1080UB Bench Testing and Convergence
Perfect Score is 130
Epson PowerLite Pro Cinema 1080UB Benchmark Score: 95
(an overall great performer where it counts)
Test |
Max |
Component |
Component |
Color Bar |
10 |
10 |
Pass |
Jaggies #1 |
5 |
5 |
Pass |
Jaggies #2 |
5 |
5 |
Pass |
Flag |
10 |
10 |
Pass |
Detail |
10 |
10 |
Pass |
Noise |
10 |
10 |
Pass |
Motion adaptive Noise Reduction |
10 |
10** |
Pass |
Film Detail |
10 |
10 |
Pass |
Cadence 2:2 Video |
5 |
0 |
Fail |
Cadence 2:2:2:4 DV Cam |
5 |
0 |
Fail |
Cadence 2:3:3:2 DV Cam |
5 |
0 |
Fail |
Cadence 3:2:3:2:2 Vari-speed |
5 |
0 |
Fail |
Cadence 5:5 Animation |
5 |
0 |
Fail |
Cadence 6:4 Animation |
5 |
0 |
Fail |
Cadence 8:7 animation |
5 |
0 |
Fail |
Cadence 3:2 24fps film |
5 |
5 |
Pass |
Scrolling Horizontal |
10 |
10 |
Pass |
Scrolling Rolling |
10 |
10 |
Pass |
Total Points |
130 |
95 |
*We fed the unit 480i HDMI output from a Denon DVD-3930CI **There was some panel blurring.
Comments on Bench Testing
The Pro Cinema 1080UB mimicked the former Pro Cinema 1080 except that it passed the Film Detail test this go-around. I noticed a tiny bit of smearing on the Motion adaptive Noise Reduction test, though after comparing to a source component I was familiar with, I chalked up a majority of the slight blurring as the fault of the LCD panel. This was the reason it didn't fail. With this projector you're going to get a great picture, even if you are feeding it interlaced standard definition.
Quality Control Issues - Convergence
You may have
heard a bit about the convergence issues associated with the 1080UB series.
What I'm not certain of is how many people would be concerned if they had never
heard about it in the first place. Nevertheless, the issue centers around the
correct alignment of the three LCD panels and how that translates into the
projectors ability to clearly produce the image pixels on the screen. In my
first sample (yes I got nailed with it as well) my projector was far enough off
that I could notice a slight reddish hue at the lower right of my screen and a
slight green tinge at the center when putting up a test pattern grid. While I
didn't notice the convergence issue on normal viewing material, it bugged me
enough that I had Epson send me a replacement - and the replacement, while not
absolutely perfect, was likely within tolerance. If DLP gets wind of this, you
can count on press releases all over the place about how single chip DLP
systems don't suffer from convergence problems…
Here's what the convergence issue looks like:
To me this was a bit too much to accept for the price. Epson has reportedly gotten a bit better in the QC department since this became a very public issue earlier this year.
And we would be lax if we didn't link to the AVS Forum thread that discusses some of the issues and provides user pics of what to look for.
See also:
Recent Forum Posts:
Biggiesized;414238
What's D7 technology?
Check this out:
http://www.audioholics.com/education/display-formats-technology/epsons-d7-panel-c2-fine [audioholics.com]
AcuDefTechGuy;413529
I have not heard any negative about the Epson 1080UB.
Are you sure it's the same exact model?
Yes. It definitely is. I've also seen only good reviews for this until I read the What HIFI one. I must be honest. I absolutely love the Infocus IN82. They're priced similarly here is South Africa. Which would you go for if it was your money? (Yes I know you can't compare them directly DLP vs LCD, but still. If you had to choose.)
The Epson Pro Cinema 1080UB is marketed as the TW2000 outside of the USA, only 1 model is available, that is, no Home Cinema 1080UB...... I can't post links yet try projectorsreviews-dot-com
Is it like DarkChip in DLP?
