1080UB Movies and Games
The Epson PowerLite Pro Cinema 1080UB was a pleasure to watch, and while I didn't include everything I watched in this review, I put forth many clips designed to show the detail evident in this revised projector.
HDTV: Las
Vegas
Las Vegas is a very "red" show, but
it also has the added benefit of putting out a ton of indoor material, varying
from sparsely-lit offices to outdoor scenes on the Vegas Strip. I was able to
capture a couple shots that showed off the deep black levels and also the rich
saturation which this projector is more than capable of providing.
Rich colors, deep blacks make up the Las Vegas typical shots
HDTV: Rides
Rides had a unique
show where they introduced the new Corvette Z06 along with the makers of the
Corvette. Additionally, they showed off the new Corvette C6.R. This car is
insane - 505 horsepower from a small block 8-cylinder engine that holds a combination
of aluminum and titanium parts. Of course, what I liked was how awesome it
looked in HD - even close up on a supersized projector screen.
I'll take two - they're small (block).
Xbox 360: Army
of Two
Any time I
can play a video game and call it "work" I'm all over it. I decided
to put up some Army of Two action
(with my trusty sidekick Tom Andry) and see how well the Epson handled
fast-paced gaming action as well as the intensely dark scenes I knew AoT was
capable of delivering. OK, so I probably played the game for 5 hours in order
to snap a couple of cut scene shots, but it was worth it. The game looks great,
and there's simply no avoiding the excellent dynamic range which is evident any
time an explosion or shootout happens indoors. This game has plenty of content
to deliver and it will eat up your display for all its worth. In this case, the
Epson held on for the ride and came out looking pretty great.
Army of Two is butt-kick-a-liscious!
Xbox 360: Clive
Barker's Jericho
This game is
insane. It's very different from any other third person shooter I've ever
played and the environments seem like they were pulled right out of the mind of
a masterful horror story writer. Oh wait, they were. In fact, the storyline and
voice acting are so convincing, it's hard not to get your pulse racing and find
yourself looking deep into the dimmed corners in anticipation of the next
strange creature to leap out at you from the darkness. Having a projector that
can handle the deep dark areas really helps for games like this and I was
thankful that Epson had both increased the lumen output of the project while at
the same time making improvements to the LCD panels. The end result is more
dynamic range - and this game used it all up.
Xbox 360: Turok
With a game
like Turok - if you play this on an older projector you'll either be looking at
a ridiculously over-bright picture where blacks are gray, or you'll see an
occasional splotch of light in an otherwise sea of black. You're basically
running around caves for the demo - trying to get out. Caves. Dark caves. With
velociraptors hunting you down. Did I mention this is a dark game? Check out
these pics:
See also:
Recent Forum Posts:
Biggiesized;414238
What's D7 technology?
Check this out:
http://www.audioholics.com/education/display-formats-technology/epsons-d7-panel-c2-fine [audioholics.com]
AcuDefTechGuy;413529
I have not heard any negative about the Epson 1080UB.
Are you sure it's the same exact model?
Yes. It definitely is. I've also seen only good reviews for this until I read the What HIFI one. I must be honest. I absolutely love the Infocus IN82. They're priced similarly here is South Africa. Which would you go for if it was your money? (Yes I know you can't compare them directly DLP vs LCD, but still. If you had to choose.)
The Epson Pro Cinema 1080UB is marketed as the TW2000 outside of the USA, only 1 model is available, that is, no Home Cinema 1080UB...... I can't post links yet try projectorsreviews-dot-com
Is it like DarkChip in DLP?
