You are here: Home Pro Reviews Projectors Panasonic PT-F200U LCD Projector Review
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Clint DeBoer last modified November 18, 2008
Panasonic PT-F200U Projector
  • Product Name: PT-F200U LCD Projector
  • Manufacturer: Panasonic
  • Review Date: June 06, 2008 14:18
  • MSRP: $ 3,999
Specifications
Brightness: 3500 ANSI lumens
Resolution: 1024 x 768 (XGA)
Aspect Ratio: 4:3 or 16:9 aspect ratio (4:3 native)
Supported Screen Size: 33-300 inches diagonal
LCD Panel: 3 x 0.7” polysilicon active matrix
Optical System: Dichroic mirror separation/prism synthesis system
Video Features: Ambient Luminance Sensor (ALS)
Scanning Formats: 480i/576i/1080i and 480p/576p/720p (PAL equivalents supported)
Video Inputs: component, composite, S-video, and 2xPC/RGB (HD15)
Projection Lens: 2x optical zoom; f = 21.6 – 43.0 mm. F/1.7 – 2.6, manual focus & zoom
Lens Shift: Vertical and horizontal (50% vertical, 32% horizontal)
Keystone Correction: +/- 30 degrees (vertical)
Lamp: 250 W UHM lamp, 5000 hour estimated life
Mounting: ceiling, desk, front/rear (menu configurable)
Power Supply: 100-240 volts, 50-60Hz
Power Consumption: 330 watts (maximum), 4.5 watts (standby mode with fan stopped)
Operating Temperature: 32 – 104 degrees F (0 – 40 degrees C); 20-80% humidity (no condensation)
Audio: 3W output via onboard speaker
Projection Method: Front/rear/ceiling mount/table-top
Remote Control: Standard (non-backlit) remote with laser pointer, AA x 2 batteries
Standard Accessories
: Power cord, Wireless remote control, batteries for remote control, safety cable
Optional Accessories: Ceiling bracket (ET-PKF100H/ET-PKF100S), AV cables (TY-SC10CP)
Dimensions: 17" x 4.9" x 12.6" in (432 x 125 x 319 mm)
Weight: 13.7 lbs (6.2 kg)
  • Lens shift
  • High lumen output
  • Daylight View 4 works well
  • Not good for dedicated home theater use
  • No noise reduction
  • Poor deinterlacing
Introduction
We reviewed the PT-F100U projector last year and were very impressed by the level of quality available for general viewing. When selecting a projector it's important to know your requirements and set performance goals. In the case of the PT-F200U, the projector is targeting users with a need for high lumen output and analogue video sources. This means that you will not get as much performance in low light situations, nor can you expect to connect the latest HDMI devices. With that said, this projector is going to be a massive "win" for business presentations or even houses of worship.
Recent Forum Posts:
