Epson Pro Cinema 1080 Features and Comparison
1080p is coming to market with a vengeance. Epson is leading the way with its new 1080p LCD panels and the only question is: how well does this projector compare to other products available on the market? With pricing under $5000 and Epson's proclivity for producing very high quality projectors with excellent features, detail and color, it's bound to be a serious contender in the market.
I think labeling 1080p as "true" high definition is a bit unfair, but I do understand the desire of the industry as a whole (not to mention consumers) to get away from the dual 720p/1080i scenario and jump straight to the maximum consumer resolution currently available. You can see this is happening as new DVD players and displays come to market left ad right with support for 1080p (whether as an input format or upconversion output resolution). 1080p is not only coming - it's apparently here to stay, at least as a standard resolution.
Features and Favorites
We just (and I do mean JUST) reviewed the Epson PowerLite Pro Cinema 810 HQV projector. Many of the physical features of the Pro Cineam 1080p are identical to the 810 HQV, however there are some stand out differences as well. Here are the features of the Epson Pro Cinema 1080 that we wanted to highlight for our readers:
- C2 Fine VAN 3LCD System
Epson's new C2 Fine (Crystal Clear Fine) system produces a higher contrast and pixels that are so close together you'll have to literally be standing less than 3 feet away from the screen in order to see pixels. Any hint of screen door effect has been eliminated from the Pro Cinema 1080. - Horizontal and Vertical Lens Shift
Along with Epson's "super-zoom" , the 1080 maintains Epson's signature ~100% horizontal and ~50% vertical lens shift, allowing users to position this projector just about anywhere inside, or even outside the screen area. Keystoning is a thing of the past. Like all Epson theater projectors, the lens shift still does not have a locking function and use at both extremes is impossible. - 1080p Native Resolution
This Epson projector has support for native 1080p content without scaling or loss of resolution. That means your overpriced 1080p-mastered BD and HD DVD discs will look absolutely fantastic on this projector. - HDMI 1.3
The Pro Cinema 1080 sports HDMI 1.3 and Deep Color for the best possible image color depth.
How to Spend ~$5000: 1080p or 720p with HQV Processing?
For those with the budget - it's an interesting decision to make when comparing the Pro Cinema 1080 and its 720p counterpart the 810 with HQV option. For all intents and purposes, they are priced almost the same and depending on your needs you may swing one way or the other. Here are the quick specs for comparison:
Epson Pro Cinema 1080 |
Epson Pro Cinema 810 HQV |
HQV Score: 85 |
HQV Score: 125 |
3 x 1920 x 1080 pixels |
3 x 1024 x 720 pixels |
0.74-inch C2Fine LCD panels |
0.7-inch D5 MLA |
Inputs: S-video Component PC (HD15) |
Inputs: S-video Component (BNC with adapters) PC (HD15) S/PDIF audio |
Outputs: NA |
Outputs: |
Contrast Ratio: 12,000:1 |
Contrast Ratio: 10,000:1 |
1200 ANSI lumens |
1600 ANSI lumens |
Scaling Options: Zoom |
Scaling Options: |
1) 12V Triggers |
2) 12V Triggers |
RS-232C: Yes |
RS-232C: Yes with Slave |
Full native 1080p/24/30/60 support |
480i/480p/720p/1080i support (limited 1080p/24/30 downscaling) |
MSRP: $4,999 |
MSRP: $5,999 |
Recent Forum Posts:
1) Can I zoom the image fairly small from 10-15'?
2) Is there a supplier that has developed whole wall surfaces for video projection?
Regarding the first question, does the manual focus on the projector give me enough control to crisply project a relatively small display area, say 46" or so?
To put this into context, I have spent time looking at the costs of hiding a tv behind a picture frame and mirror or painting canvas; a high quality installation can cost $15,000.
A custom light fixture with a $5,000 projector seems a much better approach to "not wanting to see the TV when not in use".
If I can zoom the image to a 46" rectangle, the search for suitable paint or wall paper to overcome the lack of a projection screen would begin.
admin;261037
This is really starting to make me reconsider buying a TV, albeit a very high end one. The projector pricing is starting to come down into high-end tv range, and the thought of having a billy badass-sized screen make it even more alluring! And with the power of Santa growing stronger in the coming months, I would bet prices will drop considerably.
Owners: More details on performance please.
cleaner450;263470
Here is a question ..primarly using it for 360 and HD DVD... How does the image overall compare to ..ummm lets say a 50 inch rear projection. besides the size; does it or could it look as good, clear and bright a rp TV.
Sorry if I am being very broad but you own it and I just want to get your thoughts on quality of picture compared to a rp. This will be set up in a very dark room...
thanks
I game and now am more into HT but games are what maed me want a big TV. I got a front projector. I will never ever ever o back to anything else for the main HT/"viewing room. I have aCRT for the news etc, but untill projectors cost more as a box that has a set screan I won't even think about the RP plasma LCD even DLP.
I hop emine never dies, if it did today it would be epson for sure and if they make a DLP in my price point that would be it. Hands down.
