You are here: Home Pro Reviews Projectors Mitsubishi HC5000 Projector Review
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Clint DeBoer last modified July 24, 2008
Mitsubishi HC5000 3LCD Projector
  • Product Name: HC 5000 Projector
  • Manufacturer: Mitsubishi Digital Electronics America
  • Distributor: ProjectorPeople.com
  • Review Date: June 27, 2007 09:19
  • MSRP: $ 4495
Specifications
Brightness: 1000 ANSI lumens (vivid mode)
Contrast: Up to 10,000:1 (with Iris operation)
Resolution: 1920 x 1080 native HD resolution
Aspect Ratio: Widescreen native 16:9 aspect ratio (4:3 resized)
LCD Panel: 3 x 0.74" three-panel inorganic C2Fine LCD
Optical System: Dichroic mirror separation and prism combine method
Video Processor: Silicon Optix Reon VX HQV, 3D Y/C digital comb filter
Iris: Auto Iris optical system
Video Inputs: HDMI-HDCP (1.3), DVI-D, component, composite, S-video and PC/RGB (HD15)
Control: RS-232C, IR remote
Projection Lens: F=23.5-37.6mm; F1.8 – 2.3 (3.1-5.0m@100");
Scanning Rate: 15-100kHz (horizontal) 50-120Hz (vertical); dot clock max 170MHz
Throw Ratio: 1.41 - 2.26
Zoom: Powered focus & zoom (1.6:1)
Lens Shift: Vertical and horizontal (75% vertical, 5% horizontal)
Keystone Correction: +/- 15 degrees (vertical)
Lamp: 160W UHP, 2000 hours normal, 5000 hours in eco-mode
Power Supply: 100-120 volts, 2.7A
Power Consumption: 245W (high); 200W (low); 4W (standby)
Operating Temperature: 32 – 104 degrees F (0 – 40 degrees C); 20-80% humidity (no condensation)
Fan: 24dBA operation (19dBA in low mode)
Remote Control: Backlit w/batteries included
Standard Accessories
: Power cord, RGB cable, RS-232C cable, manuals, wireless remote control unit, batteries for remote control
Warranty: 2 years parts & labor
Dimensions: 13.1” x 4.9” x 13.8” in
Weight: 12.3 lbs (5.6 kg)
  • VERY quiet
  • No screen door effect
  • Motorized lens shift, zoom, and focus
  • Backlit remote
  • Native 1080p/24/60 support
  • HDMI 1.3 with 480i support
  • Slow, noticeable, undefeatable auto-iris
  • Weak remote signal
  • HDMI didn't pass Blacker-than-black
  • Cumbersome menu system
  • Limited horizontal lens shift range
Introduction
In a sea of new 1080p projectors being released this year, Mitsubishi has a distinctive product that sets it apart as a leader. The C2Fine technology renders an incredible picture and does indeed produce some excellent black levels. If you're shopping for a 1080p model you owe it to yourself to check it out.
Recent Forum Posts:
raneil posts on July 08, 2007 03:09
Are you sure that the projector that you reviewed has HDMI 1.3? Yours is the only review to make such a claim. If so, it sounds like a production upgrade that potential buyers should inquire of prior to making a purchase,
hdfansv posts on June 28, 2007 14:13
Hi Clint,
Just a few nitpicking in your review so that it does not confuse your readers.
"Whether it was pin-striped shirts, or city skylines that would make any jaggie-reduction scream in terror, Batman Begins is a movie that you can test nearly all aspects of a projector's video processing system with."
This sentence is incorrect. The Jaggie-reduction algorithms are not activated when the deinterlacer is in film mode. Edge adaptive interpolation switches on for video deinterlacing NEVER for film mode. The reason for that is you have all the pixels from the complete frame and there is no need for anti-aliasing filter.
Also
"We also confirmed results with 1080i upconversion."
The film mode tests are not valid when you upsample from 480i --> 1080i. In that case you are evaluating the film mode handling of the upsampling DVD player.
Clint DeBoer posts on June 27, 2007 20:14
My guess is it was the transmitter (remote). It certainly improved with new batteries but was never stellar like some other remotes I've used.
I've packed up the unit, so I missed my window to troubleshoot it further.
djoxygen posts on June 27, 2007 17:27
Do you know if the poor IR reception was the fault of the transmitter or the receiver? If it was the transmitter's fault, wouldn't the issue disappear for those who use universal remotes?
