You are here: Home Pro Reviews Projectors Panasonic PT-AE900U LCD Projector Review PT-AE900U Setup Menu and Calibration
by Clint DeBoer last modified July 23, 2009
PICTURE Menu
The PICTURE Menu is where I spent most of my time - and for good reason. It allows access to contrast, brightness, color, tint, sharpness, color temperature and iris settings as well as access to an ADVANCED Menu and memory load/save options. Engaging the MENU button on the remote or projector brings up the rather large menu, but it can be moved to one of seven quadrants of the screen (including the center). Engaging any of the picture controls hides the menu and allows you to view the screen with only a smaller bar graph representation of the control at the bottom of the screen. This makes using calibration discs such as AVIA Guide to Home Theater or Digital Video Essentials possible. Put your running shoes on, though, as the mini menu only stays up for about 3.5 seconds unless you make an adjustment (then you get a 3.5 second extension). This applies to when you directly access a menu function from the remote control as well. I found this only mildly annoying as simply hitting ENTER or moving the directional pad brought the mini control back to the front, hiding the larger menu (not so with the direct access control, obviously).
At the bottom of the PICTURE Menu is an option to engage the ADVANCED Menu which provides controls for Gamma, Black and White Levels for the red/green/blue colors. This is also where you can gain access to the Cinema Color Management function (C.C.M.) - a system whereby users can select which colors they want to blow out of whack by specifically tweaking their Color, Tint, and Brightness settings. If the Panasonic hadn't already provided access to red green and blue Gamma, Black, and White levels I suppose the C.C.M. system could potentially be utilized to compensate for color decoder issues. I found it to be a fun tool that could be used to give Monday Night Football and televised golf games exceptional greens. Take a look at an over-exaggerated use of this function:
You engage C.C. M . which freezes the screen and allows you to move a cursor around to grab the color to which you want to apply correction.
Once selected the color controls for Color, Tint, and Bright[ness] appear, allowing you to modify the color and see the update after pressing the ENTER key.
Here you see the highly exaggerated green grass along with a pronounced yellow centerline in the highway.
Calibration - Get Those Black Levels Right!
We wanted to ensure that the Panasonic PT-AE900U was fully capable of reproducing a decent range of luminance information from deep blacks to bright whites. The goal, of course, is to maximize the contrast ratio while not crushing blacks or whites and losing resolution. Speaking of contrast, I was able to get 670:1 ANSI rating using my standard configuration for front projection systems. This is extremely good for a front projection system and shows how far Panasonic has come with this latest LCD panel.
The Datacolor ColorFacts software provides a CIE Chart which shows the colors for the PT-AE900U's HDTV color reference, as well as the gamut of colors that it is capable of creating. I was able to get better color reproduction, but only at the expense of black levels and sacrificing overall accuracy. The real ticket was attaining compromise of best color, along with a solid grayscale uniformity and deep black and white levels.
Here are some of the before and after measurements as shown by the Datacolor ColorFacts Professional 5.5 software:
Before Calibration
After Calibration
Holy lack of reds, Batman! The default color mode for the Panasonic is " Normal ". I'd recommend using this only if you plan on watching sports like football and golf religiously where bold greens/bright whites are the most important aspect of your viewing enjoyment. Go for Cinema1 and start adjusting from there.
After calibrating the PT-AE900U were able to get the colors more into the ballpark but saw a consistent issue whereby red would creep into the higher gain levels. Playing with the red gamma is what we would recommend here for those of you who absolutely must have perfection.
When the unit is stepped through levels of grey from 0 IRE to 100 IRE, the measurements hold a rather uniform luminance histogram.
No surprise here. After adjusting the set we have an equally uniform luminance performance.
Got color? The Panasonic (in ' Normal ' mode) was a bit off form the desired 6500K reading we were looking for.
After calibration, the PT-AE900U got right down to business, settling in about where we wanted it to. It doesn't typically get much flatter than this without some serious tweaking.
I was pleasantly surprised by the Panasonic and found it to be very easy to calibrate using the user controls. The only negative we found was a tendency for red to creep into the higher luminance windows. As the gain increases, the amount of visible red grows disproportionately. The provided gamma controls are where you may spend some time in dialing that in a little bit to attain an even more tweaked performance.
