (1920 x 1080 maximum)
Aspect Ratio: Widescreen native 16:9 aspect ratio (4:3 compatible)
Supported Screen Size: 40-300 inches diagonal
LCD Panel: D-4; 3 x 0.73” TFT LCD
Lens: All Range Crisp Focus Lens (ARC-F Lens)
Iris: Dynamic Iris optical system constantly adjusts the brightness and gamma characteristics in real time
Accepted Video Formats: 480i/575i/1080i and 480p/720p/1080p(24) (PAL equivalents supported)
Accepted Computer Formats:
RGB: Horizontal 19 to 72kHz, Vertical: 48 to 92Hz; Max input resolution WXGA (1280 x 768, fV:60Hz)
Video Inputs:
HDMI-HDCP, component, composite, S-video, and PC/RGB (HD15)
Color System: NTSC, PAL, SECAM, NTSC 4.43, PAL-M, PAL-N, PAL60
Projection Lens: 1.6x optical zoom; f = 21.3 - 34.1 mm/F2.4 - 3.16, manual focus & zoom
Lens Shift: Vertical and horizontal (100% vertical, 50% horizontal)
Keystone Correction: +/- 30 degrees
Lamp: 135 W UHP lamp
Mounting: ceiling, desk, front/rear (menu configurable)
Power Supply: 100-240 volts, 50-60Hz
Power Consumption: 195 watts (maximum), 4.5 W (standby), 0.5 watts (ECO mode with fan stopped)
Operating Temperature: 32 - 95 degrees F (0 - 35 degrees C); 35-85% humidity (no condensation)
Projection Method: Front/rear/ceiling mount/table-top
Remote Control: Backlit, AA x 2 batteries
Standard Accessories
: Power cord, Wireless remote control unit, batteries for remote control, replacement air filter, CD-ROM application software, owner's manual
Operating Noise: 30dB (minimum)
Dimensions: 13 5/8” x 5 7/8” x 14 5/8” in. (348 x 135 x 360 mm)
Weight: 12.4 lbs (5.7 kg)
  • Excellent black levels
  • 1.55x optical zoom
  • Deep, rich colors
  • Usable picture/color controls for HDMI input
  • 3000 hour lamp life
  • 12VDC trigger output
  • Requires calibration out of the box
  • IR sensor on front only
  • Large 5% overscan on component (undefeatable)
Introduction
Sony made a splash with its VPL-HS51 Cineza LCD projector at last year's CEDIA. It had a 6000:1 contrast ratio that, for possibly the first time, rivaled DLP, thanks in no small part to a dynamic iris system. While we wanted to get our hands on a review sample, our schedule pushed it off until we now got our hands on the newly improved VPL-HS51A. The 'A' denotes a slightly revised model that now boasts a 10,000:1 stated contrast ratio. With its price point coming in right at the sweet spot of those wanting to get into decent quality 720p projectors - we were anxious to run the Sony through our barrage of tests.
Recent Forum Posts:
mtrycrafts posts on February 23, 2009 22:50
Driver_King;527150
I know this is a really old thread but I need some opinions here. I can get a Sony HS51A with a new bulb for $800 shipped. Would a Panasonic PT-AX200U be a better choice? What is the best projector I can get in the range do you think? I like what I've seen about the HS51A. I'm actually upgrading from my ISF calibrated Sony VPL-VW10HT projector because of the extreme lack of black detail on it. I moved from CRT blacks to virtually no blacks and am really wanting my black levels back! I have a completely light controlled room by the way if that helps any. Thanks!
I am far from being the expert on this projector or the Panny and tradeoffs.
Don't forget that Sony is only a 720p projector, from briefly reading Clint's post. Not sure if you are going BluRay or not, but today, buying a 720 may be a mistake no matter what. The larger the picture, the more you need the higher resolutions.
You may want to check out some older posts on this projector at AVS
http://www.avsforum.com/avs-vb/forumdisplay.php?s=&daysprune=&f=24 [avsforum.com]
and search for both projectors. Some of those guys live and breath these
That vinyl screen, who make it?
Driver_King posts on February 21, 2009 23:05
I'm also getting a 92" screen to go in my bedroom setup.It is a white vinyl screen and I'm not sure if that has to do with anything.
Driver_King posts on February 21, 2009 23:01
mtrycrafts posts on February 08, 2006 21:44
LEVESQUE
5 clicks and your in the factory mode. Really easy to do. I don't know if I can post factory settings here, but here it goes. But don't try those settings if you don't know what you are doing!
In the factory mode, "Other" directory, change:
#43 to 140
#44 to 700.
Those are controlling the way the iris reacts from both ends of the luminance spectrum.
5 ip/sharp limit. Default at 255. I set it to 0
8 IP-VS 0 is off, default 1 is on I turned this to 0= off.
18 IP-VS LIMIT default 64 I set this to 0
19 IP-VS CORE 4. Set it to 0
No more ringing.
Great. I made notes and attached to my preplanning papers The 8ip, 18ip, 19ip also needs to be adjusted to eliminate the ringing? Gary only mentioned #5.
Did you notice a decrease in lumens from these changes?
Is there are sheet what all those setting are for?
LEVESQUE posts on February 08, 2006 09:32
What tweaking did you do in the factory menu? Easy to get into it??
#43 to 140
#44 to 700.
One post by Garry, the WS reviewer, mentioned that the factory sharpness is defaulted to 255, yielding visible ringing issues and resetting to 0 caused it to disappear.?
No more ringing.
