HC5000 Inputs, Remote and Menu System
I liked my options on the HC5000. Typically a person isn't going to run multiple component video cables to a projector, so having one option for each connection type seemed very practical and reasonable. Notably, neither the DVI-D or HDMI are shown to support 1080p/24 (at 48Hz) in the user manual, however Mitsubishi claims that it is supported. Unfortunately, my Toshiba HD-XA2 HD DVD player doesn't (yet) so we'll have to pass on this test for now.
Mitsubishi HC5000 rear connections
The all-important 12V
trigger is present on the rear panel of the HC5000 as is a functional RS-232C
which will make this projector fully compatible with higher-end control
systems. The component inputs are for use with a maximum of 720p/1080i, so if
you've got your Xbox ready to output 1080p, downshift it to 1080i or get the
new version with HDMI outputs. Either way I'm betting it still looks great… and
since I'm not a betting man, I'll toss up the screenshots to prove it.
Mitsubishi HC5000 Remote Control
I liked the layout of the
HC5000's remote. All buttons were easily accessible and the backlit function
came on when ANY button was pressed - a feature I appreciate and request in any
projector remote. The backlight stays on for about 6 seconds which is
reasonable, and I liked the arrangement of buttons. What I didn't like was the
range and effectiveness of the remote. I was very difficult to control the
HC5000, even though I was only about 11.5 feet form the screen. At times I
found myself doing contortions to get the remote positioned just right, even
aiming it backwards at times when I finally got frustrated. There is no excuse
for this type of remote control behavior given the price of this unit and beta
testing which certainly must have revealed this prior to release. The reason it
is so frustrating is that it takes all of the positive features like motorized
zoom, focus and lens shift and turns them into "mini-hassles" which
must be endured. Had the remote controlled the system better, then I'd be
spending all this energy and literary real estate gushing about how cool it is
to use a remote to focus and dial-in the picture.
The Menu System
With the exception of
getting in and out of the sub-menus, the menu system on the HC5000 is
straightforward and easy to navigate. Sub-menus are somewhat anti-ergonomic and
annoying because they force you to scroll all the way to the top to exit a
particular area or hit the Menu button rather than the far more intuitive 'left
arrow' exiting I see in many other projectors. All whining aside, I was at
least happy to see that most of the functions I look for were present and there
was a great deal of customization available in the User menu.
Image Menu
This grants the user access to Gamma
(picture) modes and the typical adjustment settings for the projector like
Contrast, Brightness, etc. You can also save your settings to Memory positions
which can be recalled from the remote directly. This is very handy if you
decide to set up unique modes for difference types of viewing (daytime,
nighttime, black & white movies, etc.) AV Memory settings also work across
different inputs.
Installation
Menu
The
Installation menu is simply where you configure the most basic functions of the
display such as auto on/off, background color (when no signal is present),
front/rear projection mode (called "image reverse") and the trigger
output. You can also call up a test pattern and lock the lens so that
adjustments cannot be made which would throw off the picture (handy for once a
system is installed in a ceiling mount configuration).
Feature Menu
This
menu is a catch-all for such controls as aspect ratio, Menu Dimmer/Position,
Setup (a black level mode that we found works best when in Auto or Off),
Language and Cinema (deinterlacing) modes.
Signal Menu
Primarily
for PC interfacing, this menu gives you the ability to access vertical and
horizontal positioning, Fine Sync and Tracking adjustments. Users will also
find the Overscan function here - be sure to set it to 100% for best scaling
results.
Information
Menu
This
provides info on the currently active source input, delivering signal frequency
and resolution. It also shows the lamp hours which will let you know when
you're getting close to the time when a new lamp should be ordered.