Perfect Score is 130
Panasonic PT-AE900U Benchmark Score: 71 (room for improvement, but darn good from what we've tested to date)
Test
Max
Points
Component
Results
Component
PassFail
Color Bar
10
10
Pass
Jaggies #1
5
3
Pass
Jaggies #2
5
3
Pass
Flag
10
5
Pass
Detail
10
10
Pass
Noise
10
0
Fail
Motion Adaptive Noise Reduction
10
0
Fail
Film Detail
10
10
Pass
Cadence 2:2 Video
5
5
Pass
Cadence 2:2:2:4 DV Cam
5
5
Pass
Cadence 2:3:3:2 DV Cam
5
0
Fail
Cadence 3:2:3:2:2 Vari-speed
5
0
Fail
Cadence 5:5 Animation
5
0
Fail
Cadence 6:4 Animation
5
5
Pass
Cadence 8:7 animation
5
0
Fail
Cadence 3:2 24fps film
5
5
Pass
Scrolling Horizontal
10
5
Pass
Scrolling Rolling
10
5
Pass
Total Points
130
71
Comments on HQV Testing
I'd have to say I was impressed with the Panasonic's overall video processing performance for a front projection system. In fact, it outclassed the progressive scan output from a Sony ES DVP-CX777ES in our first round of testing; leading us to select feeding it interlaced 480i output from the Sony rather than allowing the 400-disc changer to handle the task of deinterlacing (the back end of the review was done using a Denon DVD-3910). The noise reduction feature of the Panasonic, in real world use, seemed to do very little. I could see some noise reduction, mostly around the very edges of objects, but never enough to qualify as passing the HQV noise tests. Jaggie reduction was acceptable, but not quite as smooth as Faroudja or HQV chipsets. There was a bit of wobbling around the center and at extreme angles. This also translated to the more real-world flag test. Detail was excellent and the Panasonic handled more cadences than the FLI 2310. 2:3 pull-down, needless to say, was perfect, with a faster lock-on time in the Film Detail test than most DVD players I have tested to date (the DVD-5910 excepted.)
Recent Forum Posts:
imrjones posts on February 07, 2008 15:37
Hello,
Is there any way I can do any manual adjustment to the picture on a Panasonic PT-AE900U? I get like a bit of a ghost image or blur around images on the screen and I have adjusted it from the lens but is there anything else I can do? Is there anything inside that I can adjust?
BMXTRIX posts on April 25, 2006 14:57
If you can put the projector ANYWHERE... Then I would look at where a typical mounting distance would be for projectors without as much versatility. Say, the InFocus IN76 or Optoma HD72. If those models are supposed to be 13 feet from the lens to the screen (or so) then that is where I would put the projector. That way, you are at least marginally sure that should you upgrade down the road you will be able to swap out the current projector for a new projector that may not have as much versatility in the setup.
docferdie posts on April 25, 2006 11:36
Thanks for the reply. As far as general installation is concerned, given the wide range of throw distances for a given screen size, is it better to mount this projector closer to the screen or as far back as possible, or does it not make a difference? Basement is still unfinished so this is my one shot to get it right.
BMXTRIX posts on April 24, 2006 21:41
I can't imagine that you would get that much from almost any projector over the current lineup of 720p $2Kish projectors on the market.
When I got my projector 3 years ago (Panny PT-L300U) the first thing I did was put it right under a $12,000 Runco projector. The Runco was a LITTLE bit brighter, had a little bit better image processing, colors were a tiny bit more accurate - and it was no less than five times as noisy.
The store manager walked in and said "Yep, that's why we don't sell those, they look way to go for the money."
Bottom line is that there are very, VERY few projectors over $5K or $6K that I would recommend. Some of the 3-chip DLP models (Sim2) or the Sony Ruby (1080p SXRD).
But, that's my opinion on all of it. Looking for 90%+ of the quality?
Panasonic AE900
Sanyo PLV-Z4
Optoma HD72
InFocus IN76
docferdie posts on April 24, 2006 14:19
can somebody please do a head to head with this projector and the yamaha DPX-1300? I don't want to spend an extra $7000 if I'm not getting that much more in terms of image quality.
