You are here: Home Pro Reviews Projectors Projector Screens Projector Screen Shootout: Stewart, Da-Lite & Carada Compared First Impression: Da-Lite Cinema Vision
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Clint DeBoer last modified December 08, 2006
Da-Lite packagingUnpacking & Assembly
The next arrival was from Da-Lite. As with the Carada screen Da-Lite packs their product well. Just as with the Carada, the Da-Lite screen shipped with four side rails, some mounting hardware, and of course the screen material.
Note: Da-Lite shipped a Cinema Vision screen instead of a Cinema Vision High Contrast screen due to a miscommunication. Because of time constraints we decided to proceed with the review but plan to request a high contrast screen sample to which we'll add our findings in an addendum.
All of the corners were marked for easy assembly. I did take notice that the rails slid in with a somewhat snugger fit than the Carada.
Just as with the Carada screen, some snaps had to be screwed into place once the corners were in position along with some screws for extra stability. Overall, the assembly was very straightforward and took very little time. Labels were provided, along with instructions, for matching up the appropriate corners.
Da-Lite frameCompletion of the frame was a breeze. All that was left was to snap the screen into place. I noticed immediately that the Da-Lite screen felt very "industrial" and appeared to be made of a thicker gauge material than the Carada.
Da-Lite uses the exact same wall bracket as the Carada model which makes hanging the screen a snap with just one person. The mounting bracket is actually built into the frame of the Da-Lite. If you look at the outer edge of the frame, you can make-out the recess in which the frame slides into the wall bracket. Again, this allowed for the Da-Lite to be slid into position while still maintaining the ability to center the screen on the wall. The frame for this particular screen did not feature Da-Lite's "pro-trim" fabric covering. This option is available at an additional cost.
