Epson Pro Cinema 6010 3LCD Projector Preview
by Clint DeBoer last modified September 10, 2011
  • Product Name: Pro Cinema 6010 3LCD Projector
  • Manufacturer: Epson
  • Review Date: September 10, 2011 06:37
  • MSRP: $3999
Specifications
  • 2D & 3D full HD 1080p
  • 2D-to-3D conversion
  • Astounding brightness — 2400 lumens color and white light output1
  • Advanced 3D technology — Epson's Bright 3D Drive for enhanced brightness in 3D mode
  • Exquisite detail — up to 200,000:1 contrast ratio, Super-resolution technology (2D mode) and superior processing for the most discerning AV enthusiasts
  • Rich, vibrant color and reliable performance — 3LCD, 3-chip technology
  • Accurate and exceptional picture quality — built-in cinema filter and THX certification (pending)
  • FineFrame technology — smoother frame interpolation and sharper video quality (2D mode)
  • Two anamorphic lens modes (stretch and squeeze) — enables 2.35:1 anamorphic viewing without an external processor1
  • Outstanding installation flexibility with maximum image quality — Fujinon OptiCinema lens (2.1x zoom ratio) and a manual lens shift of up to 96.3% vertical and up to 47.1% horizontal
  • Optimum output in any environment — ISF calibration enables you to customize specific settings
  • Split screen feature (not available in 3D mode) — project two images side-by-side from two different sources
  • 3D glasses — includes two pairs of active shutter 3D glasses
  • Also includes — spare lamp, cable cover and mount
  • Outstanding support — three-year limited warranty; next-business-day shipping service
Executive Overview
Among one of the brighter, no pun intended - OK, yes it was!) moments of CEDIA occurred when we witnessed the demo of Epson's new Pro Cinema 6010. This is Epson's newest Pro model (which means it comes in black and is sold through traditional dealers only). The new projector replaces the Pro Cinema 9700UB (currently our reference projector). As you'd come to expect from Epson, the new 6010 comes with a full 3-year service warranty (and there is no limit on hours of use) and that warranty service includes advance replacement (typically within 48 hours from Epson to the client). Like all Epson Pro models the price includes a spare lamp, Chief ceiling mount (this is a new mount style), and a plastic rear cable cover to dress up the connections.  New for 2011's Pro Cinema 6010 is the inclusion of 2 pairs active shutter glasses... that's right, the Pro Cinema 6010 is fully 3D compatible. Additional glasses can be ordered at time of purchase and the retail is under $100 (these are consortium glasses and very cross compatible with most IR-based systems).
Since the 6010 projector is 3D, it needs to have emitters for timing the active shutters on the glasses. This is an 18-LED array located just to the right of the lens. The design is that the timing signal would bounce off the screen, but there is also an external emitter option for installations where the projector is hidden or placed within a hush box.
3D traditional lowers the light reaching the viewer, since the glasses are constantly shutting of one eye - the effect is a 50% reduction in light. Epson uses something it dubs "3D Drive Technology" in its new projectors (including the 3010, 5010 and 3010e and 5010e), which drives the panels at 480Hz, essentially doubling the image refresh rate of 240Hz panels and boosting light to the viewer while reducing crosstalk. The other thing we were surprised to hear was that these new projectors crank up to 2,400 lumens (obviously in peak output mode). Epson is using a 230W E-TORL lamp for all of their new projectors and is claiming a contrast ratio of 200,000:1. What we're seeing as a general trend is that manufacturers, in compensating for the effects of 3D on realized light output, are having to use different, brighter technology to achieve the same calibrated performance with 3D content.
Some interesting features that also caught our attention and are worth mentioning:
  • 2D-to-3D conversion upconverts standard video to 3D with variably control over the effect
  • THX certification pending (presumably while the check clears)
  • Two anamorphic lens modes (stretch and squeeze) which allows you to achieve 2.35:1 anamorphic viewing without an external processor
  • Split screen feature in 2D which lets you project two images side-by-side from two different sources
We were very impressed with the demo of the Pro Cinema 6010. It had deep blacks, though it was still obviously a traditional 3LCD system and had its limitations. What's truly impressive is what the effective contrast and color looks like - and for under $4000. In fact, the new Epson Pro Cinema 6010 is shipping in November for $3999.
Recent Forum Posts:
Patrick G. posts on February 17, 2012 09:56
Good review
Savage40 posts on January 24, 2012 08:08
Bredwyn;859002
Epson 6010 3D 1080p projector: I just bought one two weeks ago. When it works, it is fabulous. Just great. AMAZINGLY GOOD. WHEN it works.
It has problems powering up. It gets stuck in half-booted mode: the lamp is on but not fully on and nothing changes that. No menus, no signal, nothing. After half an hour of trying, I can usually get it to boot up. The problem may be about temperature: I suspect the machine doesn't like it when the room is not very warm.
Epson told me they were shipping a new one to me, but it did not arrive. I finally called them after waiting all day, and they told me that they were out of stock. My beef is not that the machine is faulty, or that they were out of stock (things happen). My beef is that they did not contact me to tell me this, and when i complained about that, they said that the warranty department is not in touch with tech support. Finally, now, they are being more communicative. But they are still out of stock for another week.
If their service improves and if the problem is not endemic to the machine, then I would have no hesitation in recommending it.
IF.
That is a big problem, I just got mine, but haven't hooked it up yet. The 6010 though is supposed to come with a guaranteed NEXT DAY replacement. What good is a guarantee if they can not guarantee it? h
I hope you get your problem resolved post haste!
Bredwyn posts on January 20, 2012 13:04
IF.
gmichael posts on October 24, 2011 16:40
I have plans on buying the 5010e if reviews are possitive. My Sanyo Z4 has about 9000 hours on it. Over 3000 on this bulb.
gilcanyon posts on October 24, 2011 16:31
Can't wait--Looks like Epson has come through big time to equal the performance of the 8500/8700.
sign me up.
gil
