You are here: Home Pro Reviews Projectors Optoma HD80 DLP Projector Review HD80 Benchmark Testing and Results
by Clint DeBoer last modified September 13, 2007
Perfect SD Score is 130
Perfect HD Score is 100
Optoma HD80
Benchmark SD Score: 80 (you are going to get an excellent picture)
Optoma HD80 Benchmark HD Score: 75 (you are going to get an excellent HD picture)
SD Test Max
Points
Results Pass/Fail
Color Bar 10 10 Pass
Jaggies #1 5 5 Pass
Jaggies #2 5 5 Pass
Flag 10 10 Pass
Detail 10 10 Pass
Noise 10 5 Pass
Motion adaptive Noise Reduction 10 0 Fail
Film Detail 10 10 Pass
Cadence 2:2 Video 5 0 Fail
Cadence 2:2:2:4 DV Cam 5 0 Fail
Cadence 2:3:3:2 DV Cam 5 0 Fail
Cadence 3:2:3:2:2 Vari-speed 5 0 Fail
Cadence 5:5 Animation 5 0 Fail
Cadence 6:4 Animation 5 0 Fail
Cadence 8:7 animation 5 0 Fail
Cadence 3:2 24fps film 5 5 Pass
Scrolling Horizontal 10 10 Pass
Scrolling Rolling 10 10 Pass
Total Points 130 80
The HD80 was sent 480i via HDMI from a Denon DVD-3930CI.
HD Test Max
Points
Results Pass/Fail
HD Noise Reduction A & B 25 0 Fail
HD Video Resolution Loss 20 20 Pass
Jaggies A & B 20 20 Pass
Film Resolution Loss 25 25 Pass
Film Resolution Loss Stadium 10 10 Pass
Total Points 100 75
The HD80 was sent 1080i via HDMI from a Toshiba HD-XA2 HD DVD Player.
Comments on HQV Testing
We were quite pleased with the results of the onboard PixelWorks DNX processing. In fact, the HD80 scored higher on our HQV Benchmark DVD tests than the HD81 with the outboard Gennum processor. This may be surprising to some, but PixelWorks is no slouch when it comes to deinterlacing and scaling. The Film Detail test passed, but just barely as the lock on took right up until the very border of fully passing to engage. We've seen quicker processors, but the system had a good memory and it never missed its mark. Noise reduction was acceptable at lower settings, though it wasn't as effective. When turned up, the display exhibited what I call “floaters” - where the center of an item remains detached from the edges which are being processed to reduced noise. The effect is of objects orbiting inside themselves in a very unnatural way. In motion, trails could be seen at any setting above 4. If you want to engage the noise reduction, just be sure to keep it below this level.
Recent Forum Posts:
Clint DeBoer posts on September 25, 2007 11:01
BMXTRIX;308722
Why is this so hard for the DLP models to achieve?
Let's ask an even better question: Why can I buy THREE decent single-chip DLP projectors for a grand total of $3000, but I can't buy a SINGLE three-chip DLP projector for less than $10,000?
That's the question I want answered.
erick.s posts on September 25, 2007 10:49
Agreed. In all honesty the only reason I haven't bought this projector is the ridiculous offset. I saw it at a dealer and it's perfect for me except for this one thing.
BMXTRIX posts on September 13, 2007 19:28
Thanks for putting the image offset right at the top as one of the cons. It's the first specification that I check on projectors. Since I have a motorized screen which only gives me 12" of drop, it completely blows my mind that these IDIOTS continue to design DLP projectors that have no lens shift and anything more than just a few inches of offset.
My old AE300 projector from Panny, with no lens shift, sits about 5" above the top of my screen and works great.
