You are here: Home Pro Reviews Projectors Planar PD7150 DLP Projector Review Planar PD7150 Viewing Evaluation and Conclusion
by Clint DeBoer last modified March 07, 2007
I found this projector to be exceptional in color and contrast. I also noticed screen door effect at close seating distances - perhaps an acceptable trade-off for a very sharp picture. This is an extremely sharp-looking picture, and if you sit at least 1.75x the screen width away from the projected image you will have a very enjoyable experience.
I went with a couple darker DVDs that would show off the contrast potential of this projector. With a stated 5000:1 contrast (see our measurements) I wanted to get an idea of just how well the PD7150 would recreate black levels in my light-controlled room.
DVD: Jet Li's Fearless
There's nothing better than a good martial arts (Wushu) film - except for maybe a Samurai movie… Well, regardless, this action flick wasn't the best looking picture I'd seen all year, but it did have lots of great color and image depth. We viewed some other films for detail, but take a look at these images and note the excellent black levels captured to the best of my camera's abilities:
Fearless1 Fearless2
DVD: The Illusionist
This movie was the "clone" to The Prestige (in Hollywood all movies come out in topically-related pairs as an initial idea leaks and multiple studio clamor to get on board).
Illusionist 1 Illusionist 2
DVD: Shark Tale
It was now time for some color and edge detail. An obvious choice was Disney's Shark Tale, which has an exceptionally good range of colors and edges to check out the real world performance of the DCTI color edge enhancement feature. As with the test patterns, we still recommend this be set to 1 or 0, depending on whether you feel the enhancement bothers you, or simply makes colors pop more. It can do either based on your perspective. We noticed a tad more vibrancy when it was engaged, but it also had the effect of occasionally coming off as bad edge enhancement artifacts.
Shark Tale 1 Shark Tale 2
DVD: The Fifth Element
I wanted to toss in a reference disc example to my viewing sessions and The Fifth Element Superbit seemed to be a good place to start. This Superbit DVD actually looks worlds better than its Blu-ray counterpart due to noise-free mastering. Color is superb and there is no edge enhancement to speak of. As a reference standard definition disc, there is little out there that comes close to this quality. The Planar PD7150 showed off its attention to detail with this disc. Edges were clean and crisp, without being artificially enhanced (depending on your DCTI setting of course). Pay attention to the color edges and facial detail in these shots as well as background and texture detail.
Fifth Element 1 Fifth Element 2
HDTV: House, Bones, Discovery HD
As a final series of viewing tests we watched several episodes of HD cable shows. House is one of the better shows on television in terms of clarity and detail (CSI: Miami is also very good).
House 1 Discovery 1
Bones 1 Bones 2
Planar is definitely going after the higher-end custom install market with this fine piece of machinery. The PD7150 has exceptional color and contrast (real-world) and phenomenal optics that make for a razor-sharp picture on screen. There are cheaper alternatives, however they may not be as well positioned and feature-rich for the custom install community. They also may not come as well calibrated "out of the box".
Planar has hit a home run with this unit and we're excited to see them address nearly the full range of products at every price point. The next time you're in a grocery store checkout, modernized gas station or hospital and see a Planar screen, you might want to think about getting that logo into you home as well.
MSRP: $5,999
Planar Systems, Inc.
1195 NW Compton Dr.
Beaverton, OR 97006-1992, USA
www.planar.com
About Planar
Planar Systems, Inc. (NASDAQ:PLNR) is a leading provider of valued-added display hardware and software for a variety of specialty display markets worldwide. Hospitals, shopping centers, banks, businesses, and other discriminating consumers depend on Planar to provide unique display-based solutions to exacting requirements leveraging its operational excellence, technical innovation, and go-to-market capabilities. Founded in 1983, Planar is headquartered in Oregon, USA, with offices, manufacturing partners, and customers worldwide. For more information, visit www.planar.com.
  • StarStarStar — Good
  • StarStar — Fair
  • Star — Poor
MetricRating
Detail and ResolutionStarStarStarStarStar
Deinterlacing & ScalingStarStarStarStarStar
Contrast and Black LevelsStarStarStarStarStar
Color ReproductionStarStarStarStarStar
Noise ReductionStarStar
Calibration OptionsStarStarStar
Ease of SetupStarStarStarStar
FeaturesStarStarStar
Remote ControlStarStarStar
ValueStarStarStarhalf-star
Recent Forum Posts:
E-A-G-L-E-S posts on October 17, 2008 10:37
This is one fantastic 720p 1 chip DC3 DLP PJ!
The Dukester posts on October 14, 2008 11:30
Thanks for the review. The Planar 1080p's are on my short list. Any chance of seeing an 8150 or 8130 review? I'd really like to see how these stack up against the new JVC's coming out and the Sony's. Too bad there are no dealers close to me to see any of these.
Clint DeBoer posts on October 14, 2008 09:08
You might want to read this article:
http://www.audioholics.com/tweaks/calibrate-your-system/hdmi-black-levels-xvycc-rgb [audioholics.com]
It will give you some good info on why proper levels are important and how to ensure you get them correct.
Grayson73 posts on October 14, 2008 08:21
White Enhance, if I recall correctly, enabled whiter than white response, regardless of gamma setting. I don't typically retain calibration settings since most people's rooms and systems are different from mine.
So you recommend that it is always "on", right? Why is it good to have "whiter than white"?
Clint DeBoer posts on October 13, 2008 18:42
